Hitch drop question
Discussion in 'Towing' started by thegrandpoohbah, Jun 10, 2021.
  1. Jun 10, 2021 at 10:04 PM
    thegrandpoohbah
    thegrandpoohbah [OP] Well-Known Member
    Terrace, BC, Canada
    2013 4x4 Double Cab V6 TRD Sport
    Just lifted my Taco and now I need a drop to tow my travel trailer. According to this: https://www.etrailer.com/faq-ballmount.aspx, my hitch height is 21.75" and my coupler height is 13.75" so I need an 8" drop. But, when I have everything loaded and hitched up I expect my tail end to sag at least an inch, maybe even more. So should I account for that and go with a 7" drop? Or am I overthinking this and should just get a height adjustable hitch?
  2. Jun 10, 2021 at 10:14 PM
    Bishop84
    Bishop84 Well-Known Member
    Measuring the hitch unladen will not give you a correct measurement. Even 7" might be too much.
    Hook it up and see how much it drops.
    Good on you for doing your homework, so many idiots driving with no concern for trailer safety.
  3. Jun 10, 2021 at 10:20 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Depending on how much weight there is on the hitch you might sag 4” or more.
    What lift did you get? I would start by adding 3” drop if you got a 3” lift. If you got new leafs that have a heavier rating you might need more of a drop.
  4. Jun 10, 2021 at 10:20 PM
    thegrandpoohbah
    Terrace, BC, Canada
    OK, that's what I thought. I will load some weight in the back and hitch the trailer up this weekend and then measure the hitch height again. Thinking maybe a 5" drop would probably be sufficient.
  5. Jun 11, 2021 at 3:45 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Get an adjustable drop hitch, then you can experiment around to see what drop is best for your situation.
  6. Jun 11, 2021 at 3:48 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    I was gonna guesstimate about a 5" drop with a 3" lift. At stock height I usually ran a 2" drop. As everyone has already said it depends on your specific lift, load, and trailer.
