Hitch Ball Mount / Receiver Bar
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MY09TACO, Sep 9, 2009.
  1. Sep 9, 2009 at 4:41 PM
    MY09TACO
    MY09TACO [OP] Well-Known Member
    CENTRAL FL
    Timberland Mica TRD SPORT
    NONE
    A friend of mine has a Hitch Ball Mount / Receiver Bar that belonges to a 4Runner (Toyota Part # PT228 - 89445) that I can have. I know the one for my Tacoma is Toyota Part # PT228-00950. Does anyone know what the difference is?
    When I called my local Toyota dealer and talked to the parts department they could not tell me what the difference was just that it would work. Anyone ????
    Thanks!!!
  2. Sep 9, 2009 at 4:44 PM
    jrw1965
    jrw1965 Well-Known Member
    Southern Maryland
    '08 dbl cab long bed 4 x 4
    Front tint, Stainless steel nerf bars, Leer tonneau, Rear spring TSB, Michelin LTX A/T2 265 70 16, Pioneer AVIC X910 so far
    I kept the one from my 04 4Runner and it works fine, never bothered to check part numbers. I'm not an expert, but I dont see how they can be much different if at all.
  3. Sep 9, 2009 at 5:18 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I'd imagine you'd be good to go, I'm no towing expert though haha. I just picked up my ball and mount at an auto parts store.
  4. Sep 9, 2009 at 9:29 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I'd try it out, especially since it's free. However, if you look at aftermarket hitches (uhaul/valley) the hitches mount differently between an 09 taco and 4 runner.
  5. Sep 14, 2009 at 4:37 PM
    MY09TACO
    CENTRAL FL
    NONE
    The Hitch Ball Mount / Receiver Bar that belonges to a 4Runner (Toyota Part # PT228 - 89445) will not work on my 09 Tacoma. I can't put the pin in because the hole wont line up. The shaft that goes into the hitch need to be longer before the hole will line up to put the pin in. I guess I will have to buy the correct part #.
  6. Sep 15, 2009 at 6:30 AM
    jrw1965
    Southern Maryland
    Wow. I'm sorry to hear that. I didnt mean to steer you wrong. Maybe its the difference between an '08 and '09. Or the year of the 4Runner hitch. But, as you can see from the pics mine fits fine.
  7. Sep 15, 2009 at 6:45 AM
    MY09TACO
    CENTRAL FL
    NONE
    You dident steer me wrong at all! Its just strange that your fits and mine don't. The Toyota Oem Part # for Tacoma is the same # for yours and mine. I guess I'll try to sell this one to help pay for the Tacoma one.
  8. Sep 15, 2009 at 6:59 AM
    MY09TACO
    CENTRAL FL
    NONE
    I just noticed that the part # Toyota Part # PT228 - 89445 for a 4runner that I have is a different # then the one you have (PT228-89340) Yours is for a 2003 and the one I have is for a 2007. This must be the differance.
  9. Sep 15, 2009 at 7:15 AM
    geolink
    geolink Well-Known Member
    SILVER STATE
    09 DCLB MagGray TRD SPORT
    Weathertech mats and hood protector, RuffTuff seat covers, padded console, Redline Hood Struts, Snugtop canopy w/Thule Rack, TSB rear springs plus AAL, 5100's all around OME 885 front coils, LR UCA, Avid Step Bars, LT265/70R17 BFG AT on stock Sport Rims
    I have a ball mount from 04 4runner (PT228-89445).
    The Pin hole is at 1 1/2" which is short for my 09 tacoma (needs about 2").
    That shorter shaft/pin location is why it did not fit my tacoma.
  10. Sep 15, 2009 at 7:45 AM
    MY09TACO
    CENTRAL FL
    NONE
    The same problem I have!
  11. Sep 15, 2009 at 7:03 PM
    jrw1965
    Southern Maryland
    Yeah, mine came with my '04 when I got it, which I guess is the same as the '03. Hope you can sell the other one for at least close to what it costs ya for new.
  12. Sep 16, 2009 at 11:12 AM
    reg boulette
    reg boulette Well-Known Member
    -go to a machine shop and get a new hole cut in the ball mount for $20 if the hole doesn't line up.
  13. Sep 16, 2009 at 12:11 PM
    MY09TACO
    CENTRAL FL
    NONE
    Thats good idea. My job has a machine shop. I will have to check how far from the end the hole will be.
  14. Sep 16, 2009 at 12:25 PM
    geolink
    SILVER STATE
    That crossed my mind for about 5 seconds.
    It appeared that the resulting distance between the design hole and a new hole would be less than 1/2". I do not know about metal strengths so bagged that idea. Not to say it will not work
    Got a ball mount with ball at Checker for 'bout $25.
