Hmmm, Did I Do Something Wrong?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Caddis, Jun 6, 2017.
  1. Jun 7, 2017 at 11:19 AM
    #41
    trdsupreme
    trdsupreme Well-Known Member
    2017 TRD OR DCLB Silver Sky
    Based on the Original Post, it sounds similar to what would happen to a car with a drained battery or weak connection in the terminals.
  2. Jun 7, 2017 at 11:21 AM
    #42
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    I guess I should have asked, why is it the negative cable thats removed and not the positive? And its the negative cable I have a concern about touching other metal on the truck and causing the ground.
  3. Jun 7, 2017 at 11:23 AM
    #43
    chrisrocks300
    chrisrocks300 War Eagle
    Brandon, MS
    2016 4x4 Tacoma DCSB Trd Off-road Superwhite
    Total Chaos UCA's, Raceline Raptor wheels (16x8) 4.5 BS, 285/75/16 Cooper S/T Maxx tires, Icon Stage 2 Lift Kit, Sos sliders w/ fill plates, exhaust reroute, mobtown offroad skid plates (ifs, transmission, transfer case), and diff breather mod
    Well I can't answer you 100% on that but I can tell you the negative is much easier to remove on our trucks. The last time I removed positive instead of negative a blew a bulb
    Spare Parts[QUOTED] likes this.
  4. Jun 7, 2017 at 12:38 PM
    #44
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    You remove the neg. and touch the frame...no sweat... the frame IS the neg. If you remove the pos. and touch the frame (with the neg connected).....fireworks tonight....!!!!:bananadead::eek::eek::eek::eek:
    ancient11, EDDO, RocTaco and 2 others like this.
  5. Jun 7, 2017 at 12:41 PM
    #45
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    I absolutely love these " . . . I wired up some shit and now it won't work" threads!!
    G.
    Hobbs likes this.
  6. Jun 7, 2017 at 12:42 PM
    #46
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    What over 60 said, the ground is on the body/frame so if it touches its ok, where if the positive touches body/frame it will ark and u could end up with this...
    over60[QUOTED] and Garyji like this.
  7. Jun 7, 2017 at 12:46 PM
    #47
    Mountain Minstrel
    Mountain Minstrel Well-Known Member
    Prather, CA
    '17 DCSB MT INFERNO
    Umm...no!
    The battery is still not connected so you are not completing any circuit (as long as you are pulling the cable off of the battery).
    am sure that there is a reason for the Ground to be disconnected and I'm pretty sure someone told me what that reason was. However, I cannot remember what that reason was, so I just do it now because it is what you do.
    Spare Parts likes this.
  8. Jun 7, 2017 at 12:48 PM
    #48
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
  9. Jun 7, 2017 at 12:52 PM
    #49
    Mountain Minstrel
    Prather, CA
    '17 DCSB MT INFERNO
    I think this is the reason...If you pull the positive you still have the possibility of getting something between the positive terminal and a ground. That would complete the circuit and all hell will break loose. (my Dad did that with a twist-o-flex watch band once and worn a scar in that pattern for the rest of his life). With the negative disconnected the only possible way to complete the circuit is to drop a wrench or something between the two battery terminals.
    over60 likes this.
  10. Jun 7, 2017 at 1:01 PM
    #50
    erok81
    erok81 Well-Known Member
    Imposter
    That doesn't work in real life. I tried that with my dealer and corporate. They told me get lost. It's your fault.
    Even though I never touched anything. I even asked them to prove I caused it. Nothing.
    brich999 likes this.
  11. Jun 7, 2017 at 1:20 PM
    #51
    over60
    Muskoka, Ontario
    Re-read my post.... I stated that with the - still connected and you remove the + and touch the frame...you WILL get fireworks.
    Always remove the neg. cable.
    tcjacado likes this.
  12. Jun 7, 2017 at 1:31 PM
    #52
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    MRBOND101 likes this.
  13. Jun 7, 2017 at 1:33 PM
    #53
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Dealer holds first right of refusal. Good luck with your Magnusson Moss Act. Do you have time to hire lawyers and deal with corporate when the dealer tells you "so we see you modified your headlights, you're having electrical issues, we think you fucked up your truck with the headlight wiring--- pound sand"... good luck with that.
    tomwil, Garyji, Riding Dirty and 4 others like this.
  14. Jun 7, 2017 at 1:35 PM
    #54
    toysrgood
    toysrgood Well-Known Member
    SC
    2011 4x4 Reg Cab
    If you remove the + first and your wrench touches chassis, fireworks.
    If you remove - first and your wrench touches chassis,
    nothing
    If your wrench touches other terminal, fireworks.
    Every 1/2-9/16 combo wrench in my old work had chunks taken out
    isius, over60 and Qwack like this.
  15. Jun 7, 2017 at 1:39 PM
    #55
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    No need for a relay either. Properly fused off constant power is fine so long as the draw on the circuit isn't anything nuts. LED pods don't typically draw more than 2-3amps a piece depending. Now would I wire them up without a relay, no. Why? Because I have an aux panel prefitted with relays so why not.
    And solo light harnesses with relays are cheap too.
  16. Jun 7, 2017 at 2:36 PM
    #56
    Mountain Minstrel
    Prather, CA
    '17 DCSB MT INFERNO
    yup that too.
  17. Jun 7, 2017 at 2:40 PM
    #57
    Mountain Minstrel
    Prather, CA
    '17 DCSB MT INFERNO
    no. once you pull the positive cable there is no power available at the cable...thus...no fireworks
    yes always remove the Negative first (unless your working on some very old positive ground system).
  18. Jun 7, 2017 at 2:44 PM
    #58
    erok81
    Imposter
    I'm struggling to see how if you remove the positive (including all accessory wires) it will spark when touching metal. Sure there is some residual voltage to bleed off but that's it.
    On that note, I always remove negative. It's always seemed weird to me removing the positive first.
  19. Jun 7, 2017 at 2:47 PM
    #59
    Clearwater Bill
    Billy
    Largo Florida
    There is a risk of drawing an arc between the terminal and cable when removing the cable. ECU vehicles don't like that. Removing the ground first, and installing it last (if you are taking both off, like to replace the battery) means you won't have this issue.
    And the old 'trick' of pulling off a cable while the vehicle is running to 'test' the alternator? Don't do it. Unless you like electronic Russian Roulette.
  20. Jun 7, 2017 at 3:04 PM
    #60
    Kaerntner
    Kaerntner Well-Known Member
    2016 doublecab limited 4Ă—4
    Are you saying you touch the frame with the +cable unhooked?OR touch the +post?
