History tells me ... eh, no comment.
Discussion in 'Stocks & Investments' started by kairo, Oct 6, 2020.
  1. May 13, 2021 at 12:44 PM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Go for the gusto...
  2. May 13, 2021 at 12:46 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    GME is up, ASO is up... but my fishing stuff got delayed till tomorrow
    kairo[OP], Fohu and Nimble9 like this.
  3. May 13, 2021 at 12:49 PM
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    cancel the order and see what happens tomorrow?
  4. May 13, 2021 at 12:52 PM
    5nahalf
    Erik
    Minnesota
    And risk not getting my rapalas? no way, I ordered 14 of them with a nice 25% discount.
  5. May 13, 2021 at 1:05 PM
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    Well, not a bad day. :cheers:
  6. May 13, 2021 at 1:10 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Woah and rapalas don’t come cheap. Where you buying them with that discount?
    I get fishing tips and stock advice in this thread. Don’t catch jack squat and losing my azz.
    Fohu, TreeFortRichard and 98tacoma27 like this.
  7. May 13, 2021 at 1:12 PM
    moto.mike
    moto.mike Well-Known Member
    take a guess...
    Oakland
    2004 Xtra Cab 4x4 TRD SR5
    nice title change
    :cheers:
    TreeFortRichard and davidstacoma like this.
  8. May 13, 2021 at 1:12 PM
    5nahalf
    Erik
    Minnesota
    Dicks sporting goods is running a buy 1 get one 50% sale on rapalas. Its limited to 6, but thats 6 of each style. This is what I got (one is missing from this list as it was not instock when I ordered)
  9. May 13, 2021 at 1:13 PM
    davidstacoma
    David
    NC
    Thanks!
  10. May 13, 2021 at 1:15 PM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    I love the freedom to put my own system in..
    I dislike the overwhelming integration without there being a really top end system available...
    I have a decent albeit small upgrade on my 2010 because I wanted everything hidden. The KTU-445U Powerpack Amp hidden in the dash. It's 100W bridged to 2 speakers up front only (Access cab)...crossovers in the kick plates...Custom satellite mounts made from plastic cutting boards and Polk MM6501's all custom wired...
    Love it...
    kairo[QUOTED][OP] likes this.
  11. May 13, 2021 at 1:15 PM
    TreeFortRichard
    Brian
    I'd use 15Lb test if their all going on the same line at once...
  12. May 13, 2021 at 1:16 PM
    TreeFortRichard
    Brian
    Alright...$GME might do some after hours partying today...Closed red but then said hey there...
  13. May 13, 2021 at 1:18 PM
    TreeFortRichard
    Brian
    OOOH!!! Men can finally win the argument...
    "SEE!!! I told you YOU clogged it with your tampon...."
  14. May 13, 2021 at 1:18 PM
    5nahalf
    Erik
    Minnesota
    I got a big spool of 60lb flourocarbon line :) That should handle them all pretty good... though I think the DNR might just shoot me on the spot since MN limits you to 1 hook per line (multiple hooks on the same lure though) and 1 rod for lakes, 2 for rivers.
  15. May 13, 2021 at 1:19 PM
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    So many q-tips... why do ladies always flush insane shit that makes no sense?
    Also had a girlfriend use my shop vac on her car and the next day it had zero suction. Remove the hose to see why it's straining so hard, and... I shit you not there was a hairspray can and fist full of markers jammed where the hose met the vac body because the hairspray couldn't make it inside the bin and blocked everything else... :goingcrazy:
    Edit: good rule of thumb is if it's big enough to juggle, pick it up instead of vaccuming it.
  16. May 13, 2021 at 1:20 PM
    5nahalf
    Erik
    Minnesota
    My wife used to dump potting soil and gravel down the kitchen sink. I only found out when I replaced the broken disposal and found rocks and dirt in it.
  17. May 13, 2021 at 1:20 PM
    TreeFortRichard
    Brian
    at least break them into pieces if you insist on flushing them...
  18. May 13, 2021 at 1:20 PM
    TreeFortRichard
    Brian
    Oh my...that's fantastic.
    5nahalf[QUOTED] likes this.
  19. May 13, 2021 at 1:22 PM
    Iwilltaco
    Under development
    1 rod for lakes? 1 in the water I assume?
  20. May 13, 2021 at 1:23 PM
    5nahalf
    Erik
    Minnesota
    Whats even better, after I replaced the unit, she did it again. I had to remove the thing and hose it all out.
    Then shortly after I got in the hospital she had dumped a bunch of spaghetti down there... it clogged the drain all the way down about 20 feet past the clean out. I had to snake it while my legs didnt work. (BTW, water was backed up to the sink, and the cleanout is in the basement, so rancid water went everywhere as it had been sitting for 5 days while I was in the hospital)
