Home Defense: 9mm Semi-auto or 7.62x39mm AK-47?
Discussion in 'Guns & Hunting' started by 28ØØ3, Dec 9, 2010.
Which one for home defense?
  1. 9mm Semi-auto pistol
    78.5%
  2. 7.62x39mm AK-47 rifle
    21.5%
  1. Dec 9, 2010 at 5:44 PM
    #61
    m0nster986
    m0nster986 ♥ Emergency Medicine
    SoCal
    OP's options where 9mm or AK. I don't see shotgun up there...
    I voted 9mm
  2. Dec 9, 2010 at 6:16 PM
    #62
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2
  3. Dec 9, 2010 at 6:23 PM
    #63
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    x3!
    but has anyone every shot a wad of birdshot at an abandoned car door, close range? it is like a fistfull of lead. tight, and hard hitting. inside a home it would be devastating. outside, not so much.
  4. Dec 9, 2010 at 6:26 PM
    #64
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    Taurus Judge...
    This is how to stop someone... And wake up your entire block at the same time.
  5. Dec 9, 2010 at 6:30 PM
    #65
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    I voted 9 by the way. Probably not a good idea to risk killing your neighbors neighbor.
  6. Dec 9, 2010 at 6:31 PM
    #66
    j83soldier
    j83soldier Well-Known Member
    joshua
    Colorado
    05 tacoma
    anti lock brake disable mod, fogtime anytime mod, Leer Topper, all pro plate bumper, toytec 3 inch lift, bfg AT, rims, piaa 5100's, some double din head unit (cant remember), warn 8000 winch, DO sliders, hacked frame to fit full size spare, thule and yakima roof racks
    ^ that is awsome
  7. Dec 9, 2010 at 6:41 PM
    #67
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    AK if you live on a 10,000 acre ranch with mountains bordering all sides.
    9mm will terminate your target, providing you hit it.
    AK will terminate your target, and all the rest of the targets behind it.
    Your kids, wife, neighbors, family dog, etc, etc.
    Unless Concrete or Steel interfere.
    Each has it purpose
    "Bullet Placement"
    CC
    ps: Didn't read the thread. I assume I've repeated most of the posts.
  8. Dec 9, 2010 at 6:52 PM
    #68
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    X1
  9. Dec 9, 2010 at 7:31 PM
    #69
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Regular 7.62x39mm isn't going to kill your neighbor. It may penetrate a cinderblock wall if shot squarely, by then it has lost too much energy to do much else.
    There are numerous recorded cases where it took 7-8 rounds of 9mm to stop an attacker. Consider a large-frame intruder with a heavy jacket, maybe on drugs. How long does it take for an intruder to cross the length of your living room? If he's armed with a crowbar?
  10. Dec 10, 2010 at 6:57 AM
    #70
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    theres plenty of cases where a single .22lr has killed a person too...and ive seen cases of people being hit with .45 multiple times and surviving
    every round can be lethal...its all about shot placement
    i have 2 thoughts concerning what to use for home defense
    1, if youre trained in building clearing and feel comfortable enough to do this safely...a pistol is where you should go...period
    2, if you're planning on squirreling away in a back room (which is what the majority of you should be doing) and calling 911...arm yourself with a shotgun...do NOT rack the slide to "scare" the intruder...you'll give away your position...and in your house in the dark...you have the tactical advantage...no point in helping them out
    What most people are overlooking though, is that most home invasions, or burglaries, occur during the day while you're away at work
    Burglars watch neighborhoods, and they know when people are around...they watch your trash to see what kind of stuff youre buying...just like you dont ever want to meet them face to face...they also dont want to come thru your window and meet you
    do some sort of strenuous exercise before shooting...get the heart rate up...then focus on the target
    practice shooting with 1 hand (both)
    practice what to do when the gun doesnt go bang
    etc etc
    Too many people just buy a shotgun, throw some shot in there and call it good
    Take that gun out and check out the patterns at different distances that you may encounter in your home
    I dont believe in lights or lasers attached to the gun, but rather opt for a flashlight held by my non-dominant hand off to the side
    say youre walking thru your home investigating a bump in the night with your flashlight and that person who is entering your home intends to do you harm to protect himself...you flash that light thats attached to the gun...or the laser...he now has somewhere to aim...if your flashlight is held off to the side by your non dominant hand...and he aims towards the light...you have a LOT less chance of getting hit
  11. Dec 10, 2010 at 7:04 AM
    #71
    V-TRAIN
    V-TRAIN Well-Known Member
    N. CACKALACKY
    08 TRD SPORT LONG BED
    DEMELLO ROCK CRUSHER SLIDERS, PIAA LIGHTS, TSB 4 LEAF PACK, CBI OFFROAD REAR BUMPER LINEXED, CBI OFFROAD FRONT BUMPER LINEXED, REAR 5100's, 1.5" TSB AAL, ICON EXTENDED TRAVEL COILOVERS @ 3", TOTAL CHAOS UCA's, HELLA MICRO DRIVING LIGHTS, IPOD INTERFACE, THULE ROOF RACK, UWS SLIM LINE BLACK TOOL BOX, 17" BBS RD TRUCK WHEELS, GOODYEAR WRANGLER DURATRAC IN 285/70/17
    i use an alarm system. have sign at street, at side door, front door, and stickers on all the first floor windows. i have guns also, but i think the alarm is all i need.
  12. Dec 10, 2010 at 7:07 AM
    #72
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im considering getting a sling shot...No Over penetration, and it should give the intruder a good sting, letting them know Im Serioz!
  13. Dec 10, 2010 at 7:10 AM
    #73
    SuperTacoma
    SuperTacoma Well-Known Member
    Clint
    Georgia
    2019 Double Cab SR5 4x4 Silver
    I am a fan of the Judge.
    I have 3 of them. I finally got the SS that shoots the 3" 410 Mags.
  14. Dec 10, 2010 at 7:13 AM
    #74
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    maybe a spit wad, and a straw.......and aim for the eyes.....
  15. Dec 10, 2010 at 7:20 AM
    #75
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    The funny thing is, you're agreeing with me. I mean, 00 is better than #4 buck for stopping power. Absolutely. But as my first post said, #4 is COMPROMISE between stopping power, and less likely to overpenetrate.
    Yeah, know where your walls are, again we agree. But planning not to shoot at a particular wall is poor planning. I'd rather have the idea that the wall seperating me from my kid WILL be hit, and plan accordingly. Not cuz I can't shoot straight, but rather b/c adrenaline, poor lighting, target movement, etc will pretty much ensure that not every round downrange will hit a BG, and stop IN the BG (remember that word, OVERpenetrate?) I think you're focusing on shooting a wall point blank, whereas I'm talking about hitting your target, the bullet passing through, and then hitting the wall.
    Anyway, FWIW, I've seen probably 40+ folks shot with shotguns. None died. Those that did stayed on scene, not came to the hospital, so I can't comment on the rounds used.
  16. Dec 10, 2010 at 7:43 AM
    #76
    Zulu Six
    Zulu Six Well-Known Member
    North Carolina
    2005 Tacoma Double Cab SR5
    I'm guessing that the 9mm handgun was shooting a FMJ bullet. FMJ bullets do not expand and as such, often times punch right through their intended target. Any decent JHP or frangible bullet will fix that.
    FWIW, the 9 vs. 40 vs. 45 debate is a circle jerk. There are differences between how much ass each round brings to the table, but in the real world the differences are pretty much nonexistent. General rule of thumb with a handgun: 1) Shot placement is key. 2) Anyone worth shooting once is worth shooting a dozen times.
    OP: A good 12 gauge, pump action shotgun with a light, Modified choke and 00 buckshot would be an ideal set up. It's a show stopper. The AK is an awesome weapon, but poorly suited for your needs. Now, if you need one gun to do it all - as in a gun that you plan to carry with you and then keep on the nightstand - find yourself a good pistol. All of the major manufacturers are turning out good stuff these days.
    Oh, and "racking the slide" to scare away the bad guy is retarded and a good way to get Sean Taylored. I would immediately distrust anyone who recommended it. It can serve no purpose but to give away your biggest advantage: it lets the bad guy know exactly where you are (kinda like laser sights).
  17. Dec 10, 2010 at 7:45 AM
    #77
    Zulu Six
    North Carolina
    Dude. Really? I mean they are fun little guns to play around with at the range, but for self-defense? What's the point?
  18. Dec 10, 2010 at 8:07 AM
    #78
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    I'm really NOT agreeing with you, at all. I'm saying #4 will still penetrate drywall and NOT do the job.
    And if you shoot a wall with your kid behind with with #4 buck, it will STILL go through. Try it or go look at box o truth where #4 BIRDSHOT goes through 2-3 sheets of sheetrock. How far will buck go then, buddy?
    Lastly, of course I'm talking about missing and hitting a wall. You're confusing your own arguments:
    First, you can't avoid walls with your kids behind them in the middle of the night because you're confused and tired with adrenaline going. Then, the only way your #4 buck will hit that wall is if it hits your target and passes through?
    Which is it?
    Lastly, ever shot a... buck with 00 buck? Doesn't do a whole lot of penetration once it encounters a human target, does it?
    Exactly.
  19. Dec 10, 2010 at 9:14 AM
    #79
    aficianado
    back to bone stock.
    no..harsh language. cuss alittle bit..really get "dangerous"..hahhah
    tell him to leave!! NOW!
  20. Dec 10, 2010 at 9:21 AM
    #80
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    I think the Judge is an awsome little defense piece.
    http://www.winchester.com/Products/New-Products/Pages/pdx1-410.aspx
    This is your best option for defense.
    3 slugs plus shot X 6 as fast as you can pull the trigger?
    Like having 3 45acp rounds plus shot going off with each trigger pull.
