Highway Speed for 4 Cyl 5-Speed Manual 4WD?
Discussion in '4 Cylinder' started by jcman01, Jun 9, 2013.
  1. Sep 16, 2013 at 11:16 PM
    #41
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Thanks for the useful info, wads. :)
  2. Sep 17, 2013 at 4:10 PM
    #42
    2007 tacoma
    2007 tacoma Well-Known Member
    LEEEEEEROOOYYY JENKINS!
    2007 Access Cab
    16" Alloys, K&N intake, Class III Hitch, US Truck Cap Rack, Carpeted Bed Mat, WeatherTechs, SeatSaver covers, Many more in the works
    There's a difference among each of the 4x2's. Prerunner is the same as the 4x4. 5 lug 4AT = .705 * 3.583 = 2.53
    5 lug 5MT = .805 * 3.307 = 2.66
    Prerunner = .805 * 4.100 = 3.3
    4X4 = Same as Prerunner
  3. Sep 17, 2013 at 5:11 PM
    #43
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    FTFY
  4. Sep 17, 2013 at 5:51 PM
    #44
    Petrol
    Petrol Well-Known Member
    Central Va.
    Tacoma
    That 4 cylinder is way tougher that most people know. Keep clean oil in it, drive it like you have just a little bit of sense and it will out last the truck.
  5. Sep 17, 2013 at 7:47 PM
    #45
    2007 tacoma
    2007 Access Cab
    Thanks. I didn't realize that in 2011 they converted the I4 Prerunner from being 5MT only to 4AT only.
    http://pressroom.toyota.com/article_display.cfm?article_id=2678
    Edit: This PDF also shows an obvious typo from someone in the prior one. Displacement is 2694 cc, not 2964 cc. Torque is also 180, not 280 for the I4. At least the gear ratios seem correct. That's all I looked at previously.
    The actual official 2009 specifications are available here:
    http://pressroom.toyota.com/article_display.cfm?article_id=2583
  6. Sep 20, 2013 at 7:55 PM
    #46
    mrbadwrench
    mrbadwrench Well-Known Member
    Cleveland Ohio area
    2014 GMC Sierra 4x4, 1988 Mitsubishi J53
    I have found that 70-75 mph is the MPG/power "sweet spot" for the 2.7 liter 5 speed 4x4. Best combination of power and economy. You're both right, it really loves to cruise at just under 3k rpm.
    My 4x4 usually gets me a steady 24 mpg at that speed. To get better steady mpg, I have to drop down to about 60 mph or less, at which point I can see upwards of 26 mpg but I have to downshift more on hills because I'm out of the powerband in 5th gear.
  7. Sep 20, 2013 at 10:50 PM
    #47
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    Sweet spot for 1st gen 2.7 5 speed is 45-55
