Home defense
Discussion in 'Guns & Hunting' started by Scoobarooo, May 30, 2020.
  1. May 30, 2020 at 10:44 PM
    TheTacoMarine
    TheTacoMarine Well-Known Member
    2016 Tacoma TRD Sport
    I would step away from shotguns and AR's in the off chance you miss you will be going through walls and everything else. Then it becomes a concern who is on the other side of every wall. Rather get yourself a Glock 19 or 17 pretty reliable and relatively cheap. Look at Springfield XD's as well.
    Best advice is go to the gun range and shoot a bunch of different guns they have and that will help guide you.
  2. May 30, 2020 at 10:47 PM
    jacobswx
    jacobswx Well-Known Member
    Colorado
    2020 Cement Tacoma TRD Off Road
    For sure. But there is always the chance they are high on something. Definitely could cause that.
    JimBeam likes this.
  3. May 30, 2020 at 10:48 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    To add
    Follow up shots are way slower with a shotgun, the racking sound doesn’t scare off someone who’s intentions are to hurt your family and only give away a huge tactical advantage, reloads are not even close to intuitive for anyone outside of a competitive world, they’re actually harder for most people to handle, they are easy to take away if you go beboping thru your house looking for the noise, birdshot is basically worthless on stopping someone
  4. May 30, 2020 at 10:49 PM
    TacoTuRD18
    TacoTuRD18 Well-Known Member
    2018 Tacoma TRD OR
    I bet just the sound of racking a shotgun would be a pretty good deterrent for the person breaking in.
    Slashaar and Fernando like this.
  5. May 30, 2020 at 10:50 PM
    JimBeam
    JB
    2015 Tundra
    It’s not
  6. May 30, 2020 at 10:51 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Maybe, but that's not something I'm going to bet on keeping me alive. Not to mention, my stuff is loaded so that racking sound is ejecting one of my eight shells I have to work with.
  7. May 30, 2020 at 10:56 PM
    Loco_Barbon
    Loco_Barbon Just deez nutz hangin’ out
    Hugh Mungus
    Where ever my 10mm isn’t
    i LiKe tRuCkS!!
    Penis valve stem caps.
    So you're telling me that if you had someone pop off two rounds in a hall way, in the dark, with no hearing protection you would keep approaching that person. This topic is like asking people if they put peanutbutter and then jelly, or jelly then peanutbutter. I know for a fact that there isn't a person out there that would let me shoot them with a .22 or a .460 so what difference does it make. The best home defense gun is the one you are most proficient with in the dark, disoriented, and in a panic. You're hands will be shaking do to adrenaline so I'll take a 2" spread over 9mm any day of the week.
    davidstacoma likes this.
  8. May 30, 2020 at 11:06 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    An AR is THE most effective gun for defense.
    There are plenty of links and information on the net with general summaries of information however I don’t agree with everything out there, take take information as you will.
    Handguns fail to have the speed to cause the amount of tissue damage and hydrostatic shock that a rifle cartridge will provide. The relevance is to stop a threat “right now” even without a perfect head or CNS shot. Penetrating organs alone isn’t enough to cause immediate stop to a threat.
    While people get wrapped up in walls and over penetration, if you live on the western side of the United States, you have drywall. Basically paper and 2x’s. A shotgun with buck shot and or a handgun, will still penetrate the wall, and as stated, birdshot is not effective at killing.
    So it comes down to over caution and use a less effective tool, or make proper planning for a home defense situation and working around over penetration for a more effective cartridge. Early detection and deterrence is your friend. After that, you can’t be half in or half out, the only way then is to use complete and utter lethality if it comes to it. A shotgun might fill that, but a good AR will fill that for about 5 intruders on one mag, and can maintain effectiveness in even the longest hallways, and allowing for a better aiming solution and follow ups then a shotgun, for those that know what it means to zip up, and zip down. It’s not really about the gun though. It’s about the smart decisions, pre planning and tactical proficiency that makes the difference.
    gotoman1969 and JimBeam like this.
  9. May 30, 2020 at 11:09 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Yep, had way more rounds fired at me in the dark and still kept approaching. I get the attraction to a slightly larger spread but the downsides of reduced capacity and harder handling far outweigh that in my opinion. The widespread notion that shotguns are best because of their huge spread and point em that way idea leads to a lot of bad information. Fully agree with your statement about the best firearm being the one you are proficient with.
    Front sight, YOTA 4X4 and JimBeam like this.
  10. May 30, 2020 at 11:24 PM
    k5driver
    k5driver I hate bums
    Montana
    2009 4x4 DCSB MT SR5
    I vote shotgun and I like the mossberg 500. Get the 18.5" barrel (shorter mag tube) and you can swap in a nice longer barrel anytime and go shoot birds or clay.
    I saw an earlier post- pistols will penetrate a lot of drywall too. Check out this website: https://www.theboxotruth.com/the-box-o-truth-1-the-original-box-o-truth/
    These old guys shoot at everything; lots of good reading and pictures on there. Good luck with your choice.
  11. May 30, 2020 at 11:38 PM
    Scoobarooo
    Scoobarooo [OP] Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    Not a chance. Lol
  12. May 30, 2020 at 11:45 PM
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    Lots of good information here! For those talking about going through walls... I live in a block house, so I’m not to sure that’s a worry for me.
    RobP62 likes this.
  13. May 30, 2020 at 11:52 PM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    Where do you people live that you have concerns of 5 or more people breaking into your house in the middle of the night bent on a shoot out? You all living in Walter Hill movies out there?
    Sig45, shane100700 and uurx like this.
  14. May 31, 2020 at 12:10 AM
    CdnSldr
    CdnSldr ______________
    Canada Eh!
    With cylinder bore, lots of buckshot will open up to 6-7” by 30’. Gotta test your ammo and buy accordingly.
    SC4333 likes this.
  15. May 31, 2020 at 12:17 AM
    #35
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    Agreed. A home defence situation is in most cases going to be close quarters and the last thing you need is to be swinging a barrel around. Imagin the perp breaches your bedroom in the middle of the night when split seconds count you can't imagine how much longer it takes to square up a longer barrel as apposed to a shorter barrel and heaven forbid you have a struggle with said perp you're doomed with a shotgun or rifle in your hands. My bedside is a Glock 40 S&W, laser grips with the extended clip holds 14 rounds. My wife's bedside is the Glock 17 which holds 19 rounds. With the built in safeties its point and shoot.
    Regardless of what you end up with OP keep it SHORT. Long barrels are for reaching out to hit your target which is unnecessary when inside your home.
    SilverBulletII likes this.
  16. May 31, 2020 at 12:25 AM
    #36
    Slick Taco
    So many flaws in this theory I'm just going to turn my head and move on :facepalm:
    pink_pony, SC4333 and Loco_Barbon like this.
  17. May 31, 2020 at 12:28 AM
    #37
    dfanonymous
    No please, enlighten. Tell me the ultimate defense strategy and set up. Tell me about terminal ballistics, sources the statistics. Tell me about the proper amount of tactical savy.
  18. May 31, 2020 at 12:34 AM
    #38
    johnmichael125
    johnmichael125 mikeD1Esel
    Michael
    West Point, NY
    2022 MGM Tacoma DCSB TRD OR
    $500 worth of training with a $200 gun will always be better than the biggest bullet and more stopping power any day of the week.
    Whatever you decide, train with it at the range and train with it in your house. I’ve spent hours “clearing” my house with my guns and done the same day/night.
    I also spent time training my wife how to do it as well. Well placed shots and knowing what you’re doing will always win against bigger bullets/scarier sounding guns.
  19. May 31, 2020 at 12:41 AM
    #39
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    5+1
    or
    10+1 :D
    stbear, cubie, SC4333 and 1 other person like this.
  20. May 31, 2020 at 12:52 AM
    #40
    Slick Taco
    I'll cover one to enlighten you THEN I'm moving on. Hmmm let me pick one..you say handguns fail to have the speed to cause the amount of tissue damage and hydrostatic shock that a rifle cartridge will provide. The relevance of this is absurd. You're not hunting game at 300 yards. You're target is going to be within 20 feet of you when in your home. Besides home defense ammunition for hand guns is outstanding. Keep your 7mm mag in the closet until hunting season. Can I go now?
