Hole In Tire Sidewall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by big_jarv, Apr 13, 2016.
  1. Apr 14, 2016 at 12:48 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    ok
    there is no center diff in pt 4wd
    open diffs in front and open diffs in back don't matter, it is the
    front prop shaft vs rear prop shaft
    if front tires are different diameter than the rears with part time 4wd
    you always are in a tire-scrubbing scenario...and all that fightin energy is focused in
    the transfer case
    if tires are equal then you only go in scrubbing mode when turning front wheels or in any type of turn
    offroad less worry about vehicle wear and driveline wear, but more worry about slipping off the road
    as one or the other sets of wheels is always slipping more than if diameters was equal
    on pavement the tires will slip but they will fight that slip and the transfer case has to eat it somehow
    so, if you have 10,000 miles on one set of tires and zero on the other, you get slight problem
    if you have 20,000...more problem
    if you have all 4 same mileage and rotate them every 5000 miles, practically no problem
    people say well don't drive in 4wd on pavement. yes of course, but anyone who knows anything about 4wd in
    winter knows the road is often clear in some patches and it is inevitable you will do some type of dry road action in 4wd.
    I am just sayin...if someone is asking 'should I replace all 4?" well fuck yes obviously the truck will
    function better in all regards 2wd or 4wd on road or off road traction will be consistent with the same
    age and same mileage meats installed.
    if you have AWD it matters a ton less. if you stay in 2wd it matters a ton less. it's all percentages..
    the end result is the more the front is different than the back as far as equivalent gear ratios,the more issues that can happen
    increased wear and decreased traction is what happens
    Just Dandee[QUOTED] likes this.
