Hobie Cat transporting
Discussion in 'Boating & Fishing' started by bmgreene, Feb 5, 2015.
  1. Feb 5, 2015 at 6:40 PM
    bmgreene
    bmgreene [OP] Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    Will a Hobie 16 break down for transport to the point where it'd fit in a rooftop canoe rack? thinking something like a Thule bar on the cab with a "goalpost" in the hitch so it'll clear my soft topper.
    Live near the beach and vacation in Tahoe most summers, I'm wondering about options for what I could haul back and forth without having to find storage space for a trailer.
  2. Feb 6, 2015 at 6:59 AM
    Yakoma
    Yakoma Well-Known Member
    Randy
    ATL-ish
    '14 DCSB TRD Sport 4x4 - White
    Black APS Bull Bar Black Westin Step Bars Black ARE camper top with Yakima J-cradles (replaced Roll-X Tonneau) Black AMP HD Bed Extender
    Not familiar with that particular model, but the idea of putting a 16' kayak on top of a rack 8 feet above the ground - especially alone - is kind of daunting. How much does it weigh?
    I've got a 12 footer that weighs 65 lbs and even that might be problematic. You might be able to utilize a pulley system at home, but away from home you'll be wrestling to get it on top, I would think.
    The goalpost idea seems rather flimsy. Is a TracRac possible or does the soft topper not allow for that?
    EDIT: Duh...I thought you were talking about a 16' Hobie kayak, not a sailcat. Nevermind.
  3. Feb 6, 2015 at 7:22 AM
    lock
    lock Well-Known Member
    greg
    N.W.OHIO
    tacoma
    I have owned several hobies and I would not break one down unless I absolutely had to. Even if you did put the hulls on top you still have the mast, sails, boom, rudders, lines, sheets,tramp, and a whole bunch more hardware.
    You need a trailer, breaking down is a bad idea.
    Weight wise the hulls are probably a 100 lbs. each, maybe a little more. Total weight about 400 lbs.
  4. Feb 6, 2015 at 7:43 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    How do you propose to haul the trampoline? They don't weight any thing go buy a small utility trailer at HD and make your own.
  5. Feb 6, 2015 at 9:49 AM
    bmgreene
    Brian
    L.A. Westside
    plan for carrying the cat on the roof would be to have the long rigid parts (hulls, mast, jib, booms) on the rack and the soft parts (sails, tramp, rigging) and smaller stuff like rudders in the bed of the truck, or possibly leaving the rudders on the hulls.
    At this point I'm not even sure when I'll have the money freed up to think about buying the boat, and still need to learn enough sailing to run the thing anyway. Being able to avoid a trailer would help some with the Tahoe trips since I usually caravan with friends who aren't towing anything and probably wouldn't appreciate having to slow down to 55-60 for the drive since CA has reduced speed limits for trailers. I'd also have to check the capacity on the goalpost since they're designed for canoes which are under 100 lb total; some kind of cage/contractor rack that would fit over the topper could also be an option for that as well for a bit more $$$, and I might be able to rig up some kind of retractable/removable roller for loading on and off. Might even end up with a heavier rack in the coming years anyway since I'm doing some significant work on the house.
    If it comes to it, I could probably deal with a trailer but for such a lightweight boat was hoping there might be an alternative.
  6. Feb 7, 2015 at 6:19 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    There is no reason to remove the rudders. You'll need to think about this though your roof racks are going to be pretty high and wide so you need to think about getting the truck doors open. With out a friend or two you won't be able to get the cat up there and once you get to the lake you'll need them again to get it off. I sailed Hobie's for years we even raced New Years day if the river was not frozen when I lived down south. My trailer was a small utility trailer out fitted to carry it. Lock the rudders up pull it off and push it back on.
  7. Feb 7, 2015 at 7:54 AM
    lock
    greg
    N.W.OHIO
    tacoma
    Go look at a couple of hobies, then ask the owners what they think of your idea.
    After they get done laughing they will say the same as I did.
    This really, really a bad idea.
  8. Feb 13, 2015 at 8:26 AM
    Skrumbie
    Skrumbie Member
    Stefan
    Miami
    I have had several Hobie 16's, not to mention having worked for a Hobie dealer when I was in high school. The biggest part of my job was assembling new Hobie 16's after they had been purchased. The thought of breaking one down to put it on top of a truck for transport gives me shivers! Don't do it!! Buy a real trailer that;s been set up for the boat, or don't buy the boat. You'll find it more than enough of a PITA just putting the mast up when you get to the beach.
  9. Apr 2, 2016 at 6:15 AM
    hobiecat111629
    hobiecat111629 Well-Known Member
    2015 Tacoma Access Cab
    Ok, old thread, but I have .02 for the OP if he/she is still boat shopping.
    I've owned two hobie 16s over the past 10 years and grew up sailing sunfish. I've got the following comments:
    * A hobie 16 weights in anywhere between 345 -400 depending on age and condition, so you don't want to be heaving it up there
    *Having fully assembled a boat before, I can confirm that it's a 3-5 hour task to completely assemble a boat.
    *Each dissasembly is going to loosen up the joints on the boat and after the 4th time the boat will be so loose that it sails like a turd. No good for racing.
    *its got about 26ft of mast. That's a lotta length.
    OP: The hobie 16 is a relatively easy boat to sail, but very difficult to sail well and it'll kick your ass if you're not careful. Assuming that you're still looking for a boat, the smaller hobie bravo and hobie wave are great boats.
    The bravo is small enough that it'd probably roof top great and is super easy to sail, but only holds 1-2 people.
    The 14' hobie wave is another great boat and I've seen people transport them on top of their pop up campers. Also very forgiving, but still fast enough to be fun.
  10. Apr 2, 2016 at 6:31 AM
    bmgreene
    Brian
    L.A. Westside
    Definitely a surprise to get an alert on this thread, almost forgot I started it.
    Thanks for the tips on the boats, I got the idea for hobie cats because there's typically a number of used ones for sale around the lake when I'm on vacation, so my selection would be limited to that market as far as models, although I'd be looking for something that could hold 3-5 adults plus a couple kids, but could also be managed alone as well. Also the all fiberglass construction of the hobies seems like it'd make going from fresh to salt water pretty easy when I'm home near the beach.
    I can still trailer anything in that size range, but was hoping to avoid having my speed limited to 55 for the 600 mile drives involved. I may also go with a kayak/canoe for the lake instead, but the racks to carry it on top of the truck over a soft topper will end up costing more than the boat if I do that....
