Hitch Receiver Rust
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dr4g1116, Sep 15, 2020.
  1. Sep 18, 2020 at 11:07 AM
    #81
    wheelerkr2
    wheelerkr2 Well-Known Member
    Kevin
    Richmond, VA
    08 TRD Rugged Trail
    BillsSR5 and Kev250R like this.
  2. Sep 18, 2020 at 11:10 AM
    #82
    itr1275
    itr1275 Well-Known Member
    Jerold
    San Jose CA
    '00 Tacoma TRD Off Road
    Icon Coilovers, Daystar Shackles. Sliders.
    I know it's hard to spend a bunch of money on something you really like and have BS like this happen, but it does. I would try not to get too caught up in it, otherwise you will loose a lot of sleep over stuff that is unavoidable in the end.
    Why this is happening it there is a large amount of pressure (pressure=force/area) in the worn areas. The force is small and the surface area it's contacting is also small. In this case it's wearing on the high spots. If it were distributing the force of the hitch over the entire flat surface (not possible because of tolerance) the wear would be minimal and wear evenly.
    Nit pick physics aside, you have some choices.
    1. Hit it with some Rust-oleum and call it a day.
    2. Mitigate the rust (wire wheel, sand, stripper, etc) and paint it. - However it will still wear because of the pressure points.
    3. Take it the dealer and have them "fix it" - See #1.
    4. If it really bothers you, take it off and bring it to an shop to get stripped and powder coated. The power coating will hold up a better, but still wear through eventually. Also you cannot touch up powder coating... sort of.
    My opinion here, nothing else. The truck is a tool and it will show normal wear. I would call this normal wear. See #1.
    usmc2msu and hiPSI like this.
  3. Sep 18, 2020 at 11:13 AM
    #83
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    JW Black is my norm. I also like McCallan 18 but damn. Johnny for the win last night.
  4. Sep 18, 2020 at 11:24 AM
    #84
    itr1275
    Jerold
    San Jose CA
    This won't be the point of failure due to rust. Look in the 1st gen forums, the frames like to rot out on us. You can always replace the entire hitch assembly [Toyota (51908-04020)] if it's bad enough. It's a few hundred $$ at most and a few bolts 10-20 years later. More than likely the bolts will be rusted into your frame by then and it won't matter.
  5. Sep 18, 2020 at 11:31 AM
    #85
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    :rofl::rofl::rofl: You need to relax if interewebs and a bit of rust get rev'd up...:duh:
    wheelerkr2 and Kev250R like this.
  6. Sep 18, 2020 at 11:52 AM
    #86
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    On my 2nd gen they didn’t replace the hitch with the frame even though it was far more rusted than the frame and it holds on the rear bumper! They probably won’t cover it (you can ask). Wire wheel and paint, don’t sweat it to much Your still driving the most reliable truck on the road. Laugh with the trolls
  7. Sep 18, 2020 at 12:01 PM
    #87
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Looks like normal wear & tear to me. Doubtful if Toyota will handle with a warranty. I'm pretty sure they could handle that in the Toyota body shop at your cost.
    I'd recommend to remove the rust, prime with a rust converter, paint your color of choice, schmear some graphite or moly added grease on the inside of the receiver. Store the ball/hitch in the cab when not in use.
    The Receiver/Hitch interface will always rattle and move some. Otherwise, you wouldn't be able to put the hitch into the receiver with a tight fit.
    This is normal.
    Oh......try to relax a bit.
    Rick111, BillsSR5 and Kev250R like this.
  8. Sep 18, 2020 at 12:06 PM
    #88
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    When two pieces of painted metal contact each other paint can, will and does come off.
    Once you make moisture available to an unpainted surface rust will form and break the bond between the metal surface and paint. This is why your paint is flaking.
    Your pulling a trailer in and around salt water. Paint is gonna chip and metal will rust. This is not Toyotas fault.
    Wire wheel. Paint. Clear.
    Done.
    Rick111 and Chew like this.
  9. Sep 18, 2020 at 12:10 PM
    #89
    txags92
    txags92 Well-Known Member
    2016 DCLB TRD OR 4x4 BBP
    I am going to guess you probably rinse the whole trailer and rig off with the vehicle every time after using it in salt water, right? But probably without detaching the trailer first and without taking the hitch receiver out when you do it...leaving any water and salt accumulated in the bottom of the hitch receiver there. Toyota is going to (rightfully) say that rust of that type is normal wear and tear on a vehicle used in or near salt water.
  10. Sep 18, 2020 at 12:14 PM
    #90
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    Kev250R, Malvolio, hiPSI and 2 others like this.
  11. Sep 18, 2020 at 12:21 PM
    #91
    WarBeard_Actual
    WarBeard_Actual Well-Known Member
    You need to lift that a bit more
    Malvolio likes this.
  12. Sep 18, 2020 at 12:23 PM
    #92
    wessyder
    wessyder Enlightened OR Bro who don't need no skewp
    2019 Tacoma TRD OR, basically an off road race truck
    Tied several boat anchors to my truck to destroy MPG.
    my receiver is rusted too just like that, as is the chain attachment point from where I bashed them off some rocks and bent them when on the Fortune Creek trail. so i just took the whole damn thing off and threw it on the ground, when I put on a RCI bumper that had more clearance and its own receiver. maybe we can do a class action.
    i have a two package for a 3rd gen for sale btw. game used.
  13. Sep 18, 2020 at 12:43 PM
    #93
    BillsSR5
    bill
    2014 SR5
  14. Sep 18, 2020 at 2:39 PM
    #94
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    How do you deal with the water coming in the front of the receiver?
  15. Sep 18, 2020 at 2:45 PM
    #95
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    I leave my hitch out because I don't like bruised shins. I do stuff a rubber plug in it just because it looks better does zero for rust through. There is a lot of clearance between the hitch and the receiver the trouble starts if you leave the hitch in all the time.
  16. Sep 19, 2020 at 12:45 AM
    #96
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    I'm only writing as I did not see anyone make a similar comment. I'm not picking a fight, and hope your skin gets a little thicker since I don't think anyone has been too terribly hard on you.
    My opinion, I tell you to piss off if you are making a warranty claim.
    My reason is this did not happen overnight. If you would have brought it in at the first sign of chipped paint, I would have had someone grind and repaint it, but it's a little more than noticable which means it was not maintained well.
    Hell, I may have even swapped the hitch for a new one if it was brought in early, and you made a big deal, but this is pretty far gone to not cite negligence on behalf of the owner.
    I don't often take a dealerships side.
    Again, not picking a fight with you
    Rock Lobster and Kev250R like this.
  17. Sep 19, 2020 at 1:28 AM
    #97
    harpoonalt
    harpoonalt Member
    2011 MG DCSB TRD sport
    I spray everything i see rust on with woolwax or fluidfilm. It's preventive maintenance. Salt or saltwater is the worst thing possible for your truck if you're concerned about rust. In Vermont they salt the roads and rust here is a fact of life. I waxoyled my new Tacoma as I've had excellent results from it in the past 30 years or so. My Kubotas get woolwax or fluidfilm on wear areas at the first sign of any rust or bare metal.
    You can keep rust away, but it's no set and forget. My friends dad has a farm truck from the 70's with zero rust here in Vermont. He oil undercoats it every year and spot coats any problem areas.
    My cans of fluid film come out often to spray various things I have. I hate rust but so far I've managed to win the battle with minimal effort.
    usmc2msu likes this.
  18. Sep 19, 2020 at 6:57 AM
    #98
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    I have a little rust back there... Show me a truck that does not have some marks around the receiver hitch especially where the chains connect. Just get a shaker can and put a little paint there once in a while you’ll be good to go. I’ve also got rock chips on my side steps can’t help it drive on gravel roads and get rocks. I do the same as shaker can sprays right over these. No big deal.
  19. Sep 19, 2020 at 7:07 AM
    #99
    Itchyfeet
    Itchyfeet Well-Known Member
    I think the OP checked out.
    Rick111 likes this.
  20. Sep 19, 2020 at 7:08 AM
    #100
    Knute
    Of course. The replies were not what he wanted to hear. So, he buggered off.
    Rick111 and Rock Lobster like this.
