Hole in A/C Condenser
Discussion in '2nd Gen. Tacomas (2005-2015)' started by maj2505, Oct 9, 2011.
  1. Oct 9, 2011 at 7:35 PM
    maj2505
    maj2505 [OP] New Member
    Maryland
    06 PreRunner
    I have visited this forum for a while, but this is my first post. I am hoping someone may be able to shed some light on an issue I am having with the A/C in my '06 Tacoma.
    A few days ago my tacoma's A/C stopped blowing cold air. I took the truck to the local Toyota dealer and after recharging the ac and adding dye, they told me that my A/C condenser has hole in it which is allowing the freon to leak out. They told me it would cost $1500 to fix. $1100 for the part, and $400 for labor. I about hit the floor when I heard that and told them not do anything. Once I got the truck home I started pricing A/C condensers. It looks like a new A/C condenser can be easily found through common channels (autozone, napa, etc.) for less than $200. Is the dealership honestly marking the part up that much, or am I missing something? Is it possible that they meant the compressor, not the condenser? Does anyone here have any experience replacing an A/C condenser? Is it a DIY job?
    Thanks for the help.
  2. Oct 10, 2011 at 7:23 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Bump
  3. Oct 10, 2011 at 8:23 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Based on what little I know, when the system's opened up to replace a major component like the condenser it's usually not just the condenser that needs replacement. There's also a dryer and sometimes a valve they have to replace. So be sure to get prices for all the parts needed.
    Part of the job could be a DIY; but when you put it together you will need a pro with the right equipment to, at the very least, put a vacuum on it and recharge. There are a few gotcha's too. Prolly better to let a pro do the whole thing unless you REALLY know what you're doing.
    That said, I think you could get the work done a lot cheaper at an independent shop who'll not force-feed you OEM parts from Toyota.
  4. Oct 10, 2011 at 11:58 AM
    jimlindenfelser
    jimlindenfelser Active Member
    Jim
    Greenacres, WA
    05 DCab TRD
    I have removed the condensor. Pretty easy. Just need to plug all the lines to keep contamination from getting in the system. I would take it in once it is back together and have a proffessional put a vacuum on the system to remove contaminents and fill with freon. I too need to buy one still. If you look online for factory price you will see that is the price for just the condensor. I plan to go to napa or similar before next summer
  5. Oct 11, 2011 at 6:19 PM
    maj2505
    Maryland
    06 PreRunner
    Thanks for the replies.
    Given that my A/C condenser has gone out after only 60,000 miles, I place no value in Toyota OEM parts. There is no way I'm going to pay six times more to have a Toyota condenser installed. I've found a well-respected local mechanic who will allow me to buy the part and they will only charge for labor to install, vacuum the system, and recharge it. Is there any difference in terms of quality between Napa, Autozone, etc. parts?
  6. Oct 11, 2011 at 6:25 PM
    TacomaPrime
    TacomaPrime Cybertronian Tacoma
    Greg
    Illinois
    05 Prerunner SR5 TRD off road
    Look on Amazon.com for the part. I bought a brand new AC compressor there for 277 shipped! Everyone else wanted at LEAST 600 bucks for it.
  7. Oct 11, 2011 at 6:27 PM
    TacomaPrime
    Greg
    Illinois
    And don't quote me on this, but when I had the compressor replaced, everyone told me that i needed a receiver drier. however, when the mechanic went to replace it, he said it's built into the condensor.
  8. Oct 17, 2016 at 4:58 PM
    sweetstreet
    sweetstreet Member
    2010 tacoma
    i just hit 65000 miles on my 2010 Tacoma and have the same issue. i believe you have your numbers mixed up. The toyota dealership quoted me $1400 but i believe the labor is 1100 and the parts are 300.
    the reason is to get to the condenser you have to remove the whole dash.
  9. Oct 17, 2016 at 5:03 PM
    CurtB
    CurtB Well-Known Member
    Curt
    Kansas
    2010 Tacoma SR5
    The condenser is the part in front of the radiator. The evaporator is the part that is behind the dash.
    File IFR, cory02taco and ABA180 like this.
  10. Oct 17, 2016 at 5:08 PM
    sweetstreet
    sweetstreet Member
    2010 tacoma
    ok so im dumb
    wish it was my condenser.
    i bought a toyota because they not supposed to have issues this early
  11. Oct 17, 2016 at 5:09 PM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, Toytec AAL, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Toyota Wheel Locks, Extang Trifecta Cover, Fumoto Drain
    Incorrect...condenser is in front of the radiator. Evaporator is under the dash and a pain in the ass to get to. If it is the evap be ready to dig deep...either in work or your wallet.
  12. Oct 17, 2016 at 5:15 PM
    sweetstreet
    sweetstreet Member
    2010 tacoma
    yes I'm not in anticipating the work. Again the truck is only 6 years old you wouldn't expect this from a
    Toyota!
  13. Oct 17, 2016 at 5:26 PM
    Armkb
    09 TRD Sport DCLB
    If dealer said its your evap I would consider a second opinion before you dig in. May be all for nothing as could be some other part failed.
  14. Oct 17, 2016 at 5:29 PM
    sweetstreet
    sweetstreet Member
    2010 tacoma
    i have thought that but i talked to a mechanic and explained to him that i can smell the freon in the cab and he said thats what it sounds like. i might get a second opinion though,thanks
  15. Oct 17, 2016 at 5:37 PM
    Armkb
    09 TRD Sport DCLB
    Might want to check the valve and seal at the firewall before committing to the evap. If its leaking there then it could be your source of freon smell.
  16. Oct 17, 2016 at 6:00 PM
    sweetstreet
    sweetstreet Member
    2010 tacoma
  17. Oct 17, 2016 at 6:24 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Yep! The TXV is accessible from the engine bay. And as far as the smell... freon or R134A has no smell at all. You 'might' be able to smell the refrigerant oil.
    Make damned sure the leak is in the evaporator before you tear the dash apart. If it is the TXV gasket... well that gets removed when the evap is pulled. It will be replaced in any event.
  18. Oct 17, 2016 at 7:00 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Check the drain tube of the evaporator under the truck on the passenger side..... if it has oily residue on it at the end, your evap 'could' be leaking.
    Evaps are fairly bullet proof and out of harm's way. The condensing coils are the ones that are out in the open, ready to take a stone and leak out.
