History of Tacoma rust
Discussion in '1st Gen. Tacomas (1995-2004)' started by irhunter, Dec 17, 2023.
  1. Dec 17, 2023 at 5:49 PM
    irhunter
    irhunter [OP] Well-Known Member
    Maine
    '96 2WD 5-sp 2.4 Tacoma and '03 4WD AT 4.7 Tundra
    I have the impression that frame rust and other under-carriage rust became a much bigger deal at some point.
    Is that right?
    When was the change?
    Roy
  2. Dec 17, 2023 at 5:54 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  3. Dec 17, 2023 at 6:17 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Well it all started in Anatolia circa 1800BC, but really the finger can be pointed at Henry Bessemer, some time around 1855.
    StihlToyota, taco57, SH10151 and 6 others like this.
  4. Dec 17, 2023 at 6:23 PM
    Clearwater Bill
    Billy
    Largo Florida
    Objection your honor, this isn't a fishing expedition
    Sustained. Counsel will redirect to be more specific with questions.
    rocknbil likes this.
  5. Dec 17, 2023 at 6:30 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    DK117 and SH10151 like this.
  6. Dec 18, 2023 at 2:35 AM
    voodoomaster33
    voodoomaster33 VoodooMaster
    Dave
    Asheville NC
    02 Std Cab 5 spd 4WD Mystic Gold
    Lifted a little.........
    rust? what rust...........I ain't go not stinking rust! well.....except on my valve cover flange bolts and that's gonna change pretty soon.
  7. Dec 18, 2023 at 2:46 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    LOL @ these responses . . . .
    To answer the question do a little digging around and look at when the frames went from U frames to box frames. The box frames retain moisture and can rust from the inside out.
  8. Dec 18, 2023 at 5:39 AM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    I dig the obscure references
  9. Dec 18, 2023 at 9:13 AM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    Around 1995 they switched their supplier for the frames. Corners were cut during the milling practice, and the result was internal delamination of the steel when exposed to salty conditions without any protection i.e. fluid film etc.
    Canadian Caber likes this.
  10. Dec 19, 2023 at 3:59 PM
    jabberjawmash
    jabberjawmash Well-Known Member
    Jackerz
    95Tacoma
    That’s why you always got to keep a extra frame on deck for when ya need it!
  11. Dec 20, 2023 at 7:22 AM
    MT-98
    MT-98 Well-Known Member
    Montana
    98 Tacoma
    Sorta Stock
    Or be lucky in where you live. I've had a guy at a drive-through window ask me about my frame. Like in some circles, people associate these trucks with terrible frame rot and breaking in half. Which is, of course, valid...Except out here it's nonexistent. My 98 has a little surface rust on the frame, completey superficial. There are thousands of these first gen Tacomas out here, with no rust. But farther east...most of them have gone to the crusher because of rust. A shame. All those spare parts off the market.
    Xbeaus likes this.
  12. Dec 20, 2023 at 7:24 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Well they stopped crushing the rusty ones after 2000, then started replacing frames.
  13. Dec 20, 2023 at 7:25 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    My 98 has an immaculate frame and I am in the midwest. Spent its life in Wyoming and now in South Dakota. They mag water and salt the road. Previous owner either had the frame replaced or was very diligent about frame protection. I have done the same thing and inspect, clean, fluid film it every year. Good way to check all the other bolts and hardware under there too.
    taco57 and Ozark_RegCab like this.
  14. Dec 20, 2023 at 7:52 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    The thing is, it's really not that hard to protect the frame from corrosion, even in the heart of the rust belt. Coating it inside and out with fluid film takes about an hour with a spray gun and 360 degree wand, and there's tons of places that'll treat the whole undercarriage for like 100 bucks.
    taco57 and Xbeaus like this.
  15. Dec 20, 2023 at 1:54 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    Same here in Oregon. We don't salt the roads and my truck has been here since new so the frame looks great.
  16. Dec 20, 2023 at 2:03 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    The Frames are multiple over lapping pieces that build moisture and rust in between the layers, that and a faulty coating. I believe the frames were made in the US by Dyna Corp.
    Check out the new Tundra frames. They do not have over lapping layers, and the high strength steel is electric welded to the standard steel, not over lapped, and the frames have a wax coating inside, and tons of drain holes on the bottom of the frame.
    Something says Toyota is trying to get away from the bad frame stigma.
    Ozark_RegCab likes this.
  17. Dec 20, 2023 at 9:58 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
