Hissing sound from transmission (only when moving)
Discussion in '1st Gen. Tacomas (1995-2004)' started by anewman9, Nov 20, 2019.
  1. Nov 20, 2019 at 2:24 PM
    anewman9
    anewman9 [OP] Well-Known Member
    Austin
    ATX
    1997 Tacoma Ext
    ARB Bumpers. Warn Winch Bilstein 3in lift. kargo Master Roof rack. K&N CAI. Mickey Thompson Classic II
    not sure if I described it well.. but I have a sound I hear when moving slower. Sure its there at all speeds but that's the only time I can hear it. Its not a grinding or screeching sound... but more like a his or a steady sound …
    any thoughts?
    97 Tacoma 238k miles
  2. Nov 20, 2019 at 6:35 PM
    rogerman
    rogerman Well-Known Member
    Roger
    HNL 808, SPN 670
    2000 Tacoma SR5 V6 4wd 5speed
    A video will help immensely
  3. Nov 20, 2019 at 6:38 PM
    soggyBottom
    soggyBottom Well-Known Member
  4. Nov 21, 2019 at 10:11 AM
    Glamisman
    Glamisman Well-Known Member
    could be low fluid level in trans, could be power steering whine.
  5. Nov 21, 2019 at 7:10 PM
    anewman9
    Austin
    ATX
    1997 Tacoma Ext
    Alright.. gonna drain and refuel the fluids on the tranny and transfer... any new hotness on fluids that people run on those boxes?
  6. Nov 21, 2019 at 7:38 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Automatic or manual?
  7. Nov 22, 2019 at 4:20 AM
    anewman9
    Austin
    ATX
    1997 Tacoma Ext
    Auto
  8. Nov 22, 2019 at 7:37 PM
    JDouma82
    JDouma82 Active Member
    Justin
    04 black Double Cab Trd
    Bilstein 5100s w/ Eibach 3”springs Old Man Emu Dakar’s w/ Amal 33x12.50 Bfg Muds on Steelies 4.56 gears
    You hear the noise only when in drive?Does it shift normal? Is it more of a whining type noise like a low on fluid power steering pump?
  9. Nov 22, 2019 at 7:39 PM
    anewman9
    Austin
    ATX
    1997 Tacoma Ext
    Only in gear. And yes , very similar
  10. Nov 22, 2019 at 7:45 PM
    JDouma82
    Justin
    It sounds like what I just went through. I had a whining noise only in gear. Trans shifted normal. I went with my gut and replaced the torque converter. Noise went away. I wouldn’t let it go too long if you plan to keep the truck.
    underaroof likes this.
  11. Nov 23, 2019 at 12:13 PM
    anewman9
    Austin
    ATX
    1997 Tacoma Ext
    Cost of that repair?
  12. Nov 23, 2019 at 12:15 PM
    JDouma82
    Justin
    I did it myself, replaced the torque converter, front pump seal and rear main seal. I used a Transtar recon torque converter. I spent about $200.00
