Hissing noise when cruising.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03taco, Mar 19, 2019.
  1. Mar 19, 2019 at 9:01 AM
    03taco
    03taco [OP] Well-Known Member
    Alex
    2004 Taco
    Never Ending Project
    Hello,
    I recently started to have a hissing noise on my 2003 taco. The noise is only there when u are cruising and not when accelerating.
  2. Mar 19, 2019 at 10:41 AM
    03taco
    Alex
    2004 Taco
    What do u mean???
  3. Mar 19, 2019 at 10:45 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    It's more than likely always there, you just don't hear it when the loud pedal is depressed. Hissing sounds like a vacuum leak maybe
    Can you tell where the noise is coming from? front? back?
    There are these microphone things you can get, where you can (help) diagnose where a noise is coming from. There are kits that come with multiple microphones and it records the noise levels. Or a poor man's version with just a single microphone, you just have to move it around more.
    Also, apparently, there's an app for that:
    https://www.smithsonianmag.com/innovation/app-can-diagnose-your-car-trouble-180967412/
  4. Mar 19, 2019 at 10:54 AM
    03taco
    Alex
    2004 Taco
    There is no hissing noise at just idle only when cruising.
    Running Board Man likes this.
  5. Mar 19, 2019 at 10:36 PM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    Is it by the glove box area? If so, the intake tube extension is right in the passenger fender and that is where you are probably getting the hissing sound from, It is like that on my Taco.
  6. Mar 19, 2019 at 10:58 PM
    03taco
    Alex
    2004 Taco
    i will check it out
    homegrown_xt[QUOTED] likes this.
  7. Mar 20, 2019 at 5:32 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Starting fluid is your best friend for finding vacuum leaks in the engine compartment. Since all air entering your intake SHOULD be going through the air cleaner, anything from another source represents a leak.
    Just spray 1-2 second bursts at the motor (esp top end near vac lines of course) from all different angles. When the spray is picked up by the leak, the RPMs will increase momentarily. I have found a lot of leaks that way.
    wilcam47 and Running Board Man like this.
  8. Mar 20, 2019 at 8:55 AM
    03taco
    Alex
    2004 Taco
    I will give it a try
  9. Mar 20, 2019 at 9:24 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    check your air intake hose for cracks...
  10. Mar 20, 2019 at 9:37 AM
    03taco
    Alex
    2004 Taco
    I have no hissing at idle at all. Only when I drive
  11. Mar 20, 2019 at 10:27 AM
    03taco
    Alex
    2004 Taco
    Alright I will take a look at it
