Hit and run. Looks like I'm going to be shopping for a rear bumper. FML
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SpeedoJosh, Oct 30, 2016.
  1. Oct 30, 2016 at 8:42 PM
    SpeedoJosh
    SpeedoJosh [OP] Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    Welp, I stopped at a place to grab a quick bite to eat today. When I left I heard what sounded like rubbing. Pulled over and it looks like someone decided to smash the back end of my truck and leave. The mud flap was rubbing on the tire and luckily I was able to bend it back and drive back. No cameras and pretty much I'm SOL. I deploy in two weeks so any repairs will have to wait until I get back. Hate the thought of leaving it like this, but life happens I guess.
    The rear quarter looks toast though. I remember seeing some rear bumpers that have an extended piece that goes to the fender flairs. Anyone have a name on those? Any recommendations would be appreciated. Trying to figure out the best way to tackle this so I end up with a decent looking truck again.
    Thanks
    -Josh
  2. Oct 30, 2016 at 8:58 PM
    Pigpen
    Dan
    Northwest Montana
    With a high clearance off road bumper, you'll cut all that shit off anyway.
  3. Oct 30, 2016 at 10:58 PM
    natas1321
    natas1321 mischief monkey
    natas
    san antonio
    1990 Honda NC30 stock for now
    that sucks, sorry to see that. There are several different styles of rear bumpers out there that you can look over while you are deployed and depending on how much you want to spend you can probably keep the rear panel and repair it to look decent again without having to replace it.
  4. Oct 30, 2016 at 11:16 PM
    tx novice
    tx novice Foward momentum
    Ron
    OAHU
    11 DC 4X4 TX PRO silver
    Trd, Cal Tech, Weather tech, Viper, Al's tinting . L.E.D's , Hide a Hitch or Chrome Stinger , Walker Evans Resi's w/AllPro 3" lift ,FLM, ProComp Xtreme MT2 , Diff Breather Mod, 4x4 Switch Light mod, Plastic Derped. Trailer Socket Relocate mod via Miles , 4:56 G2 gears. Blue Intake Spacer, S.S. Brake Lines F&R, Sway Bar Deleted, Roll-X, Pop-N-Lock Electric. Red metal TRD badges. Paid Off Mod- Chee Hu, Superbumbs(f),Timbrens(r).Pelfrey Bilt, Bamf, Urd. Cobra Heat Shield.CMC .Mishimoto (custom bracket by Nate), Powerstop, Rampage 50".Depo Taillights,SPPC Black Headlights, Rigid Industries. Factor 55.American AirFlow.
    Yes a High Clearance Rear Bumper. Maybe paintless dent repair the higher section
    THROTTLE231 likes this.
  5. Oct 31, 2016 at 5:25 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Man, people suck
    Biscuits likes this.
  6. Oct 31, 2016 at 5:39 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I say go with a high clearance bumper as well. You may have to straighten out the very bottom of the bedside after its cut as the area that remains is just above the bottom of the taillight. Considering that the bedside will be free on the bottom and not constrained by the lower portion of this, this shouldn't take much effort to straighten. Also, by having a high clearance bumper you can have more functionality on the trail and will likely prevent this crap from happening again as the other guy would likely just mess his shit up at this point.
    I know its not ideal for one of these moments to take place, but I think the higher powers have decided that its time for a HC bumper. BTW, I helped a friend install this on his superwhite 2010 Taco...real easy process and not nearly as bad you might think. Just get a grinder, ruler, and some painters tape and take your time. There are some good write-ups on here for cutting up the bedside.
    Coot
    SpeedoJosh[OP] likes this.
  7. Oct 31, 2016 at 5:50 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    Sorry for your trouble, did you check to see if the place had cameras.
  8. Oct 31, 2016 at 7:53 AM
    Hit n Run
    Hit n Run Well-Known Member
    14 Black DCLB Sport
    That sucks but I didn't do it!!
    Fitz235, SoCalSteve and Pigpen like this.
  9. Oct 31, 2016 at 8:10 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    True that, it would take a lot more than tits to do that sort of damage.
    Coot
  10. Oct 31, 2016 at 8:47 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Sucks that it happened, now you have excuse by the new bumper!
    bsp_taco likes this.
  11. Oct 31, 2016 at 8:57 AM
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    Another vote for a HC rear. I banged up my stock bumper this summer and ordered a HC. keep in mind lead time for a lot of shops is 2 months or so... don't wait till you get back from deployment to order one
  12. Oct 31, 2016 at 9:00 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    THROTTLE231 and wagerhope like this.
  13. Oct 31, 2016 at 10:05 AM
    SpeedoJosh
    Florida
    Yea, it was a budget Mexican restaurant. Good food, but not the nicest establishment so no cameras.
    scottalot likes this.
  14. Oct 31, 2016 at 10:13 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    Check out SOS Concepts in Charleston, high clearance rear, closer to you if you wanted to save on shipping could make a run for it. lead time on them so I would order before you deploy if you can :thumbsup:
  15. Oct 31, 2016 at 1:49 PM
    SpeedoJosh
    Florida
    I've seen those. Nice looking for sure. Wanting to keep the fender flares and find one of the bumpers that stops just before them.
  16. Oct 31, 2016 at 2:59 PM
    Crazydave
    Crazydave Crazy Dave
    Dave
    Western PA
    2015 Tacoma SR5 DCLB
    265/75R16, Clazzio seat covers W/aftermarket heated seats, Interior lights changed to LED
    If you are going to sit on it like this while you deploy, best to spray something like Fluid film or some similar product on it inside and out. If the paint is cracked or chipped in spots it will start rusting rather quickly. When you get back you will have to deal with a rust issues as well as bent metal. Then again if you are cutting the metal off for a high clearance bumper it will not matter much. Just my $.02 worth.
  17. Oct 31, 2016 at 3:53 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    @Pelfreybilt High Clearance Rear Bumper! :)
    I regret not getting a high clearance - and doing the tire swing gate too. :(
