Hissing Sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by itsmagenta, Feb 29, 2024.
  1. Feb 29, 2024 at 6:48 PM
    itsmagenta
    itsmagenta [OP] New Member
    Bill
    2005 Tacoma
    Hi,
    New member here.
    I have a 2005 Tacoma, 4 cyl with 325,000+ miles. Been running great. Stopped by my mechanic today and he has 40+ vehicles in his lot, so kind of backed up.
    In the last couple of weeks, it started behaving a little odd. If I kick it up to 3k-4k RPM, like to get up a steep hill, it makes a noise like it's either sucking or blowing air. No combustion sounds just a really loud hiss. Also, either my imagination or it seems to have less power when this happens.
    I've had some issues lately that have kept me from getting too deep into checking it out. I did check the air intake systems and don't see any loose or broken connections there.
    I tried to check it out in the driveway but the noise does not happen when the truck is in park and at least 4k RPM.
    Any ideas from that description?
    Thanks
  2. Feb 29, 2024 at 6:52 PM
    Bishop84
    Bishop84 Well-Known Member
    Could be a pin hole leak in the exhaust caused by a small amount of rust, or when loaded exhaust can be escaping past a gasket, they are material and leak over time.
    Because its only under load its likely not a huge deal, but doesnt hurt to get it looked at.
    itsmagenta[OP] likes this.
  3. Feb 29, 2024 at 7:00 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like maybe you have a plugged catyletic converter, an exhaust backpressure test would be needed to verify.
  4. Feb 29, 2024 at 7:15 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Good advice above, sounds like an exhaust leak.
    Oftentimes the exhaust will find a path around a partially clogged converter, and leak out through a gasket or connection. Also, with that many miles the exhaust could be rusty which makes it easier for a leak to develop
    Even without a clogged converter, a small exhaust leak can affect backpressure which can make it feel a little sluggish
    Get under the truck and look for black soot. Also a mechanics stethoscope with the metal tip removed (just the hose) can help locate the source of the sound
  5. Feb 29, 2024 at 7:29 PM
    Cincy Tacoma
    Cincy Tacoma Well-Known Member
    Cincinnati, Ohio
    Welcome to TW.
  6. Mar 1, 2024 at 5:44 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    An easy way to conduct this test requires the use of a shop vac. You plug the hose into the exhaust port on the shop vac and put the other end into the tailpipe. Turn on the vacuum then go around your exhaust with a squirt bottle with a dish soap and water mixture. Make sure you squirt all the connection points but if you have a pinhole, you might hear it when you turn on the vacuum. Follow the bubbles.
    -J
  7. Mar 1, 2024 at 12:56 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Y pipe to manifolds do leak and make it run richer (less MPG too) with less power when mine went
