Hitch won't fit! WTF gives?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03TACOMANH, Jun 19, 2011.
  1. Jun 19, 2011 at 12:33 PM
    03TACOMANH
    03TACOMANH [OP] New Member
    Gregg
    Seacoast, NH
    2003 Tacoma
    I got a SWEET deal on an OEM hitch, presumably off an '04 Tacoma. Trying to put it on my '03 but the frame rails appear to be too wide for it. I never asked the questions about whether the donor was 2WD vs 4WD...is there a difference in rear frame rail dimensions?
  2. Jun 19, 2011 at 12:58 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    No, the frames should be the same.
  3. Jun 20, 2011 at 1:40 PM
    04DcTaco
    04DcTaco Active Member
    sam
    Visalia,Ca
    3 inch toytec eibach 5100 with aal FN five stars rims Goodyear duratrac 285/75/16 Retrofit Headlights
    I thought the same way too, one side goes through but the other doesnt. But theres a certain way you gotta manuever it. Pretty tough if ur doing it your self. I think slide the right side on and move it towards the rear bumper. Then move the left side all the way down untill u can get it on there. Only hard part was removing the rusted frame bolts!
  4. Jun 20, 2011 at 2:56 PM
    snoope
    snoope Well-Known Member
    Ft.myers,FL
    2003 Lexus ES300/2004 Lexus 330 AWD
    Ok,
    Measurements; My Draw-tite receiver is 42" wide ,bolts to the frame and then the bumper brackets bolt on the outside of the receiver.....
    Does this help??? 2 people does make this a MUCH easier project....
    If you need help still.......I'm in Dova'.....
