Hissing noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Canadianguy91, Feb 7, 2019.
  1. Feb 7, 2019 at 4:07 AM
    Canadianguy91
    Canadianguy91 [OP] Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    so yesterday I had the heat in and it was making a pure hissing noise. Sounds coming from the passenger side. This morning I heard it but the hissing wasn’t as loud. It only sounds when the heat is on.
    Any suggestions?
  2. Feb 7, 2019 at 4:13 AM
    deadpocketss
    deadpocketss Dingus
    Ian
    Colorado Springs, Colorado
    '24 Subaru Crosstrek Premium
    Low freon/leak?
    Evap core jacked up?
    To clarify, if it's worse than freon going through the evap core normally. Then, it's probably something above.
  3. Feb 7, 2019 at 4:14 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    It’s just the Freon passing through the evaporator core. If t keeps doing it then you might have a leak
    MrBrooks likes this.
  4. Feb 7, 2019 at 4:20 AM
    MoneyMan55
    MoneyMan55 Licensed Master Electrician
    Doug
    South Central PA
    2017 DCSB SR5 Blazing Blue Pearl
    Beans for supper?
  5. Feb 7, 2019 at 4:24 AM
    Clearwater Bill
    Billy
    Largo Florida
    When the heat is on the AC still runs, but at a low 'demand' to help with defogging the windshield.
    My guess is you are hearing the expansion valve (attached to the evap) doing it's thing.
    Turn the radio up a click or two. ;)
    su.b.rat, shakerhood and wahoobie like this.
  6. Feb 7, 2019 at 5:10 AM
    basshole
    basshole Well-Known Member
    chicagoland
    2018 OR MT
    Check that cabin filter. Could be leaf litter rubbing on the blower cage.
  7. Feb 7, 2019 at 5:31 AM
    Canadianguy91
    Sean
    2016 Limited
    I only thought Freon was form ac but ok ya that makes sense if it runs also when there is heat.
    And ya I’ll look at the cabin air filter too. I try not to tough anything plastic when it’s -10 Celsius out
  8. Feb 7, 2019 at 6:20 AM
    basshole
    chicagoland
    2018 OR MT
    Once warming up the interior you should be fine getting to the cabin air.
    But, good point! The great north... Don't pull plastics when below freezing!
  9. Feb 8, 2019 at 5:20 AM
    Canadianguy91
    Sean
    2016 Limited
    I took a look at the filter yesterday. Things gota be switched out lol it’s done it’s job. There were 2 small leaves in there so I shook it out and haven’t heard that noise since.
    This morning driving I put my hand on the vent for the feet and thought it didn’t put out much. A new filter should fix that no?
    TeecoTaco likes this.
  10. Feb 8, 2019 at 11:24 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My truck makes that Darth Vader Exhaling sound every now and again, I always assumed it was the expansion valve.
  11. Feb 8, 2019 at 11:26 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    buddy that's spring weather.
  12. Feb 8, 2019 at 4:31 PM
    basshole
    chicagoland
    2018 OR MT
    I had a hunch.. So many times I've had customers with the same complaint. Leaves rubbing the blower cage.
  13. Feb 8, 2019 at 4:45 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I knew the 2017’s were, but are the 2016’s under the squirrel cage blower recall too?
    tcjacado and shakerhood like this.
  14. Feb 9, 2019 at 7:24 AM
    Canadianguy91
    Sean
    2016 Limited
    Thanks man that’s another thing off my shoulders lol. Is it common for them to be wet?
    I have no idea. What’s the recall for?
  15. Feb 9, 2019 at 8:32 AM
    shakerhood
    Southern Ohio
    I think 2016s are on the list too but I think the recall applies only to fans of manual climate controls Tacomas, not ones with automatic climate control.
  16. Feb 9, 2019 at 6:13 PM
    OnHartung'sRoad
    Sounds like the recall is not in your case, but it was to replace a defective squirrel cage blower fan that cracks on the motor shaft and makes noises before failing completely.
    shakerhood likes this.
  17. Feb 9, 2019 at 10:22 PM
    Canadianguy91
    Sean
    2016 Limited
    Gotcha well thanks for the info anyway!
