Highway Speed "Float" after 2.5" Lift... Anyone?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by floridaoccifer, Jul 6, 2010.
  1. Jul 6, 2010 at 3:40 AM
    floridaoccifer
    floridaoccifer [OP] Civil Servant
    I just wanted to hear from those that have lifted your truck around the 2.5" or 3" mark.
    This is the first Tacoma I have ever lifted out of three I have owned. Ride quality prior to the lift was good and everything seemed very stable even at 80+ interstate speeds. Ever since the 2.5" spacers on the front end my highway speed "float", "drift" (whatever you call it) has gotten very noticeable at speeds 65mph+. To the point it made me slow down quite a bit the last rainstorm because it felt like I was hydroplaning (which it turns out I was not).
    Not to squash any of the random helpfulness that this forum tends to offer but I would really appreciate hearing from those that have this, corrected this or know why this is happening.
    Thanks in advance!
  2. Jul 6, 2010 at 3:53 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    Without aftermarket uca's your alignment will be a little off.
    Hence the "float".
  3. Jul 6, 2010 at 3:53 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Have you had your alignment checked?
    Increasing caster will usually stop the vehicle from wandering or floating. You want your caster to be around 2.4º.
    After lifting 2.5" and higher some people have trouble getting the proper Caster. Thats why some people install aftermarket UCAs. Most aftermarket UCAs are made to increase caster.
  4. Jul 6, 2010 at 3:54 AM
    Ridingontrd
    Richard
    Laughlin,N.V
    Did you get/have the alignment #'s?
  5. Jul 6, 2010 at 3:57 AM
    floridaoccifer
    No, but I will be calling the shop today. They stated camber was good and caster was close but off.
    What really bugs me about the alignment is that I can visually see the camber being "off" (still appear to be tucked in at the top).
    I should have stuck around while the tech aligned the truck... I will see if I can get the numbers today.
    As for aftermarket UCA's, a small lift such as I described would make things that noticeable? (once again, first lift, sorry for the redundant questions)
  6. Jul 6, 2010 at 4:04 AM
    Ridingontrd
    Richard
    Laughlin,N.V
    @ the last part..."Noticeable?" Yes,2.5" is the magic # for the Tacoma's i.f.s. front end.
    No worries on the questions.:cool:
  7. Jul 6, 2010 at 4:11 AM
    floridaoccifer
    Pirelli Scorpion 265/75/16 - These are 10 ply so I would assume that should not come into play. I am running 35psi all the way around right now.
    Again, THANK YOU for the input guys. I scheduled a numbers check for 9am at the shop.
  8. Jul 6, 2010 at 4:12 AM
    Ridingontrd
    Richard
    Laughlin,N.V
    :eek: No shit?? You :crazy::D
  9. Jul 6, 2010 at 5:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    But your Caster is still less than ideal. Some people are more likley to notice it than others, IMHO.
  10. Jul 6, 2010 at 7:07 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Did you specify the alignment settings to the shop? If not, the standard alignment range is used and that is more than likely not optimum for your lift/tires. Make sure you specify the settings you want the alignment set at, and make sure they are set there before you leave.
  11. Jul 6, 2010 at 7:14 AM
    betz.steven
    betz.steven Well-Known Member
    Southern NJ
    2011 TE 4Runner
    I noticed the float/wander pretty bad before at about 70+, but as others have stated i made sure the shop did my alignment correctly to the numbers I wanted ie. 0*toe 0*camber and 2.4* caster, rides like a dream ever since. Im running a stiff tire as well (285 KM2's) @35psi, also i AM running Total Chaos UCA's, my lift is right at 3in.
  12. Jul 6, 2010 at 7:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Gotcha.
  13. Jul 6, 2010 at 7:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thing is....This wandering people are having is directly related to the lack of caster angle. Less caster = less straight line stability. A soft Tire sidwall exacerbates this issue. A tire with a stiffer sidwall doesnt "Fix" the problem. It mearly can cover it up. Is a new UCA required? No. BUT, Being as the caster angles are near, or below 1*, Its a good investment.
  14. Jul 6, 2010 at 7:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOl!! Im tired still....so I may not be clear on things :eek: BUT...Comparing a TB spacer, which only makes a whistle, to new UCA's that correct for loss of caster, is an Apple to Orange comparo. In the end, Its all up to the owner of the vehicle. If the wandering, or lack of caster is not a deal, then by all means, keep the OEM UCA's. IF there are wandering issues (And keep in mind, when lifting, you loose down travel which Uniball UCA's can give a little back), then get the UCA's.
  15. Jul 6, 2010 at 7:50 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok. But the OP HAS the wandering. New UCA's are cheaper than buying new tires with stiffer sidewalls. Both still more $$$ than hookers.....
  16. Jul 6, 2010 at 7:53 AM
    betz.steven
    Southern NJ
    2011 TE 4Runner
    X1000 you'll forget all about the wandering, promise.
  17. Jul 6, 2010 at 8:15 AM
    floridaoccifer
    WOW, thread jacking 101...
    LOL,
    Anywho... Just got back and I asked for the 0-0-2.4
    The tech said the best he could do was:
    Left Camber: 0.7
    Right Camber: 0.6
    Caster Left: 1.8
    Caster Right: 1.8
    He also noted that my Pirelli's are "E" rated and should be running at a HIGH pressure?
  18. Jul 6, 2010 at 8:19 AM
    floridaoccifer
    E Rating = 80PSI Max :eek:
  19. Sep 3, 2010 at 9:36 PM
    whitaco
    whitaco Active Member
    Thomas
    Northern, New Mexico
    01 TRD white with a touch of badass.
    K&N cold air, Harris throttle body spacer, westin bull bar, chrome mirrors, rainguards, bugflector, 20% tint. Borla cat back, weathertec, ome complete lift with dakar leaf packs, light racing UCA's and a toytec add an inch shackle, 33x12.5 15 BFG KM2's. Procomp 15x10's with 3.75" backspacing, carpet dash cover, tint visor, PIAA off road lights, aftermarket tail and headlights, smittybuilt nerf bars stainless
    You have probably fixed it by now but in case you haven't I will be installing theses bushing kits to see if they help at all. But I need a new powersteering rack first so it may be a while. This could be a cheap fix for these issues. :confused:
