Hissing Engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FrostyEldin, Oct 18, 2016.
  1. Oct 18, 2016 at 3:25 PM
    FrostyEldin
    FrostyEldin [OP] Well-Known Member
    Austin
    Lewiston, ID
    2008 SR5 Impulse Red
    Whenever my truck is running there is a hissing noise. Sounds near the water pump/fan area so that's what I'm thinking it is. Taking it into Toyota saturday for them to diagnose the problem and from there I will be doing it all myself. I can take a video if that helps and post it but I would like some feedback for suggestions. It has 107,800 miles on it and I picked it up with 90k in december. Wasn't doing it until 104kmiles.
  2. Oct 18, 2016 at 3:31 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Have you noticed any loss in coolant?
  3. Oct 18, 2016 at 3:37 PM
    FrostyEldin
    Austin
    Lewiston, ID
    I have not seen any leaks anywhere. I will check reservoir next time i go outside
  4. Oct 18, 2016 at 3:39 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Is the AC on at the time? Maybe the drain line is dripping on the exhaust.
  5. Oct 18, 2016 at 3:40 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    "hissing noise" makes me think of a vacuum leak, have you checked all the hoses for cracks or loose connections?
    Torspd, wilcam47 and bluezzy like this.
  6. Oct 18, 2016 at 3:40 PM
    FrostyEldin
    Austin
    Lewiston, ID
    I rarely use my A/C. It does it everytime my engine is on even if the air is off
  7. Oct 18, 2016 at 3:42 PM
    FrostyEldin
    Austin
    Lewiston, ID
    I will go and take a video, someone explain how to post videos while i do this :)
  8. Oct 18, 2016 at 3:43 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Make sure the defrost is off too.
  9. Oct 18, 2016 at 3:43 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Post to youtube and then add the link.
  10. Oct 18, 2016 at 3:55 PM
    FrostyEldin
    Austin
    Lewiston, ID
  11. Oct 18, 2016 at 4:13 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    idler Pullies?
  12. Oct 18, 2016 at 4:15 PM
    FrostyEldin
    Austin
    Lewiston, ID
    I have 1 and got that changed already. Guy at toyota said it was the worse one he's seen. The bearing was so bad!
  13. Oct 18, 2016 at 4:19 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    I feel like they always say that
    outlawtacoma, wilcam47 and 3rYODA like this.
  14. Oct 18, 2016 at 6:32 PM
    FrostyEldin
    Austin
    Lewiston, ID
    He showed it to me afterwards and oh man... It sounded rough
  15. Oct 31, 2016 at 9:15 AM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    So. . . Did it end up being the pulley?
  16. Oct 31, 2016 at 9:25 AM
    FrostyEldin
    Austin
    Lewiston, ID
    They said it was the alternator and an idler pulley. About to order them tomorrow.
  17. Oct 31, 2016 at 9:38 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Cool. I'm about to pick up an idler pulley. Got that same noise. Parts place said there was a upper and lower. . . . Which one are you replacing ? I'm thinking of just doing both.
  18. Oct 31, 2016 at 9:39 AM
    FrostyEldin
    Austin
    Lewiston, ID
    I've gotten my lower replaced a few months ago so I'm doing upper and alternator. Now I got to find a pulley puller!
  19. Oct 31, 2016 at 9:43 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Only one?? You should replace them all at the same time.. They have the same amount of wear.
  20. Oct 31, 2016 at 9:44 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Good to know. Guess I'll borrow one from the parts place. Thanks for the info
