hitch
Discussion in '1st Gen. Tacomas (1995-2004)' started by Huntn57, May 28, 2014.
  1. May 28, 2014 at 5:34 PM
    Huntn57
    Huntn57 [OP] Well-Known Member
    Justin
    VA
    1995 Toyota Tacoma
    i com 2300 ham radio. for hunting (170 k miles) list of replacements since 166k miles: 4wd solenoid tailpipe muffer catalitytic conver exhaust manifold
    im trying to get my hitch receiver off because the hitch wont go in it. i was going to buy a new one but i can get the old on off. i had an impact and i the bolt loser stuff and it still wont unloosen. any ideas
  2. May 28, 2014 at 6:16 PM
    Tinmann
    Tinmann Well-Known Member
    NorCal
    Cutoff the bolt heads with a sawzall or use a torch?
  3. May 28, 2014 at 6:38 PM
    Huntn57
    Justin
    VA
    1995 Toyota Tacoma
    ok i will try that. i gotta pull if not i might as well buy a car lol
  4. May 28, 2014 at 7:24 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Did you try to clean out receiver? Could shoot pb blaster and scrape inside or file. Might try that before totally taking receiver off. Small wire wheel on drill could help.
  5. May 28, 2014 at 7:32 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    So rusty that the drawbar won't go in? Do you have a 2" drawbar? They aren't that tight of a fit usually.
  6. May 29, 2014 at 1:07 PM
    Huntn57
    Justin
    VA
    1995 Toyota Tacoma
    yea it wont go in. i tried a wire brush. i think some home the bottom got bend in. because now that u said something the hitches have some play in them to began
