Highway driving RPM, Shifting, Transmission, UGH!! 2018 TRD Pro
Discussion in '3rd Gen. Tacomas (2016-2023)' started by garner2002, Feb 22, 2019.
  1. Feb 22, 2019 at 8:41 AM
    garner2002
    garner2002 [OP] Well-Known Member
    DFW TX
    2018 TRD Pro Cavalry Blue
    I have had my truck for around 7K miles and love everything about it except for driving on road trips. At any highway speed between 70-80. When using the cruise control the transmission will never shift out of 4th gear, or it will shift between 4th and 5th, and never shift into 6th, unless I trick it by pressing quickly on the gas pedal. And I experience similar performance without the cruise control on, other than I can get it go into 6th downhill or on very flat roads by playing tricks with the gas pedal.
    I am getting around 20 MPG in the city and 14-16 MPG on the highway.
    This is ridiculous!
    Anyone have any suggestions other than trading it in for something different?
  2. Feb 22, 2019 at 8:44 AM
    su.b.rat
    su.b.rat broken truck
    OV Tune and/or regearing. or make the move to MT land if you want to stay with the Tacoma.
    Paul631 and doublethebass like this.
  3. Feb 22, 2019 at 8:51 AM
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    echo what @St.Germain has said. OVTune can save your truck and make you love it again.
    su.b.rat likes this.
  4. Feb 22, 2019 at 8:51 AM
    rogue.tacoma
    rogue.tacoma Well-Known Member
    Ed
    2017 TRD Off-Road 4x4 DCSB
    I'll be more than glad to take it off your hands
    a400ryan likes this.
  5. Feb 22, 2019 at 9:29 AM
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    These trucks could definitely use more torque at lower rpms.
  6. Feb 22, 2019 at 9:30 AM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    Did you get the transmission update? It makes a huge difference.
  7. Feb 22, 2019 at 10:42 AM
    garner2002
    DFW TX
    What is the TSB # for the transmission update?
  8. Feb 22, 2019 at 10:47 AM
    melikeymy beer
    melikeymy beer Hold my beer and watch this
    2019 Tundra
  9. Feb 22, 2019 at 10:49 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    TSB-0062-18 Also have done any mods to truck to induce your problems. Tires, lift, or ?
    Flash1034 likes this.
  10. Feb 22, 2019 at 10:55 AM
    garner2002
    DFW TX
    Added 265/75/16 Nitto Ridge Grapplers, only mod other than ditch lights and retrax bed cover.
  11. Feb 22, 2019 at 11:00 AM
    na8rboy
    WI
    The tires are going to drop your mileage, and not give you accurate mpg readings.
  12. Feb 22, 2019 at 11:02 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Instead of buying a tune, you could try S mode and ETC. S5 and ETC will fix 90% of your complaints without spending a dime.
    Cruise is just brutal in these trucks with the auto in D. I have all the latest TSB's and like my truck, but CC is pretty bad. I can typically beat CC in D by about 2-4 mpg by using my foot instead.
  13. Feb 22, 2019 at 11:03 AM
    prodemann
    prodemann Well-Known Member
    Phil
    Carver, MN
    2017 TRD Off Road AT DCSB Silver Sky
    TRD Pro grill, OVTune
    OVTune. It will totally fix what ails you.
  14. Feb 22, 2019 at 11:21 AM
    Flash1034
    N/W Montana
    Actually, when I went to 265/75/16s my speedo was right on. GPS confirmed.
    Get the tsb. Makes a world of difference
    na8rboy[QUOTED] likes this.
  15. Feb 22, 2019 at 11:27 AM
    CTF
    CTF Well-Known Member
    2017 TRD OR
    Mine used to do this. Somewhere between the tranny TSB, higher octane fuel and a Borla exhaust it has gotten noticeably better. I rarely hit 4th on the interstate now.
  16. Feb 22, 2019 at 11:33 AM
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    Yep, not looking forward to my first road trip scheduled for next month, from ABQ to DEN. Good news is it’s only 425 miles each way... bad news is I-25 has two high mountain passes to go through en route. From what info I’ve read on TW, I’m expecting a slower drive, painful A/T shift dance, part time in cruise control (when it flat), and poor MPG... and at the end of the day, completely pissed off.
    Managing my expectations :annoyed:
  17. Feb 22, 2019 at 11:35 AM
    CTF
    2017 TRD OR
    That’s what the ECT button is for!
  18. Feb 22, 2019 at 12:34 PM
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
    buy a standard trans i had a auto could not stand the way it allways shifted toyota could not do any improvments so traded in for stick
