Hole in frame, do I need to scrap my Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NeedAdvice2008Tacoma, Aug 23, 2023.
  1. Aug 24, 2023 at 5:54 AM
    MadRussian
    MadRussian Well-Known Member
    Metrowest MA
    2010 TRD OR AC
    I wouldn't be that surprised that it went from mild rust to rot in 4 years, especially if they did a bad job with prep/seal/coat. My frame was inspected/coated then failed/replaced exactly a year later. The coating was flaking off with rust under it.
  2. Aug 24, 2023 at 5:59 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Yikes! What a shame, the body looks solid. Time for a transplant.
  3. Aug 24, 2023 at 7:43 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    I'm not sure there was a frame recall back in 2011. I think it was later than that. My truck was recalled in 2018.
  4. Aug 24, 2023 at 9:29 AM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    do you woolwax fluid film or cosmoline your frame? It’s cheap and extremely easy to do yourself and I’ve seen guys in the salt belt who do it with zero rust (if they do it right)
  5. Aug 24, 2023 at 2:19 PM
    Ceedub53
    Ceedub53 Active Member
    NW Arkansas
    2006 Tacoma Prerunner Access Cab
    This...
  6. Aug 24, 2023 at 3:23 PM
    4Stents
    4Stents Roost or be Roosted
    Appleton Wisconsin
    2013 White Tacoma SR5 , w/peeling paint.
    Frame recall done
    Another Victim of the Yota bulletproof vehicle, Corporate does not care.
    Sells the Taco on drones.
    Pyris likes this.
  7. Aug 24, 2023 at 3:35 PM
    2023TRDOffroad
    2023TRDOffroad Well-Known Member
    California
    ‘23 DCSB TRD Off-Road 4x4
    My 100 series Land Cruiser died this same death earlier this year. Absolutely gutted seeing her go. For me the decision was tough, but I traded her in at the dealership (and they saw all of the frame rot) and walked out with my 23 TRD OR which I love. Or, put the money in and do a frame swap. I’m glad I didn’t, the value wasn’t there, but maybe someone is ripping apart my old 100 now and making her a beast. If that’s so, I wish him all the best, but I’m glad he’s not me.
  8. Aug 24, 2023 at 3:53 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
  9. Aug 24, 2023 at 5:10 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Chris(NJ)[QUOTED] likes this.
  10. Aug 24, 2023 at 8:31 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    Freestyle offroad Fabrication, the place in Churchville. He installed a repair sleeve on a section of my 4runner frame a few years ago.
  11. Aug 25, 2023 at 1:57 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Yup! Really great stuff. I was this >< close to doing a frame from them for my '49 you see in the avatar, but then I scrapped the whole idea and sold the truck lol. Of course, the AD frames were no where near what some of the others run. Almost a bargain, in comparison.
    Torspd[QUOTED] likes this.
  12. Aug 25, 2023 at 5:29 PM
    lynyrd3
    Bill
    East Central Upstate NY
    Welcome to TW :hattip:
    Sorry about the frame . Keep us updated on what you decide to do .
  13. Sep 19, 2023 at 4:19 PM
    DetroitDarin
    DetroitDarin Specified
    York County PA
    Scratches and Whatnot
  14. Oct 18, 2023 at 1:57 PM
    NeedAdvice2008Tacoma [OP] Member
    Hey guys, got an update! We were able to trade it into a dealership for $4000. Not a total loss thankfully.
  15. Oct 18, 2023 at 1:58 PM
    #35
    Yes!! Traded it in for $4000 at a dealership.
  16. Oct 18, 2023 at 2:04 PM
    #36
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Buying it for $16k and only getting $4k back 4 years latter def hurts :(
  17. Oct 18, 2023 at 2:21 PM
    #37
    Yes it does! Found a great deal on a suburban and had our mechanic look it over really well. There was no visible rust for the first two years at least on that Tacoma. I think someone mentioned that having it rhino lined exacerbated the issue and that sounds about right in our case.
    hyrule_trd and lynyrd3 like this.
  18. Oct 18, 2023 at 3:38 PM
    #38
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I'd be willing to bet the rust had started well before being rhino lined... it was applied to cover it up. Rhino lining isn't a rust inhibitor... that was put on there for another purpose.
  19. Oct 19, 2023 at 11:28 AM
    #39
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    That same Dealership will sell the truck to an unsuspecting buyer for $9,000.
    2 months later that buyer will be on TW asking how too fix the frame.
    Lawfarin likes this.
  20. Oct 19, 2023 at 11:41 AM
    #40
    I really hope not! They were well aware of the frame and said they were going to sell it to be parted out. There were a few salesmen who wanted it as a project. However, this was what was holding the frame from splitting in half.
    DetroitDarin likes this.
