Holley blue fuel pump
Discussion in 'Buy / Sell / Trade' started by taco06, Apr 8, 2010.
  1. Apr 8, 2010 at 6:06 PM
    taco06
    taco06 [OP] Well-Known Member
    Alex
    pomona ,California
    06 sprt
    I can't let the wife know
    Less than 20hrs of use.. Had it on my drag car....Gone now :(
    Features
    •Tumble polished billet look
    •New lower housing casting for enhanced fuel flow
    •Motor draws only 3 amps current
    •7 1/2 amp fuse recommended
    •Improved design for street/strip applications
    •Distinctive “BLUE” logo
    •Flows 110 GPH (free flow)
    •Flows 88 GPH at 9 PSI
    •Maximum pressure is 14 PSI
    •Includes P/N 12-803 fuel pressure regulator
    •Provides constant fuel flow with no pulsation
    •Has externally accessible pressure relief valve (max 14 PSI)
    •Rotor/Vane pump design is more tolerant of contaminated fuels
    •Weighs only 3 lbs
    •Includes mounting bracket
    •Repair kits are readily available
    •Can be serviced from the pump end
    •NOT compatible with alcohol or methanol fuels
    •Use of safety shut-off switch, P/N 12-810, strongly recommended
    •Not designed or recommended for use with fuel injection systems
