Home Audio reciever questions....
Discussion in 'Off-Topic Discussion' started by chris4x4, Jan 1, 2011.
  1. Jan 1, 2011 at 1:13 PM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Are there any 5.1 receivers out that have a sub output that has about 100 watts, or more, to the sub?
  2. Jan 1, 2011 at 1:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    dam.....My sub is un powered....
  3. Jan 1, 2011 at 1:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No...Its a few years old, but sounds great.
  4. Jan 1, 2011 at 1:37 PM
    757southpaw
    757southpaw Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    Hard to find a reciever with a designated speaker level subwoofer output I'm sure. Does your sub have speaker outputs? If so you could get a 5.1 reciever with a 100w output on the mains (A channels), cennect your subwoofer from it and then to the front speakers. Only problem with that is it's not true dolby digital.
  5. Jan 1, 2011 at 1:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No speaker out puts. Just the 2 that go to the sub.
  6. Jan 1, 2011 at 1:52 PM
    757southpaw
    Jay
    757
    Does your current receiver have a line level subwoofer output?
  7. Jan 1, 2011 at 2:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No. Sub isnt hooked up either...Just sitting in the corner.....alone......and depressed......
  8. Jan 1, 2011 at 4:15 PM
    757southpaw
    Jay
    757
    :frusty: Sheeez....sounds like you need a new receiver and subwoofer...time to upgrade :p
  9. Jan 1, 2011 at 4:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL!! Yeah...My Current unit is a Pioneer 5.1 reciever, but I think Im loosing a few inputs.....There is a "Buzz" or high pitched Humm, comming from the "VCR" and "CD" input. So far, the "DVD" input is fine.....
  10. Jan 1, 2011 at 4:33 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    It needs some valium...
  11. Jan 1, 2011 at 4:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think Gunner pee'd on it....
  12. Jan 1, 2011 at 4:36 PM
    oldtacomaguy
    Dave
    SE Conn.
    Make that two valiums:D
    Last year my sub stopped working. I took it apart and found that a mouse had been living in there.:eek:
  13. Jan 1, 2011 at 4:37 PM
    757southpaw
    Jay
    757
    YAMAHA RX-V#### and a Velodyne sub FTW!!
  14. Jan 1, 2011 at 4:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, THe Sub works fine. My Last receiver had an powered sub output, and since I replaced it, I havent had it hooked up. I may install an amp in it........or.....just leave it lie....
  15. Jan 1, 2011 at 4:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The receivers Im considering are the Pioneer, Onkyo, Denon, and Integra.
  16. Jan 1, 2011 at 4:40 PM
    oldtacomaguy
    Dave
    SE Conn.
    Mine is an Onkyo, I've had it about 4 years now with no problems.
  17. Jan 1, 2011 at 4:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah...Onkyo is a quality unit from everything I have read. I like the simplicity of the Denon though....
  18. Jan 1, 2011 at 4:46 PM
    757southpaw
    Jay
    757
    FWIW I was in the A/V industry for about 10 years as an installer than moved on to design/sales and project management. Before you choose, definately take a look at the YAMAHA line. I'm rocking the RX-V1700!
  19. Jan 1, 2011 at 5:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I'll check them out, But Im not looking to spend much cash.....Yamaha is definately great stuff! Hell....Im running their speakers :)
  20. Jan 1, 2011 at 8:04 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Why not install a plate amp into the sub so it will be a powered sub? Easy as pie. What sub do you have? Check PartsExpress.com for some amps.
