Highway lane drift problem???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hellmutt, Aug 12, 2010.
  1. Aug 12, 2010 at 4:29 AM
    Hellmutt
    Hellmutt [OP] Well-Known Member
    Piqua, Ohio
    '08 SR5 TRDsport 4x4 DC
    sadly, I've only put Husky Liners in it thus far - tend to blow all my cash on my bikes and guitars.
    I'm new here, but I've experienced at highway speeds my tacoma tends to drift left and right a bit -- still stays within my lane, but seems like I'm always having to correct it's path........anybody else have this problem?
    I've bought the TRD sport package and had dealer add the front skid plate, but I wouldn't think that at 70-80mph the skid plate would generate enough lift to push the truck left/right??
    I've always had trouble with turbulence and crosswinds pushing the truck around but always just chalked that up to just being a light weight vehicle with higher ground clearance so there's little downforce at work there right??
  2. Aug 12, 2010 at 4:45 AM
    beef TACO no rice
    beef TACO no rice Well-Known Member
    Orlando, FL
    07 taco single cab
    Same problem here.. But im running 33.5x11.5 wide's.. So i just figure thats why.. I honestly dont know.. Maybe its bc the truck is so light?
    But im getting used to it
  3. Aug 12, 2010 at 4:46 AM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    mine doesn't drift at all, you may want to check your alignment.
    and welcome to TW!!!!!
  4. Aug 12, 2010 at 4:53 AM
    Hellmutt
    Piqua, Ohio
    Thanks for the welcome, and it's been aligned twice since I bought it and the problems never went away -- still got the factory Dunlops on it though, so possibly poor tire choice?
  5. Aug 12, 2010 at 4:57 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    What psi are you running in the front?
  6. Aug 12, 2010 at 4:58 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    More caster = less drift & twitchness due to road surface imperfections, grooves & wind.
  7. Aug 12, 2010 at 4:59 AM
    rhodehard09
    tampa, fl
    yeah mines lifted 3 with 32.5 km2s, but if i remember correctly it also rode straight as an arrow stock......
  8. Aug 12, 2010 at 5:08 AM
    Hellmutt
    Piqua, Ohio
    Believe they're at 32psi? Honestly, have to check -- been a while since I've done that -- but the few times I have checked them, rarely have to add any air pressure.
  9. Aug 12, 2010 at 5:09 AM
    Hellmutt
    Piqua, Ohio
    Thanks man, but would that affect tire longevity at all?
  10. Aug 12, 2010 at 5:27 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Camber and toe are what wear the tires, caster is more about tuning the way it feels driving down the road. I had my pwr steering rack replaced recently. Before that the caster was set near 3.0 after doing the UCAs to have caster adjustment after doing 2.5 lift. It drove perfect. The Toyota dealer put the caster back to 1.7 when doing the alignment after puttin on the new rack and now it is back on the verge of sucking again. I will deal with it for awhile but will have my regular alignment guy put it back to the 2.5 to 3.0 range when I buy another 1 yr alignment from NTB. I will not buy the lifetime Firestone one so they can practice learning.
  11. Aug 12, 2010 at 5:45 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Twitchy was how I described my 09 SR5 DC after I got it. Same thing I think, it just felt "light and fluffy" on the highway, not dangerous, almost boat-like floaty (60-70s Caddy feel).
    I did the following, not trying to solve this specific problem, but others:
    o Larger tires - from 245/75-16 to 265-70-16 - helped some
    o Rear TSB springs - helped some
    o 5100s at .85 lift - helped some
    o alignment (specific settings at 2.1/0/0, not stock range...) - helped quite a bit
    It still feels a bit light to me, but a combination of the above list and getting used to it, I just don't notice it anymore unless I have a strong crosswind.
    If I were to recommend one thing, get an alignment to specific settings.
  12. Aug 12, 2010 at 5:52 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Pardon the ignorance, what do the 3 numbers represent (2.1,0,0)? I don't know anything about alignment but I just got new tires and now my truck wanders like the OP's truck. I don't want to go into winter like this!
  13. Aug 12, 2010 at 5:55 AM
    Ridingontrd
    Richard
    Laughlin,N.V
    :cool: ok..That rules that out.
    + one more for more caster.
  14. Aug 12, 2010 at 5:57 AM
    Ridingontrd
    Richard
    Laughlin,N.V
    Toe 0*
    Camber 0*
    Caster 2.1*
  15. Aug 12, 2010 at 5:58 AM
    Hellmutt
    Piqua, Ohio
    Sweet, thanks for the insight -- mines bone stock currently, but I've got some plans to get a little bigger tires on my factory 17's and maybe some other mods too.
  16. Aug 12, 2010 at 5:59 AM
    Hellmutt
    Piqua, Ohio
    Nice, have to make a note of that........do these settings apply with factory wheels/tires as well?
  17. Aug 12, 2010 at 6:03 AM
    Ridingontrd
    Richard
    Laughlin,N.V
    Sorry,Don't know what it would be. :eek:
  18. Aug 12, 2010 at 6:20 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    This is what I set mine to. From my research (search on this site), the 2.1 will increase to 2.4-3.0 as you go with larger and larger tires. Stock sized though was 2.1/0/0.
  19. Aug 12, 2010 at 6:22 AM
    Hellmutt
    Piqua, Ohio
    Great! I'll have to try those out and see how she handles afterwards
  20. Aug 12, 2010 at 6:43 AM
    ClemsonTacoma
    ClemsonTacoma Well-Known Member
    Cam
    Lexington, SC
    Tacoma
    Pioneer DEH-P5100UB single din HU and black dash kit, Alpine 12" sub custom inverted box bed liner'd, various interior trim painted black, 48 blue LED domelight, cheepo floor mats, hose clamp mod, Cobra CB and knock off firestik, Stock steelie rims, with 265/75/16 Sumitomo HTR Sport A/T's
    My truck was fine before i got some new tires, now above 60 mph they just suck, I'm alll over the road but alignment is fine at lower speeds.
