Hitchpod S1 or DD hitch pod reverse kit
Discussion in 'Lighting' started by Bkicks333, Nov 18, 2022.
  1. Nov 18, 2022 at 7:19 PM
    Bkicks333
    Bkicks333 [OP] Well-Known Member
    James
    Trd offroad 4x4
    Going to get one of these. Want to know which ones you all like better and why? I think hotshot has a plug and play kit that doesn't require removing taillights. Diode dynamics seems pretty simple as well. So which do you all prefer?
  2. Nov 19, 2022 at 12:34 PM
    Bkicks333
    James
    Trd offroad 4x4
    Bump trying to order today
  3. Nov 19, 2022 at 12:49 PM
    Tacospike
    Two Trucks
    I like the function that the DD has but can be stolen in seconds, no security. - correction you can have a hitch pin or not
    I have the BDS1 mounted with a locking hitch pin. Not as many functions but works great for a reverse light.
    Bkicks333[OP] likes this.
  4. Nov 19, 2022 at 12:55 PM
    Tacospike
    Two Trucks
    I watched a video and it snaps in
    I might have to double check
    Edit: I guess you can. drill and modify like the BDS1 pod
  5. Nov 19, 2022 at 1:14 PM
    Tacospike
    Two Trucks
    Yeah, hard to tell from the pics. Looks like you could pop it out, not sure what inner tabs or security is inside?
  6. Nov 19, 2022 at 1:19 PM
    Clearwater Bill
    Billy
    Largo Florida
  7. Nov 19, 2022 at 1:32 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I have arrived! @Bkicks333
    So the installation of these kits is the same. We custom built the universal HitchPod harness that you've linked to. When DD came out with their Hitchmount pod they chose to build a harness that essentially mimics ours (imitation is the sincerest form of flattery after all)! So both options will snap right into the existing trailer connections on a new Tacoma with no trouble.
    As for which one is "better" it's kind of whatever brand you're into! We love our Hitchpods, but also know that the C1R brings some new functionality that the S1 simply doesn't have. As for the security part of it, DD has released that video that is them cutting off the tabs and making a McGyver locking hitchmount. The Hitchpod, since it needs to be drilled into, lends itself well to being locked into place organically. I will tell you this as well... It's a little ways out just due to backlog of other items, but we are working on our own DD Hitchpod which will be able to leverage the same C1R light and their harness. It can be transferred over easily, and will also be secure like you'd come to expect from us. If you purchase a DD Hitchmount light now, and decide you want our pod we'll cut you a good deal on one if you've already purchased from us.
    If you do decide to pick up the DD version though I encourage you to pick that up from us here at Hotshot Offroad! We've got those bad boys too.
    https://hotshotoffroad.com/products/hitchmount-led-pod-reverse-kit
    ETAV8R, TacoFergie, airmax233 and 3 others like this.
  8. Nov 19, 2022 at 1:34 PM
    Tacospike
    Two Trucks
    Thanks Colton!
    memario1214 likes this.
  9. Nov 19, 2022 at 1:34 PM
    Squatting Pigeon
    Squatting Pigeon Remember, bird watching goes both ways. Moderator
    North Texas
    TRD OR 4R | GR Corolla
  10. Nov 19, 2022 at 1:37 PM
    memario1214
    Colton
    Missoula, MT
    :cheers:
  11. Nov 19, 2022 at 2:05 PM
    Bkicks333
    James
    Trd offroad 4x4
    Colton thanks and everyone else as well. @memario1214 let's make it happen with some baja goodness
  12. Nov 19, 2022 at 2:25 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    would go with DD as it serves two purposes. a 3rd brake and backup is kinda cool.
  13. Nov 19, 2022 at 5:04 PM
    Bkicks333
    James
    Trd offroad 4x4
    Thought that was cool too
  14. Nov 29, 2022 at 9:01 AM
    Taco_diarrhea
    Taco_diarrhea Member
    2019 TRDOR
    DD hitchpod with the C1R is particularly useful if you have a softtopper since the 3rd brake light gets covered by the top, and you can still have another brake light that also flashes and acts as a reverse light.
    PLUSSSS it is cheaper overall
  15. Nov 29, 2022 at 6:35 PM
    caribe makaira
    Caribbean, Puerto Rico
    I wonder if DD will assemble a C1R for the 2nd Gen without a 7pin Tow connector and the 3rd Gen without a towing connector. (SR)
    (Reverse, Stop, Tail, Stop) are easily accessed on the tail light assemblies connector.:rolleyes:
  16. Nov 29, 2022 at 6:38 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Did you ever buy the S1 and Hitchpod? I just took one off my truck (work/scene light) in perfect shape, I can PM you about it if interested. It’s a great setup I just wanted to recess lights into the bumper. Definitely would 100% recommend anything Baja (or Rigid) over DD.
    Bkicks333[QUOTED][OP] likes this.
  17. Nov 29, 2022 at 7:26 PM
    Taco_diarrhea
    2019 TRDOR
    Whats wrong with DD?
  18. Nov 29, 2022 at 7:28 PM
    BLtheP
    Plano, TX
    Eh, too much to want to divulge here but in short I had a bunch of problems with several of their products (various bulbs, SS3 Max fogs). I wanted to like them but nothing I bought from them worked well for me beyond surface level.
  19. Nov 29, 2022 at 7:30 PM
    Taco_diarrhea
    2019 TRDOR
    Welp, I just dropped $400 on DD parts, so thats not good to hear…do they atleast backup their products?
  20. Nov 29, 2022 at 7:32 PM
    BLtheP
    Plano, TX
    Their service is good and they offer free returns so if you have any issues you can get out of it easily.
