Hitch pin… silly but annoying.
Discussion in '4th Gen. Tacomas (2024+)' started by Korywithak, Apr 14, 2024.
  1. Sep 11, 2024 at 10:00 AM
    Wahhabm
    Wahhabm Well-Known Member
    Monther
    The pin that comes from toyota is a bit thicker than the 5/8 that are being sold. I bought a couple of them and they all fit with a wobble which is annoying
  2. Sep 11, 2024 at 11:27 AM
    trey_is_a_jedi
    trey_is_a_jedi Active Member
    Just fwiw if you want a locking pin and anti-rattle I got this one and it works on the 24 and on my other vehicles. Yes I know how pricey it is. Have used the shorter length version of this one for years with no issues.
    https://www.letsgoaero.com/collections/locking-silent-hitch-pins/products/silent-hitch-for-3-hitches
    Just a note the protective 'sleeve' does not fit through the hitch. I use it without that piece and its fine. Might just be operator error on my part as to why it won't work.
  3. Oct 22, 2024 at 12:25 AM
    Jimmys115
    Jimmys115 Well-Known Member
    Jaime
    2019 Tacoma TRD-2024 Tacoma TRD Off Road
    On Amazon, in the link you provided, there are three different sizes. Which one did you buy that’s installed on your truck?
    thanks!!!
  4. Oct 22, 2024 at 12:30 AM
    Jimmys115
    Jaime
    ¿Has solucionado el problema? No he podido. No encuentro ninguno. Fui a AutoZone y O'Reilly's de la zona y no tenían nada.
  5. Oct 22, 2024 at 5:39 PM
    wamerritt
    wamerritt Active Member
    Wes
    Florida
    24 TRD Sport DCSB
    mile after mile
    My tractor supply had multiple brands of 4" locking pins on the shelf.
    Jimmys115 likes this.
  6. Oct 26, 2024 at 2:24 PM
    Jimmys115
    Jaime
    The new 4th Generation Tacoma has a redesigned hitch system, very different from the 3rd Generation, and the pin lock needs to be a bit longer. I had this issue for a few days and tried several pins from local stores, but none were long enough or had a lock. Then I found this option here on Amazon, and I’m happy with it!
    https://www.amazon.com/dp/B0978V7JJC
    Recommended for the 4th Generation Toyota Tacoma.
    Fireball 00 and H2o-Bar like this.
