Hole in gas tank? I think it's vandalism/theft.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ReidStylez, Jun 21, 2013.
  1. Jun 22, 2013 at 12:06 PM
    #81
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Shoot to subdue and you get sued.
  2. Jun 22, 2013 at 12:40 PM
    #82
    akhermit
    akhermit Well-Known Member
    Anchorage Alaska
    12 DCSB Magnetic Gray Metallic TRD Offroad
    Not in Alaska, if it is self defense.
  3. Jun 22, 2013 at 12:41 PM
    #83
    akhermit
    Anchorage Alaska
    Anyone can sue, but they won't win.
  4. Jun 22, 2013 at 12:56 PM
    #84
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    That sucks OP! hope they drill into a metal tank next time and blow them selfs up.
    I have and it sucks. but i only did it once! I learned my lesson like 13 years ago. I don’t know how some people do it more then once.
    also OP, when you get a new hitch get a locking pin. it will keep friends from playing jocks on you, and people from taking it agin. Mine is locked in.
  5. Jun 22, 2013 at 1:33 PM
    #85
    akhermit
    Anchorage Alaska
    The really smart ones drill a hole and install a valve. Then they only take a couple of gallons each time, that way you don't notice. They do this with several vehicles.
  6. Jun 22, 2013 at 5:54 PM
    #86
    grueinthebox
    grueinthebox Massive Member
    Texas
    Blazin' Blue 2017 DCSB
    I'm surprised to hear people talking about trying to "shoot to wound" the thief... Thought that was the first rule taught in Guns 101: never point a gun at anyone or anything you don't intend to kill.
    Getting at the original issue: I've had good luck fixing small holes in gas tanks using a machine screw, rubber-backed washer and JB Weld. Screw and washer seal the hole, JB weld keeps 'em in place. If you were to completely drain the tank first so there wasn't actually fuel leaking from it, the JB Weld alone would probably do the trick (have used it on plumbing as well and JB Weld's site confirms it's gasoline-proof). Have done that on two different cars, both times it lasted for the duration of my ownership of the car (years). Might consider trying it before plunking down a couple hundred dollars on a new tank.
  7. Jun 22, 2013 at 6:04 PM
    #87
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Is it time??
  8. Jun 22, 2013 at 6:27 PM
    #88
    grueinthebox
    Texas
    For that .gif? I can't fathom why anytime wouldn't be a good time for that...
  9. Jun 22, 2013 at 6:28 PM
    #89
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    you could try a pipe tap and plug it.
  10. Jun 22, 2013 at 6:34 PM
    #90
    Utard
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Yeah no shit.
    Just get a 3/8's pipe tap. Drill the hole out to a 5/16 or 11/32 or whatever the 3/8 tap calls for? Then either get a brass or PVC 3/8's plug and with a little teflon tape and plug that hole up.
  11. Jun 22, 2013 at 6:37 PM
    #91
    bullaculla
    Da big big island!
    3/8 NPT drill size is 9/16.
    If the hole is small enough, 1/4" pipe could work since the drill size is 7/16.
  12. Jun 22, 2013 at 6:47 PM
    #92
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    Anyone stealing gas sure isn't doing it to feed his/her family, I can guarantee that.
    These are the same people who sleep all day while you are at work, and come out from under their rock late at night to steal/rob/vandalize your hard earned shit.
    One doesn't need to resort to a firearm to protect oneself, who's to say Scummy McShitbum didn't have static electricity on him when he drilled out your tank and suddenly got crispy?
  13. Jun 22, 2013 at 6:50 PM
    #93
    Utard
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Yeah now that you say that the 3/8 is a little beefy.
    Just make sure you have a plug for the size you are doing before you drill.:eek:
    But I would for sure use pipe thread before bolt thread. Because it is tapered and will seal better.
  14. Jun 22, 2013 at 8:54 PM
    #94
    BamaToy1997
    Bill
    Navarre, FL
    Well if I find a tap and valve installed in the bottom of my gas tank, I will know who to have questioned first now!:rofl:
  15. Jun 22, 2013 at 9:50 PM
    #95
    akhermit
    Anchorage Alaska
    That is just what I have heard that the "professional" gas thieves do now, not me. I haven't siphoned gas since I was a kid, and back then all you needed was a piece of hose and your mouth.:eek:
  16. Jun 23, 2013 at 8:32 AM
    #96
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    You've missed the forest for the trees. Sending PM.
  17. Jun 23, 2013 at 11:14 AM
    #97
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Put in a fumoto valve so the thief doesn't have to waste time drilling a hole and you can re-fill without having to go through the hassle of sealing the hole.:wink:
  18. Jun 23, 2013 at 1:44 PM
    #98
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    The person is a thief, a piece of shit. Breaking the law, on the look out, and very nervous... because he's a low life stealing, and he knows it's wrong.
    Yet if I engage him and kick his ass, people defend him, fuck that
  19. Jun 23, 2013 at 2:39 PM
    #99
    tensecondchevelle
    tensecondchevelle Well-Known Member
    Eric
    Mesa Arizona
    2006 Tacoma Double Cab
    Well said
  20. Jun 23, 2013 at 3:22 PM
    #100
    Marc702
    Marc702 Well-Known Member
    Marc
    Las Vegas
    DC/PRERUNNER
    There's a time and a place for all discussions.......but this thread should.......
    :stayontopic:
    Went from a hole in a gas tank to justifiable homicide......sheesh...:notsure:
