Holset VGT 5VZ-FE turbo build
Discussion in '1st Gen. Tacomas (1995-2004)' started by anothernord, Dec 2, 2015.
  1. Mar 22, 2016 at 11:53 AM
    #121
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea Id want a built LCE block to run that high of pressures.
  2. Sep 13, 2016 at 11:56 AM
    #122
    anothernord
    anothernord [OP] Well-Known Member
    Northern Colorado
    Various Toyotas
    DCLB Manual
    A non-update update:
    The truck is running great. I've put probably 8,000 miles on it with only two small hiccups:
    1) I ended up ditching the fancy, electronic PCV switching solenoid. The solenoid seemed to be sticking sometimes, which would, of course, cause pressurization of the crank-case. I switching to simply running the valve cover breather into a Moroso air/oil separator. It seems to work fine.
    2) While flying up I-70 at 11,000 feet at 80 MPH, the A/C hose that runs near the turbo melted and exploded, sending a cloud of refrigerant onto the road. There is a new hose with a generous amount of tube heat-shielding.
  3. Oct 9, 2016 at 12:38 PM
    #123
    amalik
    amalik Well-Known Member
    Denver
    Mind posting a final pic of the truck? I thought you mentioned the hood wouldn't close when this project started..?
    Also if you have a video of it running, I'd love to hear it.
  4. Oct 9, 2016 at 2:49 PM
    #124
    anothernord
    Northern Colorado
    Various Toyotas
    DCLB Manual
    There's a picture of the engine bay on the first page, and yep I mention earlier in the thread about having to cut a hood support out to get clearance. I also stuck a couple washers underneath the brackets to get a little extra breathing room.
  5. Oct 13, 2016 at 11:20 PM
    #125
    amalik
    Denver
    I meant a pic of the truck itself with the work all complete. But anyway, it's cool, don't worry. Congrats on a cool project finished :)
  6. Oct 28, 2016 at 2:46 PM
    #126
    anothernord
    Northern Colorado
    Various Toyotas
    DCLB Manual
    Oh, duh. Yeah here's a recent shot of a random Friday-after-work camping trip and another with some friends on a quick cruise to Aspen.
  7. Nov 14, 2017 at 7:52 AM
    #127
    Ricky876
    Ricky876 Well-Known Member
    2002 Toyota Space Cab
    Under construction
    ive read thru the thread and have followed some of your methods for turboing my truck
    my question though do you have an oil pressure gauge installed and what are the readings you've been getting?
    what grade oil are you using?
  8. Nov 14, 2017 at 8:27 AM
    #128
    anothernord
    Northern Colorado
    Various Toyotas
    DCLB Manual
    No oil pressure gauge. But the oil pressure should be whatever the engine manual says it is. I'm assuming you're wanting to set the flow to the turbo. I was using regular 5w30.
  9. Nov 14, 2017 at 12:01 PM
    #129
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    The 5vz Tacoma on Youtube (with the lady driver) was at 20psi, with forged rods only... I wonder if they upgraded after a break, or just proactively? She was always pretty vague with answers on her channel. And at what point do you start worrying about head gaskets?
  10. Nov 14, 2017 at 12:08 PM
    #130
    Ricky876
    Under construction
    Yea thats correct
