HiLift Jack Preservation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RearViewMirror, Sep 3, 2015.
  1. Sep 3, 2015 at 7:18 AM
    RearViewMirror
    RearViewMirror [OP] Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    I've mounted my HiLift Jack on the bars on the back of my truck. It will be exposed to the elements all the time. Does anyone have any recommendations on keeping it in good operating condition and what to put on it to keep it from rusting? I'm sure there is something out there to coat the jack but I'm unaware of where to look. Any suggestions would be welcome.
  2. Sep 3, 2015 at 7:47 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    I've had my jack since '81 - and its been outside and working ever since. Its been hanging on a Blazer, F-150, Cherokee, Dodge SLT and now the Taco. I just wash the mud off (after it gets in the mud) and squirt motor oil on the working parts. Those years haven't been on salted roads tho.
    I believe the operative words are WORK - and LUBRICATE. The mechanism can't just be left to solidify, it wasn't meant to be an ornament. Mine has pulled up plenty of fence posts and run a lot of fire roads.
    Nice truck - I happen to like the white 4 dr variety............
  3. Sep 3, 2015 at 7:49 AM
    Pigpen
    Dan
    Northwest Montana
    Keep it lubed, per Hi Lift instructions and touch up chips and dings with some red paint. Mine's in my topper, so it stays beat up...
  4. Sep 3, 2015 at 7:50 AM
    RearViewMirror
    Craig Christ
    Yeah, I've been taking it off each time I wash the truck and run it through the cycle. I've been keeping all the moving parts lubed. Just curious about the rust and how to prevent it.
  5. Sep 3, 2015 at 7:52 AM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    i bought one off craigslist that was the rustiest i had ever seen, 10 bucks, sanded it all down to bare metal, painted it, installed new hardware and then mounted it in the truck. No rust as long as u cover up the nicks and keep it lubed like other have said.
  6. Sep 3, 2015 at 7:56 AM
    AKSig88
    AKSig88 Well-Known Member
    Ann Arbor, MI
    2023 SR5 Tundra
    I have the same setup and was looking for Hi-Lift and quick fists to put on there, what size Hi-Lift and where do you get the quick fist mounts?
  7. Sep 3, 2015 at 8:00 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    I wipe it down and get all the dirt/mud off it. And then hit it with tri-flow about once a month. There's a little surface rust on some areas where it's used. But apart from that, I've had no issues with parts sticking.
  8. Sep 3, 2015 at 8:32 AM
    RearViewMirror
    Craig Christ
    48" HiLift and got the quick fists off of Amazon
    AKSig88[QUOTED] likes this.
  9. Sep 3, 2015 at 12:55 PM
    Jetty Rat
    Jetty Rat Well-Known Member
    South Texas
    2006 Tacoma Prerunner SR5 TRD Offroad
  10. Sep 3, 2015 at 2:25 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    I've had mine since around '88 and as others have said, keep it lubed and touch up the paint as needed. When it stayed on my Land Cruiser I usually had it in one of the black Hi-Lift storage bags; I think I've been through like three of them over the years. Looking at their website they offer a neoprene mechanism cover and what I'm guessing is a newer version of what I have.
    http://www.hi-lift.com/accessories/jack-protector.html
  11. Sep 3, 2015 at 4:15 PM
    RearViewMirror
    Craig Christ
    That's what I was looking for. Thanks for the link. I didn't really want to use regular WD40. That seems like it might last a little longer.
    I'd like to have one of those bags but the way it's mounted on my rack I don't think it would work.
