Hitch Cargo Basket
Discussion in 'Outdoors' started by CouchlessPotato, May 4, 2019.
Thread Status:
Not open for further replies.
  1. May 4, 2019 at 6:21 AM
    CouchlessPotato
    CouchlessPotato [OP] Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    Has anyone ever used one of those hitch baskets to carry camping gear? I want to know if I should get one of those or maybe a bed extender instead. Let me know what you guys think.
  2. May 4, 2019 at 6:28 AM
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    I have one and used it to haul a large white igloo cooler on an out of state trip. Worked well, just don't drive thru any ruts or low spots off road where you might get hung up. I removed mine once I reached my destination camp spot. Also keep in mind your rear license plate is covered, I had no issues.
    CouchlessPotato[OP] likes this.
  3. May 4, 2019 at 6:32 AM
    CouchlessPotato
    Zach
    2.5" lift w/35's
    Thanks, this trip I'm about to go on will be on the road so I'll be fine. And I plan on taking it off when I get where I'm going also.
  4. May 4, 2019 at 6:41 AM
    StillNoPickles
    StillNoPickles Well-Known Member
    2020 RAV4 Hybrid LE
    They work great for hauling extra gear if the bed is maxed out. Usually you can find them on Craigslist for much cheaper. Paid $20 for mine I think, and it came with a swappable 1.25” hitch post for our car as well.
  5. May 5, 2019 at 5:49 PM
    rj15tacoma
    rj15tacoma Well-Known Member
    I got the aluminum one from harbor freight, haven't used it yet but will in a couple weeks, but looks good.
  6. May 5, 2019 at 6:03 PM
    CouchlessPotato
    Zach
    2.5" lift w/35's
    I just went to habor freight and picked uo the biggest steel one they had for $70 with a 20% off coupon. Its rated for 750 lbs but theres no way in hell I'm putting anything over 150 lbs back there. Should work perfectly for me
  7. May 15, 2019 at 8:20 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Have one, and used it over the years. Great for coolers. Put some red reflector tape on it. Cant see it at night. And hurts like a mofo if you bounce a shin off it.
  8. May 16, 2019 at 8:14 AM
    rj15tacoma
    haha I feel u with the shin breaker :)
    lucky13don likes this.
  9. Jun 28, 2019 at 12:03 PM
    FishinCrzy
    FishinCrzy Well-Known Member
    Rob
    South Carolina
    '17 4WD Limited Taco
    3" Lift, BFG LT275/70R 18, Frt. Hitch, Diamondback cover and Rack, RTT, 52 qt.freezer, House Batt.
    I spent a little extra for a welded aluminum carrier. Much easier to deal with on and off the truck. I have also installed a front hitch receiver and have put 50 qt. Cooler and plan to add small inverter generator. It did fine and was low enough not to block air flow to radiator. Also got the bracket that tightens down so carrier won't move/wobble at all.
    Definitely not for the rock climbing overlanders but should work fine 95% of time.
  10. Jul 12, 2019 at 1:05 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    DrFunker likes this.
  11. Jul 12, 2019 at 3:39 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    I've got the same one. It'll hold some weight.
  12. Sep 5, 2019 at 5:46 PM
    jz123
    jz123 Well-Known Member
    j
    11' tacoma
    It works great
Thread Status:
