Home electrical: disposal wiring problem
Discussion in 'Off-Topic Discussion' started by saltwater taco, Nov 1, 2011.
  1. Nov 1, 2011 at 8:14 PM
    saltwater taco
    saltwater taco [OP] Well-Known Member
    Brandon
    Telluride, CO
    2001 3.4 5spd 4x4 TRD
    softopper, sleeping platform
    So, here's the problem...
    (note: I'm new to this house)When I flip the switch for the disposal it trips the gfci outlet that the switch runs off of. I just put a new switch in, and I've tested the outlet that the disposal plugs into. The disposal works if I plug it into the top outlet (always hot; where the dishwasher plugs into). Also, the switch doesn't trip the gfci outlet if the disposal is unplugged. I'm fairly certain that the wires are in the correct spots on the switch and dishwasher/disposal outlet. Not sure about the gfci outlet, but the microwave works off of it. I'm so confused.
    Any help is much appreciated!
  2. Nov 1, 2011 at 8:19 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Am I understanding this correctly? Thinking the GFCI may be bad or wrong.
    On a single gang box your bottom outlet causes the gfci to trip when the disposal is plugged into it and turned on.
  3. Nov 1, 2011 at 8:20 PM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Does the switch trip the GFI if something other than the disposal is plugged in?
  4. Nov 1, 2011 at 8:22 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Fridges, dishwashers, and disposals usually aren't put on GFI's because they cause nuisance tripping
  5. Nov 1, 2011 at 8:25 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I'm an appliance repair tech. In general, if you call any appliance manufacturer and ask them why your GFCI is tripping, they will tell you to take the appliance off the GFCI. The reason is that most electric motors have a certain amount of current leakage to ground. A regular resistance meter will not be able to detect any continuity to ground, but there is still some very small amount. The GFCI is designed to detect current leakage and will trip.
    Now, there are plenty of refrigerators, washing machines, dryers, etc that are wired to GFCI outlets and they work fine. Often they work fine for years, then start to trip. In most of those cases, a new GFCI outlet or breaker will make the problem go away. Sometimes not. I believe the reason for that is that motors will leak more current to ground as they age.
    Not sure what the electrical code says about it, but what I recommend to people is that the counter top outlets should be GFCI, so that when someone drops the blender or toaster into the sink, the protection is there. The outlet under the sink for the disposal and dishwasher, and the one behind the fridge should just be normal grounded outlets.
    Maybe someone could speak up about what the national electric code says about this. I personally would get that GFCI off the under sink outlet, make sure the outlet is grounded, the disposal is grounded, and call it good.
  6. Nov 1, 2011 at 8:29 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Also, the top and bottom halves of that outlet (switched, not switched) are likely wired to a seperate breaker, and most likely not both wired to the GFCI. You can get a GFCI tester that plugs into the outlet and gives you a way to test that. Or you can use the test button on the GFCI outlet and see if the dishwasher quits when you trip it manually.
  7. Nov 1, 2011 at 8:30 PM
    cummins6speed
    NEC says that only outlets feeding countertop surfaces in a kitchen need to be GFCI protected.
  8. Nov 1, 2011 at 8:31 PM
    saltwater taco
    Brandon
    Telluride, CO
    What is that?
    Yes
    So, maybe the hot wire coming out of the gfci outlet is messed up? The outlet itself is working. Could I bypass the gfci outlet and run the hot wire straight to the switch to see if that's the problem or is that a bad idea? Worst case it trips the breaker right?
  9. Nov 1, 2011 at 8:36 PM
    cummins6speed
    Does the GFCI trip when you turn the switch on with nothing plugged in?
  10. Nov 1, 2011 at 8:38 PM
    cummins6speed
    Don't just go shuffling wires around tripping breakers and what not. Breakers are only designed to trip so many times before they should be replaced. Don't go causing it to trip now because it may end up not tripping when you really need it to
  11. Nov 1, 2011 at 8:41 PM
    saltwater taco
    Brandon
    Telluride, CO
    Sorry, I wasn't clear about this. The gfci outlet is between the switch and the breaker. The undersink outlet is just a regular outlet. Also the whole left of my kitchen is on one breaker. Its a small house.
  12. Nov 1, 2011 at 8:43 PM
    saltwater taco
    Brandon
    Telluride, CO
    No
  13. Nov 1, 2011 at 8:47 PM
    cummins6speed
    Then it likely is not the switch. Does it trip with any item you plug into that under sink outlet?
  14. Nov 1, 2011 at 8:50 PM
    Saskquatch11
    Saskquatch11 TRUCK YEAH
    you could just move the wires on the load side of the gfi to the line side of the gfi. the disposal wouldn't be gfi protected, but it doesn't need to be.
  15. Nov 1, 2011 at 8:55 PM
    cummins6speed
    That wouldn't fix the cause of the problem
  16. Nov 1, 2011 at 9:01 PM
    saltwater taco
    Brandon
    Telluride, CO
    Yes
    Btw thanks for all the help guys! I love Tacoma World!
  17. Nov 1, 2011 at 9:02 PM
    Saskquatch11
    it would prevent nuisance tripping.
  18. Nov 1, 2011 at 9:03 PM
    cummins6speed
    Have you taken the under sink receptacle out of the box and checked the connections? Might be a loose neutral on the switched one.
    Make sure you turn off the circuit first
  19. Nov 1, 2011 at 9:04 PM
    cummins6speed
    He established that it isn't nuisance tripping though because it trips with anything that is plugged into it
  20. Nov 1, 2011 at 9:07 PM
    Saskquatch11
    sorry, missed that.
