Hilux RC60F Transmission swap
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jowett, Sep 12, 2019.
  1. Nov 23, 2022 at 10:07 AM
    #161
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    You’re a madman. I love it.
    Junkhead and CygnusX191 like this.
  2. Nov 23, 2022 at 10:11 AM
    #162
    BLtheP
    BLtheP Not a Member
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    5.29 Gears, FJ Pedal, 265/75R16 Toyo ATIII
    Good to know on the shifter part.
    as for buying the transmission, it’s listed straight on the Toyota parts site and all the other dealer sites. None of them mention needing a vin. On parts I needed a vin, they said so in the listing. I’m not buying yet but in a few months I might. If I do, we’ll see what happens.
    I’d rather the RC61F over the RC60F, so it works out if I’m able to get that one locally.
    CygnusX191 likes this.
  3. Nov 23, 2022 at 10:33 AM
    #163
    gtrotter07
    gtrotter07 Well-Known Member
    2007 Tacoma reg cab 4x4 on 37's; 2021 TRD Offroad, 6 speed
    37's,lockers, bumpers, bobbed etc.
    Has anyone swapped the RC60F to a 2tr-fe a-l-a 2nd gen regular cab?
  4. Nov 23, 2022 at 11:10 AM
    #164
    Jowett
    Jowett [OP] Well-Known Member
    Brian
    North Adams, MA
    The RC60/61 transmissions are Hilux parts, non-USA. Toyota stocks them here for some reason… being a non USA model, they more often than not want proof that the part they will be selling you is for a vehicle that is legally in the country.
  5. Nov 23, 2022 at 12:54 PM
    #165
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    For warranty work 100%
    For everything else.... :popcorn: (but yes, probably)
  6. Nov 23, 2022 at 8:17 PM
    #166
    Jowett
    Brian
    North Adams, MA
    The RA and RC were never offered behind the 2TR, so a bit of research and probably an adapter of some sort will be required to make that work.
  7. Nov 23, 2022 at 9:50 PM
    #167
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    The RC60/61 parts are in the Toyota USA system because they are used in Mexico/other markets serviced through distribution centers in the US. The parts may or may not be orderable from a US dealer. Frequently not, regardless of whether you can see it listed/priced on a US dealer website.
    Wait and see.
    Jeff
  8. Nov 24, 2022 at 5:04 AM
    #168
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Confirm from our parts manager, if you want to order one of those transmissions you will need to provide a VIN.
  9. Nov 24, 2022 at 7:08 AM
    #169
    BLtheP
    BLtheP Not a Member
    Plano, TX
    Well, at some point I’ll likely try anyways and I’ll probably try to find a 1GD 2.8L truck for sale overseas whose VIN I can borrow. If they request more info than that like proof of registration, then I tried and will drop it. Some of the parts sites that require VINs don’t even seem to uphold that requirement, so we’ll see. If I try one and it cancels, I’ll try one or two more, worst case I won’t get anywhere.
    I don’t hate the stock transmission, just wish it was better suited to the 5.29 regear I’m doing. But, 5.29s and stock trans will suit me better than 4.30 and stock trans do. It will be a very good combo other than cruising relatively high in 6th.
  10. Nov 24, 2022 at 7:17 AM
    #170
    Mojlnir
    Mojlnir Well-Known Member
    Parker, CO
    2018 SR ACLB Utility Pkg
    Looked around on Toyota.MX and didn't find any VINs listed - but that doesn't mean they aren't available.
    Another source might be Toyota-gib.com.
    BLtheP and CygnusX191 like this.
  11. Nov 24, 2022 at 7:18 AM
    #171
    daveeasa
    daveeasa FBC Harness Solutions Vendor
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    So, granted a completely different engine, buuut, my only real experience with cruising at higher than stock RPM during my drive earlier this week to bring my Tundra home.
    75 ish to 80 ish hovered at 2500 rpm
    I was nervous but fuel economy was fine and so was heat. It reallly wasn’t any sort of problem at all.
    My only real concern after an extended drive post regear is the punch when shifting. It’s more pronounced. But that’s an AT so nothing I can do and doesn’t apply to MT.
    now I’m more seriously considering doing a regear plus locker in the ‘05.
  12. Nov 24, 2022 at 7:39 AM
    #172
    BLtheP
    BLtheP Not a Member
    Plano, TX
    I have not found that raising the rpm due to a regear negatively affects fuel economy very much unless you gear super drastically and you drive fast, 80+. Hell, I drove to work at 72 mph one day in 4th gear just to see how it would do and over 35 miles, I got right at 15 mpg at 3500 rpm. That’s barely worse than I get already in 6th (17ish) and that’s with a difference of 1100 rpm.
    as for punching it, it should be immediately more responsive, but the auto may cover that up by shifting at a different time or you may not feel the effect due to the torque converter. With a manual, you absolutely will feel the difference instantly because there’s nowhere for it to hide in that direct driveline connection.
    4.88 would be sweet in that 2.7L. Do you need a locker? You may be better off with a TrueTrac LSD, a locker is more for tough offroad like crawling and such which you won’t be doing in a 2WD I presume. A TT may fit the pre runner theme better and may benefit you more often.
    edit: misread the punch comment. Yes, nothing you can do about that in an auto but of course won’t apply to a manual.
  13. Nov 24, 2022 at 7:45 AM
    #173
    daveeasa
    David
    PNW
    Definitely considering another LSD. I went with nitro (same as truetrac?) in the '02 Tundra b/c I wanted it built to "never break" rather than "go anywhere nimbly". The '05, with it's super short wheelbase and light weight, might be a fun candidate for a locker just in case it did get stuck somewhere.
    Since it's starting at 4.30, going to 4.56 doesn't seem like a good way to burn cash so 4.88 might be the ticket, plus maybe a little bigger on tires. But then it's less street friendly which is really the primary purpose. Nice to have one rig which rides at stock height. Could still do the gears and stay on 245/75R16 though, no rule against that.
  14. Nov 24, 2022 at 7:50 AM
    #174
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    4.88 on 31 or 32 would be absolute blast while still retaining street ability
    daveeasa[QUOTED] likes this.
  15. Nov 24, 2022 at 8:00 AM
    #175
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I thought 4 cylinder second gens were 4.10. The third gen manuals are 4.30.
  16. Nov 24, 2022 at 8:18 AM
    #176
    daveeasa
    David
    PNW
    Well, f me, am I wrong on my factory gears? I’m 4.10?
    I’ll check the door sticker next chance I get. For some reason I remember a vin check showing 4.30
    Ah, found the doc. 8.4” and 4.10 so maybe that’s why I was thinking 4.56 and Eaton.
    Anyway, enough thread pollution, let’s get back to hilux trans and 3rd Gen :)
  17. Nov 24, 2022 at 8:29 AM
    #177
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  18. Nov 27, 2023 at 7:35 PM
    #178
    BLtheP
    BLtheP Not a Member
    Plano, TX
    Welp. With the Black Friday sale, I placed an order for an RC61F from a dealer, 33030-0KE40. $1500 off. Let’s see if it gets canceled or not. Fingers crossed, though I won’t be surprised at all if it’s canceled.
    Not excited about the prospect of immediate disassembly and reassembly but considering I can get the job done without any disassembly of my current truck, that makes it a lot less stressful. If I have to I’ll take it to a shop. But courtesy of @Jowett, I have a lot of good documentation to follow for the work.
    This thing would be an absolute beast with 5.29s and this transmission!
  19. Nov 28, 2023 at 11:29 AM
    #179
    BLtheP
    BLtheP Not a Member
    Plano, TX
    Figure I should post here. I've been following the 4th gen as I am super curious about what transmisison it might sport. My hunch has been from day 1 that it will be either the RC60F or RC61F, or something very close. Maybe it's a new transmission they came up with instead, I really don't know. Sheldon Brown said something along the lines of the transmission is very similar to 3rd gen, but the ratios were a bit tweaked. The Hilux transmissions fit that description pretty well, so that's where my guessing came from.
    Anyways, I've had this hunch but no proof. Now TFL came out with their driving impressions, and he spilled the beans that the 1st gear is 4.78:1, and the axle ratio is 4.30:1. Both Hilux transmissions have the same 4.78 1st gear. Even more reason to believe it's one of the two previously mentioned transmisisons, although it could also be a new creation that happens to use the same 1st gear I guess..
    I don't know how likely it is but I am hopeful that maybe this transmission can somehow have the correct input shaft spline/length for the 2GR and could possibly work to be a swap for the 3rd gen to get the same or similar ratios to the RC60F or RC61F. Worst case, it won't bolt up but could at least be a domestically sourced transmission as opposed to buying one of the foreign Mexican or Asian Hilux transmissions. Time will tell! I'm still searching for documentation constantly.
    I did place the RC61F order last night like I said, I don't have much hope that it will actually go through which is why I'm still so interested to see what the 4th gen brings.
  20. Nov 28, 2023 at 12:36 PM
    #180
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Good info. I am curious about this swap too. It would really help tow my new to me travel trailer. I have been looking at the used market for a donor. If I knew a word of Spanish, I might even try finding one in Mexico.
    Bumping for updates.
    CygnusX191 and BLtheP like this.
