Hole in the floor board?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kkantala, Sep 7, 2009.
  1. Sep 7, 2009 at 4:04 PM
    kkantala
    kkantala [OP] Member
    I've been getting a lot of water on my floor board, and its got to the point where i can take out my mats and stomp my feet and water will fly everywhere. Anyone have ideas of why this is?
    Thanks,
    Ken
  2. Sep 7, 2009 at 4:08 PM
    fghtngsquirrel
    fghtngsquirrel Ka-freakin'-BOOM!
    Jacksonville, FL
    '08 4x2 Rad Red *SOLD*
    Is this a 1st or 2nd gen? Is the water only in the front or in the backseat (if you have a backseat)?
    A few months ago I ran into the same issue with my '08 DC. I took it to the dealership, and it ended up being the gromet around the radio antenna. They ended up having to replace the entire carpet under warranty, and I haven't had any problems since.
  3. Sep 7, 2009 at 5:46 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Do you have any windows that are leaking? Remember water will travel down not up so most likely the origination of the water leak is not on the floor. Look along the firewall and the backside of the front wheel wells. Is the whole floor wet? Is it just wet on a specific side? Are you leaving the windows down when it's raining(have to ask)?
  4. Sep 7, 2009 at 5:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to TW! What year and modle truck?
  5. Sep 7, 2009 at 5:51 PM
    kkantala
    The whole floor board is soaked (only the front) . passenger side and driver side. My windows are always up. Its an 08 tacoma with access cab.
  6. Sep 7, 2009 at 5:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It could either be the AC tube came undone from the fire wall (it would only be the passenger side though) or the windshield seal is compromised.
  7. Sep 7, 2009 at 5:58 PM
    kkantala
    Just 2 weeks ago I had my windshield replaced, but it has been leaking before the replacement.
  8. Sep 7, 2009 at 6:18 PM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    Take your front seats out, and ask a friend to take a hose and spray your truck. Sometime there is a leak in the fire wall behind the heater unit due to bad welding or a spot left un-welded in a seam.
  9. Sep 7, 2009 at 6:20 PM
    fghtngsquirrel
    Jacksonville, FL
    This sounds EXACTLY like what happened with my '08. I would take it to the dealership and have them check it out. They ruled out the windshield first, mentioned nothing about the A/C, and then started taking out the entire interior.
  10. Sep 7, 2009 at 6:26 PM
    kkantala
    I've been to the dealer and they sprayed a hose on the top of my truck, but couldn't find anything. They also told me to clean out a little hose under the hood, and I did, but it didn't change anything. I don't think the A/C could cause so much water during a rain or does it?
  11. Sep 7, 2009 at 6:27 PM
    fghtngsquirrel
    Jacksonville, FL
    If your truck is under warranty, I would tell them to fix it...
  12. Sep 7, 2009 at 6:28 PM
    glandnut
    glandnut Grease Monkey
    Florida
    09' MGM TRD DC Sport LB(gone), 16' 4Runner Trail
    secret stuff.
    heater core
  13. Sep 7, 2009 at 6:32 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    x2 on the heater core. Does it smell like antifreeze?
  14. Sep 7, 2009 at 6:42 PM
    kkantala
    It smells like wet socks.
  15. Sep 7, 2009 at 6:44 PM
    fghtngsquirrel
    Jacksonville, FL
    That's exactly what mine smelled like, mixed with mildew. I didn't think they were telling the truth with the antenna grommet, but you should check it out...
  16. Sep 7, 2009 at 6:49 PM
    rngrchad
    rngrchad Yankee Oscar Tango Alpha
    The former USA now USSA (United States Socialst Am
    08 Rugged Trail TRD
    Rockwell 30 ton axles.
    My 1997 Tacoma did the same thing. It was the pinchweld along the rocker panel.
    NOTE: this was not an 08 tacoma. Just maybe check out your rocker panels.
  17. Sep 7, 2009 at 6:53 PM
    kkantala
    Thanks for throwing out ideas, I'm going to print out what you guys had to say and show it to the dealer tomorrow. Hopefully they will find the problem and I will let you guys know when I find out.
  18. Sep 7, 2009 at 6:54 PM
    fghtngsquirrel
    Jacksonville, FL
  19. Sep 7, 2009 at 7:00 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    The AC will run anytime you set the heater controls to defrost or Defrost/Floor, it is used to dry the air before blowing on the window.
    Take it back to the dealer and tell them to fix it
  20. Sep 7, 2009 at 7:40 PM
    dexterdog
    Oly WA
    2012 F150
    For the leak to be HVAC related and for both sides of the floor to be wet it would have to be over the tranny hump.
