Highschool project and BS
Discussion in 'Armor' started by Jensonbt, Jan 2, 2019.
  1. Jan 2, 2019 at 10:00 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    How are you connecting the kicker tubes to the angle iron piece if your not welding?
  2. Jan 2, 2019 at 10:05 PM
    Jensonbt
    Jensonbt [OP] Well-Known Member
    Beckler
    Idaho
    2012 gray tacoma DCLB
    Just enough to look kinda cool.
    The slider tubes will be welded together but bolted to the frame. So that if I need to remove the sliders for additional maintenance or additions I can unbolt them from the truck.
  3. Jan 2, 2019 at 10:09 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I didn't think about the vibrations transferring from the frame through the sliders to the cab, but I'm pretty sure my 2003 body mounts are probably pretty dried out and I probably won't notice much of a difference.
    You may have a good point with your much newer 2012...
  4. Jan 2, 2019 at 10:11 PM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    2 things:
    A- listen to @Shmellmopwho, he's good.
    2- I need some tissue after this pic. Not the first time I've finished to a pic of bolt ons :jerkoff: (oYo) :anonymous:
    Shmellmopwho[QUOTED] likes this.
  5. Jan 2, 2019 at 10:11 PM
    Jensonbt
    Beckler
    Idaho
    I only say that because I can see the difference from the bumper hoops (directly bolted to the frame) and my hood.
  6. Jan 2, 2019 at 11:49 PM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    Bahahahaha!! :rofl:
    Thanks dude
    dumontrider[QUOTED] likes this.
  7. Jan 3, 2019 at 8:07 AM
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    Wouldn't you want to avoid attaching to the body/pinch weld? Sliders are meant to protect exactly that part of the truck, so wouldn't having a direct attachment to that cause damage if you were to slam down on the sliders? The impact would be transferred directly to the body. Being attached to the frame, being really stiff, and NOT attached to the body are what protect it... right?
    Hobbs and Shmellmopwho like this.
  8. Jan 3, 2019 at 8:10 AM
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    Exactly!
  9. Jan 3, 2019 at 8:28 AM
    DarthPow
    ok cool, glad I'm not the only one who sees it that way. They even have a bit on their site that says: "And no 'chat room expert' can deny this engineering fact." referring to the "fact" that their "triangulation" design is the best out there.
  10. Jan 3, 2019 at 8:33 AM
    JasonLee
    15 TRD OffRoad
    Since you're probably the only one reading the page, what do you think about the use of the hitch steel and the angled edges at the ends of the sliders?
    [​IMG] <--- angled vs ... 90 degree cut ----> [​IMG]
  11. Jan 3, 2019 at 8:55 AM
    DarthPow
    I'm no expert in the matter... but even if Hitch Steel is stronger than the normal steel most sliders use, it doesn't matter too much, since the the normal steel used is already plenty strong enough for their intended use. Most sliders out there can already take the weight of the truck on a single point. Using a stronger steel doesn't change anything on a practical level.
    As for the angled cut, Ryan (Schmellmop) and I discussed this point actually when he was installing my sliders. It would be helpful if a rock managed to get up in that point, but the chances of something actually hitting that area are very slim. The rock/obstacle would have to be basically a pyramid or something very pointy, and really you shouldn't drive over something like that anyway. The angled cut may help in a very, very rare case.
    Shmellmopwho likes this.
  12. Jan 3, 2019 at 9:01 AM
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    I certainly don’t wanna bash any company but those rocky road sliders are hardly sliders in my opinion. More like nice protective steps
    They have 2 legs that attach to the frame and they look like 1 or 1.25” square tube. Not adequate at all. There are no gussets on the legs and it only uses a couple bolts per side. The only reason these wouldn’t bend like crazy is because they’re gonna be hitting the rocker panel and pinch weld on the first hit they take and the body won’t allow those legs to bend.
    TomTwo, jowybyo and DarthPow like this.
  13. Jan 3, 2019 at 9:09 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    These pass for sliders??
    TomTwo and Shmellmopwho[QUOTED] like this.
  14. Jan 3, 2019 at 9:14 AM
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    That’s what they’re called I guess. Like I said, I’m not in the business of bashing other companies, just not who I am. But these look like very very very very very light duty sliders at best! All I’m trying to do is help @JasonLee make a better choice on a set of sliders when he is ready for a set. He mentioned that these seem to be the best on the market that he’s seen so far and if he’s looking to actually use a set of sliders like they’re intended, then these are faaaar from the best in terms of design.
    TomTwo and DarthPow like this.
  15. Jan 3, 2019 at 9:35 AM
    #35
    DarthPow
    I suppose in the interest of staying relevant to the OP, this is a good example of how not to build your sliders.
  16. Jan 3, 2019 at 9:38 AM
    #36
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    Egg zack ly!
  17. Jan 3, 2019 at 11:23 AM
    #37
    Jensonbt
    Beckler
    Idaho
    Picked up the 3x5 angle, and some 2x9 plate to cap the square tube ends. 569D240A-2D5E-4FFD-8C9F-85BDD3A28A63.jpg
  18. Jan 3, 2019 at 3:33 PM
    #38
    JasonLee
    15 TRD OffRoad
  19. Jan 3, 2019 at 3:36 PM
    #39
    JasonLee
    15 TRD OffRoad
    If they are not going to bend (assuming the main tubing sections are strong enough for that), why would an impact not transfer evenly into the bottom of the cab where these sliders are up against next to the entire length of the pinch weld?
    Also, if the force is transferred in this way, I don't see any reason to have excessively gusseted legs / connections to the frame - all those connections are doing are keeping the sliders from rotating (ends of legs towards the ground - outside of sliders up into the outside of the truck cab/doors).
  20. Jan 3, 2019 at 3:43 PM
    #40
    Clearwater Bill
    Billy
    Largo Florida
    That's a very cool shop project (I assume that's what it is?) Learning and practical at the same time.
    For an electronics project when in Tech school a couple of us drew up and built a 12v 'Christmas tree' (drag strip) from junkyard parts an scraps from around our houses. It disassembled quickly to toss in the trunk of the starters car. Some say it might have been used in street racing.
    My dad found it in the trunk and asked what it was. I showed him our drawings and how it assembled and worked. He said 'you know what that looks like to me?' No, dad, what? 'It looks like 'your Honor, this is exhibit A'. :anonymous:
    Pyrotech and TomTwo like this.
