Hole in cab
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lit_taco4x4, Feb 26, 2022.
  1. Feb 26, 2022 at 8:45 AM
    lit_taco4x4
    lit_taco4x4 [OP] IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
    A stereo shop drilled a hole to run a rear backup camera. The hole was drilled in the driver side bottom area of cab. Gonna re-route the wires the right way through the grommet. Lucky I didn’t do any water crossing. I’m worried about water getting in there as well as rust over time. Any ideas on how to seal the hole? RTV silicone? Metal patch?
    lynyrd3 likes this.
  2. Feb 26, 2022 at 8:51 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    In the past I’ve split a rubber grommet, slipped it around the wire and then sealed both sides with RTV.
    HisDad and hfjeff like this.
  3. Feb 26, 2022 at 8:54 AM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    If it were me, I'd want to protect it from road salt and rust.
    I would clean the hole, paint the raw edges, and then fill the hole with seam sealer and make sure it bonds to the metal around the hole.
    Depending on how big the hole is, you might be able to just close it up with seam sealer, or you might have to shove something up in the hole as a backer. Seam sealer tends to stick to metal better than rtv, and you can also paint it when you done if you want.
  4. Feb 26, 2022 at 10:00 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Depending on the size of the hole, one of these might work:
    https://www.mcmaster.com/grommets/sealing-grommets-5/
  5. Feb 26, 2022 at 10:05 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    Show us pictures of this hole.
    Malvolio, wilcam47 and 18CHUÑO like this.
  6. Feb 26, 2022 at 10:09 AM
    MENACE
    MENACE Avid toker
    2018 MGM SR5 SPORT 4x4 MANTRUCK EDITION
    boston23 likes this.
  7. Feb 26, 2022 at 10:09 AM
    tcjacado
    tcjacado Well-Known Member
    o_Oo_O
    Why the f' would they drill a hole.... there are grommets under the driver seat and the cab vents behind the rear seats. Plenty of holes to run wires without drilling new holes:annoyed::annoyed::annoyed::annoyed:
  8. Feb 26, 2022 at 10:43 AM
    Kyebasse
    Kyebasse Jd
    K
    21 Tacoma TRD Off-road
    Clean prime and paint that area and rubber around the wire and plug it like the firewall.
  9. Feb 26, 2022 at 10:44 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    A new stereo shop would be my first move. My second would be taking it to a bodyshop for an estimate to have that repaired correctly and then going back to the stereo shop to have them pay for the repair.
    There are so many holes in vehicles to access that a quality stereo installer should know about. Drilling holes is usually only done in extreme installs, like a monster sub box filling your bed.
    Edit: even you know that the wires have to be rerouted the right way... that shows how bad this installer is!
  10. Feb 26, 2022 at 5:42 PM
    lit_taco4x4
    Louie
    2018 Tacoma TRD Pro
    I will post it tomorrow. I planned on taking the truck back to the stereo shop that did it and pointing it out. I’m not having them work on it so I’ll ask for a refund. If not then yelp and google review forthcoming. Then I’ll see if I can take it to a shop to have it fixed. Or if it’s an easy enough fix then I’ll do it myself. I’ll use seam seal or RTV and find a grommet that fits. I’ll plug that in after cleaning out possible rust then painting it. They installed last year so who knows how much rust is in there if any. Thanks for everyone’s input.
    JJ Diablo likes this.
  11. Feb 27, 2022 at 7:08 AM
    Captqc
    Tigard, OR
    Treat any rust you see with this…
    ColoradoTJ and lit_taco4x4[OP] like this.
  12. Feb 27, 2022 at 8:46 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Its good you didn’t have them work on a boat!o_O
    Use a split grommet and sealer to protect the wires from chafing on the sharp hole edges.
  13. Feb 27, 2022 at 8:48 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
  14. Feb 27, 2022 at 9:05 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I agree with making them pay for a body repair.
    Now if I was the dumbass that punched a hole in my own truck I'd plug it with RV lap sealant (or even a dab of Bondo if it was bigger than 1/4 inch.)
    But if another dumbass did that to my truck, then I'd make them pay for a welder to crawl under there and put a bead on it.
    Edit: I'm mildly curious as to why you're having an aftermarket backup camera installed on an 18 Pro?
  15. Feb 27, 2022 at 4:03 PM
    lit_taco4x4
    Louie
    2018 Tacoma TRD Pro
    I wanted a second camera since I have an RLD canopy which completely blocks off my rear view since I carry Front runner wolfpacks on the RLD sliders. I don’t have BSM when I got my aftermarket steel bumper so it’s hard to see and go in to the next lane without cameras.
    Rock Lobster[QUOTED] likes this.
  16. Feb 27, 2022 at 4:05 PM
    lit_taco4x4
    Louie
    2018 Tacoma TRD Pro
    E52E8B93-8DC8-4274-B3AF-4B79EFC21401.jpg Yeah I looked closer and it’s rusted for months. You can see it on the picture. Only discovered it recently when I got new rock sliders and my installer pointed it out.
  17. Feb 27, 2022 at 4:25 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Why would they do that and not use the existing holes? Stupid shop!
    Is that the ground cable for an amp?
    Edit; nvm, cable for the camera.
  18. Feb 27, 2022 at 4:35 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Kev250R, tcBob, Malvolio and 6 others like this.
  19. Feb 27, 2022 at 4:58 PM
    lit_taco4x4
    Louie
    2018 Tacoma TRD Pro
    ColoradoTJ[QUOTED] likes this.
  20. Feb 27, 2022 at 6:46 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    That is a bit of a mess with the 2 extra “pilot” holes next to the main one. What’s more interesting is that white clip on the factory harness next to the zip-tie, that’s supposed to clip to something, so looks like the whole lot is a bit messed up. Personally I’d figure out where that white clip goes, use a grommet around the harness and silicone the while lot up, from both underside and topside. Wouldn’t let the shop touch it again, and you should probably check everything they did.
