Hmm, fuel heater, oil cooler?
Discussion in 'Technical Chat' started by Coreyjon, Apr 12, 2008.
  1. Apr 12, 2008 at 3:01 PM
    Coreyjon
    Coreyjon [OP] Northern Alliance: Airlift Div
    Upstate, Ny
    08 DCab 4X4 SR5 TRD Sport
    iPod Adapter, Bilstein 5100's @ 1.75" front, Wheelers 3-leaf 1.5" + overload rear (2"), custom carrier bearing drop spacers.
    So, heres my idea (guess I've been around planes too long).
    Heat fuel going to the engine by a fuel oil heat exchanger setup. Fuel enters the vessel and circulates via a copper coil, which is then surrounded by hot engine oil . This would be installed in parallel with the oil system so that a bypass route would be able to control hot oil flow into the system to adjust the temperature.
    My reasoning, warming up the fuel would allow it to burn better, and more completely, while at the same time adding capacity to the engine oil and additional cooling.
    Idea #2, substitute oil for engine coolant.
    Is this needed? Probably not. Just an idea I'm stealing from my plane.
    So, just putting it out there, I'm bored, trying to spur ideas.
    Don't mind me..bored, the next step is for me to find something to "Fix".
  2. Apr 12, 2008 at 3:29 PM
    BigRed
    BigRed Member
    Greer, South Carolina
    06' 4X4, Double Cab, Long Bed, SR5
    Front Suspension: OME springs and struts, OME UCA, RCV half axles Rear Suspension: OME leaf springs, OME shocks Engine: S&B air intake Exterior: Viper Cut, after market headlights and tail lights, LED fog light, TRD PRO style grill Tires and wheels: 16 x 8 wheels, 285/75/16 tires
    I can't think of any reason thermodynamically why you would want to heat fuel. The only reason I've seen for heating fuel is to keep it flowing, for example #6 fuel oil used in boilers has to be heated or it won't flow. What's the reason fuel is heated in aircraft? I would imagine it's for the same reason due to extreme cold at high altitudes. Can you tell I'm an engineer:D
  3. Apr 12, 2008 at 3:55 PM
    TACOROCK
    TACOROCK Well-Known Member
    FAYETTEVILLE NC
    06 TACOMA LIFTED
    URD SUPERCHARGER 80MM PULLEY, DOUG THORLEY LONG TUBE HEADERS, MODIFIED Y-PIPE, TRUE DUAL EXHAUST MAGNAFLOW 2 IN 2 OUT, PRO COMP 6" LIFT, WIDEBAND 02/FUEL SENSOR, AVIC D3, 2 PIONEER SUBS ON A MEMPHIS 1200 WATT AMP RMS, DIY MOD FOR ALL INTERIOR SPEAKERS FULL TINT, LEER CAMPER, EURO LIGHTS, BILLET GRILL, BULL BAR WESTIN RUNNING BARS, AIR HORN, AND A RADIATOR POPPER
    well if we were talking diesel then you would be on to something that was invented 10 yrs ago
  4. Apr 12, 2008 at 4:02 PM
    Coreyjon
    Upstate, Ny
    Haha guys cut me a little slack . It is used in our aircraft because ice can form in our fuel, which - if allowed to flow to the engines could obstruct a line and cause an engine to run too lean, which would create bad problems (jet engines don't like to run out of fuel - flame out = bad)
    I'm just a guy who sometimes can't help himself, and will type a random idea to spark other ideas. There is a reason why cars don't come equipped with the set up I described.
    Now, if this was a diesel forum, and people were running veg oil, then this would be of more use.
    Damn engineers! Always using their logic.
  5. Apr 12, 2008 at 4:09 PM
    TACOROCK
    FAYETTEVILLE NC
    06 TACOMA LIFTED
    now thats funny you get a rep for that 1!!!! lol:D
  6. Apr 12, 2008 at 4:12 PM
    Coreyjon
    Upstate, Ny
    WooHoo!
  7. Apr 12, 2008 at 7:29 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Smokey Yunick Hot air engine, check this out. Hope the site works if so scroll down a ways there is a diagram of the engine and some specs. He built a few most popular was his fierrio.
    http://www.schou.dk/hvce/?mode=2
