ho alternator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by willard417, Feb 12, 2011.
  1. Feb 12, 2011 at 11:31 PM
    willard417
    willard417 [OP] Yeah
    Luke
    beaver county, PA
    06' access cab. 2.7L
    alpine head unit, removed secondary air filter, 18" XD Rockstars. 285/60/R18, 3" OME 884/AAL OME shocks all around.
    anyone put one on there truck? which one would you recommend?
  2. Feb 13, 2011 at 2:20 AM
    BartStar
    BartStar Well-Known Member
    pa
    2011 Tacoma 4X4 Double Cab, 6 speed man
    My Tacoma has the towing package and that includes a 130 amp alternator, so I believe that same alternator will bolt up to your V6
    or a good auto electric shop can modify your existing alternator.
    Edit: I just read your Tacoma is the 4 cyl, my mistake, I don't think the V6 alt will work in the 4 cyl
    May I ask,,,WHY do you need a "High Output Alternator"? you hooking up a big amp to your sound system?
    http://www.youtube.com/watch?v=egbnCIK3_CU
  3. Feb 13, 2011 at 12:34 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    I forgot I had a "heavy duty" battery and 130 amp alternator. What is a heavy duty battery? more ccas, deep cycle?
    Anywho, How many spare watts/amps does that give us. I figured it out on my motorcycle, but that has like 2 circuits.
    Truck..... eesh. Can't imagine adding up maximum draw there. 130a*12v= 1560watts
    or 13.1*130=1703. Lotsawatts
    I get to about the backup lights and run out of systems I know.
  4. Feb 13, 2011 at 1:50 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    The thread title brought me in here , and I have to say I'm a bit dissapointed .
  5. Apr 23, 2011 at 9:03 PM
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    Weird cause I'm looking to put a bigger alternator on myself. My goal is to off-set the electrical load from my flexlite fan. My buddy and I have been bouncing around the idea, and it seems to end at mounting.
