Hitch Kit for 2009 Tacoma/
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Orion, Apr 8, 2010.
  1. Apr 8, 2010 at 3:03 PM
    Orion
    Orion [OP] Well-Known Member
    Rhode Island
    Tacoma TRD
    I just purchased a 2009 tacoma trd sport 4 door. It has the hitch receiver installed. What is everyone using for the hitch kit? ball hitch inserts etc?? I see ones at walmart etc....
    Is there a preferred kit?
    Thanks
  2. Apr 8, 2010 at 3:06 PM
    Tacofanatic05'
    Tacofanatic05' #1 Member
    Hunter
    Waynesville/Charlotte,NC
    05' Tacoma 4x4 sr5, 3 Inch lift
    16'' American Racing wheels, 285/75/16 Cooper Discoverer St tires, Bilstein 5100 w/eibach coils, K&N Cold Air Intake, Flowmaster Super 44, 1 in 2 out exhaust. Tractor Supply Tool Box, No Mud Flaps, Mossy Oak Seat Covers, Oakley Decals, Hoyt Decal, Window tint 20% on sides 5% on top front windshield, Uniden Cb, and Window Deflectors.
    I just use a standard ball, nothing special
  3. Apr 8, 2010 at 4:48 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    What do you plan on towing?
  4. Apr 8, 2010 at 5:09 PM
    Orion
    Rhode Island
    Tacoma TRD
    Not much, a small boat trailer, log splitter etc..
  5. Apr 8, 2010 at 6:08 PM
    Newf
    Newf Member
    Manny
    Ottawa, Canada
    08 4X4 Basic
    If you have the receiver, just purchase a ball the size that will fit your trailer hitch and bolt size on the receiver.
    Manny
  6. Apr 8, 2010 at 8:42 PM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    more then likely its a 2" reciever so you just need a 2" receiver tongue and 2" ball. did you check your rear underseat compartments to make sure it didnt come with one already?
    just asking cause my 08 did.
  7. Apr 8, 2010 at 8:44 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Just picked up a 2" receiver and a ball to go along with it at one of the local auto parts stores. As long as it's rated for what the weight you want to tow you should be good to go. Think mine was a Reese. Haven't actually towed anything yet(although may be buying a boat in the next couple weeks so it will get it's first test).
  8. Apr 9, 2010 at 11:23 AM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    i have the same kit. works fine.
  9. Apr 9, 2010 at 11:29 AM
    Pyriteship
    Pyriteship Well-Known Member
    Bill
    Massachusetts, USA
    10 Access Cab SR5 in Pyrite
    My taco is stock and needs more like a four inch drop in order to tow my trailers close to level.
  10. Apr 12, 2010 at 3:33 PM
    Orion
    Rhode Island
    Tacoma TRD
    Thanks everyone....
    Pyriteship, that is something I have not considered yet. Got to line things up and get the right drop.... thanks
    I was thinking about the reese tongue with the 3 balls already attached but probably not a good idea. No drop with it...
  11. Apr 13, 2010 at 6:15 AM
    Pyriteship
    Bill
    Massachusetts, USA
    That (Reese) system you describe is convenient but not likely to work for most Taco applications.
    Just a reminder too, that the "drop" is measured from the top of the receiver to the platform where the ball sits; therefore a two inch drop in a two inch receiver is not going to drop the ball below the bottom of the receiver at all. The ball will be level with the bottom of the receiver.
