Hole in Muffler - What should I do?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wrtoyota, Nov 13, 2022.
  1. Nov 13, 2022 at 3:09 PM
    TRD Ted
    TRD Ted Well-Known Member
    2020 Army Green TRD Pro
    Fill it will some fire stop caulk.
  2. Nov 13, 2022 at 3:11 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
  3. Nov 13, 2022 at 3:11 PM
    wrtoyota
    wrtoyota [OP] Well-Known Member
    If we didn’t have emissions testing I would do this to fix the Corolla…
  4. Nov 13, 2022 at 3:13 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    just patch it. not exactly a complicated part. just a can with a hole in it.
    wrtoyota[OP] likes this.
  5. Nov 13, 2022 at 3:16 PM
    OnHartung'sRoad
  6. Nov 13, 2022 at 3:20 PM
    carlk
    carlk Well-Known Member
    Virginia
    2022 MGM SR 2.7 Access Cab Utility Pkg
  7. Nov 13, 2022 at 3:22 PM
    eurowner
    eurowner Duke Sky
    Scoty
  8. Nov 13, 2022 at 3:35 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Bwhahaha. OP get's small hole in muffler that could be welded by a small shop, but goes all out and buys a welder and does it himself instead....
    I like this guys style....
  9. Nov 13, 2022 at 3:45 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Grind the area, use angled tool to pull piece inside hole back out to as close to the rest of the muffler, weld [spot weld if you need to] hole closed. If you don't have a welder, find a GOOD independent muffler place and have them do it.
  10. Nov 13, 2022 at 3:55 PM
    Clearwater Bill
    Billy
    Largo Florida
    Refit the piece as close as possible and leave it alone. Nothing is hurt, maybe a pinch noisier, but certainly not by much.
    In the mean time follow your regional forum, find someone dumping their OE exhaust to clear the garage, then swap on that new-to-you muffler at your leisure.
    No reason to make life complicated or expensive for this situation.
    tcjacado, Bagman and blu92in99 like this.
  11. Nov 13, 2022 at 4:03 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Lots of suggestions. This may reach 4 pages ove the next few days. Make a decision!
  12. Nov 13, 2022 at 4:22 PM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Turn it in to your Insurance Company. You hit an object kicked up by another vehicle on the roadway obviously. Should be covered under Comprehensive Coverage. Give it a shot!
    Get an estimate for Replacement from the Toyota Dealer. Worst case, maybe it can be patched?
  13. Nov 13, 2022 at 4:24 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Drink a beer. Cut the can in half, smear it with JB Weld and slap it up under there. Drink the other five beers and admire your awesome handiwork.
  14. Nov 13, 2022 at 4:32 PM
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
  15. Nov 13, 2022 at 4:35 PM
    #35
    Clearwater Bill
    Billy
    Largo Florida
    Did similar on a '73 Hornet with small sheet metal screws and piece from a Coke can. JB around the edges. Worked fine for the 2 years I flogged that thing.
    tcjacado likes this.
  16. Nov 13, 2022 at 4:59 PM
    #36
    wrtoyota
    I was mainly making sure there was no concern for damage beyond the hole. I welded a lot growing up - grandparents have a small trailer company. Now I have a house and even better: an excuse to buy a welder I use once a year. I'll post again when I fix it. Pretty thin material but I bet if I roll a piece of stainless and just tack around the perimeter it'll look good. Will try peeling out the cut piece and tacking around that first.
    Also, any concern over this muffler should be balanced against the grief resulting from the assault on my beautiful '08 Corolla. The catalytic converter was cut from it by some junkie. Not to mention first new vehicle paranoia...
    3JOH22A and Delta09[QUOTED] like this.
  17. Nov 13, 2022 at 5:03 PM
    #37
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Hah, yea I bought a complete MIG setup to repair rust on an old project car I had (which the setup was honestly worth more than the car...) but since the rear sub frame pretty much almost caved in on me lifting it up (rust) I gave up on it and haven't used the welder in a year :laugh:
    But, if I ever need to do a project it's there. I have friends with older trucks and tinker with a mower or two so it'll see use occasionally.
    wrtoyota[QUOTED][OP] likes this.
  18. Nov 13, 2022 at 5:15 PM
    #38
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    Get a new muffler, why is this an issue?
  19. Nov 13, 2022 at 10:05 PM
    #39
    Wicked_Taco
    Wicked_Taco Well-Known Member
    Wick
    PA
    ‘21 SR Utility 4x4
    I’d fill the hole with some kind of refractory adhesive made by Resco or Vimasco. I’ve done it to the head pipe on my wife’s old car…
    Get a new muffler
  20. Nov 13, 2022 at 10:07 PM
    #40
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    I gave away my 2019 OEM exhaust when I upgraded. Lots of one’s online for super cheap!
