Hitting upper control arm
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Coolbeverage73, Jul 13, 2020.
  1. Jul 13, 2020 at 10:50 AM
    Coolbeverage73
    Coolbeverage73 [OP] Well-Known Member
    Kevin
    2019 Tacoma OffRoad in Quicksand
    I first put Rough Country coil over struts on my 2019 TRD OR last month which lifted the front a solid 2 inches making it ever so slightly nose up but I'm fine with it for now and will deal with the rear later. I wanted to run the factory wheels for now also. I bought a set of Milestar Patagonia MTs in 285/75/16 and the are slightly hitting the upper control arm at full lock. I really hadn't expected this to happen. Any idea what a recommended solution is? I ordered 4 aluminum 1/4 inch wheel spacers for $30 with shipping. I'm hoping that only 1 per wheel is needed. I'm fairly concerned if I have to use two. Anyone know if just one will do it? Should I have not attended to use factory wheels with zero off set? Thanks
  2. Jul 13, 2020 at 10:52 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Yeah the factory wheels sit too far in to run 285s, you might be fine with a 1/4 spacers.
    Coolbeverage73[OP] likes this.
  3. Jul 13, 2020 at 10:52 AM
    Uscgamecock7
    Uscgamecock7 Well-Known Member
    Nick
    West Columbia, SC
    2015 Tacoma Trd Sport DCLB 4x4(SOLD) 2017 Tacoma Trd OR 4x4(SOLD) 2024 T4R TRD PRO
    I run a 1.25 spidertrax spacer im not sure 1/4 is enough
  4. Jul 13, 2020 at 11:22 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I think imma run into this same issue when I install my JBA's control arms. I need to do more research on em
  5. Jul 13, 2020 at 11:23 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    I believe the problem is the spacing on the rim and not so much the UCA
  6. Jul 13, 2020 at 11:31 AM
    Coolbeverage73
    Kevin
    That's what I get for believing YouTube vids I guess...there was a guy on there running my same tire size and leveling blocks and he said his just barely worked...would you be scared to double up on the 1/4 space giving me 1/2 like I now might not have enough turns on my lug nuts?
  7. Jul 13, 2020 at 11:35 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    I would caution using that type of spacer
    Toyota wheel studs are shit enough as is
    Get Spidertrax for your safety and others too
    Good luck and congrats on the lift
  8. Jul 13, 2020 at 12:05 PM
    runandgun18
    runandgun18 Well-Known Member
    Nate
    Arizona
    20 MGM SR 4X4
    I went to 255 85 16 and have plenty of room all around except at full lock where I barely make contact with the uca. Trying to find a good set of wheels with enough offset, or doing spacers. I'm hesitant to go with spacers because there's so much back-and-forth on whether they're safe (or bad for your truck).
  9. Jul 13, 2020 at 12:07 PM
    Coolbeverage73
    Kevin
    Well apparently Spidertrax wheel spacers are on back order all over the country....Man....this is just the story of my life!
  10. Jul 13, 2020 at 12:14 PM
    JEtaco03
    JEtaco03 Well-Known Member
    Justin
    New Market, AL
    08 Tacoma TRD
    Lifted on 18s and tires, LEDs all around
    These are the spacers I run on my truck b/c Spidertrax were out at the time. I really like them and the company seems to have good review. I've been wheeling (blue trails) with them on and have rechecked them afterwards, with no problems to report.
    https://www.amazon.com/gp/product/B01IV2524M/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
    Natetroknot likes this.
  11. Jul 13, 2020 at 12:16 PM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Wheelers has em in stock Edit: looks like they drop ship from Spidertrax
    About any hub centric spacer is better than what you have on the way for $30
    Remember you only need 2
    TRD4X4TOY likes this.
  12. Jul 13, 2020 at 12:18 PM
    runandgun18
    Nate
    Arizona
    20 MGM SR 4X4
    Available on Amazon and Extreme Terrain!
  13. Jul 13, 2020 at 12:21 PM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Your truck karma will be happy you supported a forum vendor instead of the richest sack of dicks this side of the globe
    Just saying
  14. Jul 13, 2020 at 12:22 PM
    Coolbeverage73
    Kevin
    I actually just found these myself...we have a 4WP store in my town and I had called them and he said all his stores were sold out...I ordered the Spidertrax version on Amazon....fingers crossed.
  15. Jul 13, 2020 at 12:45 PM
    niko5055
    niko5055 Well-Known Member
    24 Underground Sport Premium 4x4
    I run the same thing and my 285's don't rub at all. They've been on the truck since 3500 miles (at 40k now) and have given me 0 issues. Spidertrax are good quality from my experience and everything that I read before purchasing them.
  16. Jul 13, 2020 at 1:00 PM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    When time is of the essence it's hard to beat the Zon
    Glad you decided on Spidertrax, they're proven quality and will save you any more headaches
    I ran them on the front of my FJ and the 5 lug version on my 100 series with no issues
    Post up a pic of your truck when you get everything squared away I'm sure it'll look great
    Cheers
  17. Jul 13, 2020 at 2:59 PM
    PinktacoDM84
    PinktacoDM84 Well-Known Member
    Dan
    BC
    2015 trd OR/AC
    St Maxx on Trd pro wheels, mbrp exhaust, k&n cai, jba's, 887's over 5100's, medium dakars and 5125's.
    Can someone here save me the headache of going through threads and tell me the legit torque of spacer to hub and then wheel to spacer? (For the spidertrax, not sure if they’re all the same)
    Thanks a bunch
  18. Jul 13, 2020 at 3:00 PM
    coopcooper
    alberta canada
    the spidertrax booklet says 100.
    but someone said that was wrong so I went with 90 all around
  19. Jul 13, 2020 at 3:03 PM
    PinktacoDM84
    Dan
    BC
    2015 trd OR/AC
    Ya I just looked at their specs but that’s 15-25 more than anything I’ve ever read from users on TW. And there was a slight variance in spacer to hub and wheel to spacer.
    Fucking opinions in this world I tell ya... confuse the shit out of me.
    You ran the company specs I’m assuming?
  20. Jul 13, 2020 at 3:03 PM
    doorsidedown
    doorsidedown Well-Known Member
