hitch wiring
Discussion in 'New Members' started by woogie48, Nov 10, 2008.
  1. Nov 10, 2008 at 12:54 PM
    woogie48
    woogie48 [OP] New Member
    London
    04 tacoma trd
    Hi all,
    I have a 2004 tacoma trd that I have recently put a 1998 factory hitch on(new out of box). The wiring is straight forward and simple, however, it has caused an electrical glitch with my left turn signal (speeds up when I put on the brakes?), causes the dash indicator to slightly brighten when i brake, the ABS light comes on, and the right rear tail lights don't function when the head lights are turned on. Could this be caused by a bad "converter" for the hitch wiring? Any ideas out there?
    Thanks everybody.
  2. Nov 10, 2008 at 12:56 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    it could be hooked up mostly right, but maybe one wire off, or perhaps a bad ground maybe??
  3. Nov 10, 2008 at 1:05 PM
    woogie48
    London
    04 tacoma trd
    I know it really sounds like a bad ground, but the wiring is right out the box and it is all factory plug ins. When i disconnect the wiring kit and go back to original, everything works perfectly. Continuity on the new ground wires ring out too. Still puzzled.
  4. Nov 10, 2008 at 1:55 PM
    woogie48
    London
    04 tacoma trd
    Good call. I will start with the elimination of each side. see what happens at least.
