Home Gas Water Heater .. replacement advise please
Discussion in 'Northern California' started by DR_CA68, Jul 31, 2021.
  1. Jul 31, 2021 at 12:26 PM
    DR_CA68
    DR_CA68 [OP] Well-Known Member
    Dean
    San Jose
    08 TRD SPORT SHORTBED DC
    trying to keep stock
    My Home Water Heater Gas 50 gallon is leaking.
    Anyone be able to recommend a service company which goes to 95758 Elk Grove?
    Thanks
  2. Jul 31, 2021 at 12:29 PM
    the_great_white
    the_great_white Well-Known Member
    I'm on the other side of the country from you, but if you can wrench your Taco, you can replace a water heater. There's nothing complicated or special about it. Save some $$$ and do it yourself and pocket the savings for more truck mods.
    Travlr likes this.
  3. Jul 31, 2021 at 12:30 PM
    tcjacado
    tcjacado Well-Known Member
  4. Jul 31, 2021 at 12:32 PM
    Taco-Obsessed
  5. Jul 31, 2021 at 12:37 PM
    DR_CA68
    Dean
    San Jose
    Thanks to all so far...I'm just found a web site which detailed the steps. I've believe I'll give it a try...
  6. Jul 31, 2021 at 12:59 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Just remember, must be in a platform. Flex has a length limit. Use pipe dope on your connections and check them for leaks. If you don’t have valves, now would be a good time to add them.
    1-800-water heaters. But like others have said, easy enough to do.
  7. Jul 31, 2021 at 1:05 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Gas or electric?
  8. Jul 31, 2021 at 1:22 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    If you’re on gas consider a tankless. Never run out of hot water. Much smaller and easier to install.
    DR_CA68[OP] likes this.
  9. Jul 31, 2021 at 1:34 PM
    Foster1
    Foster1 Well-Known Member
    California
    2023 SR V6 4x4
    I replace water heaters all the time at our rental properties, the worst part are the spiders. Besides that it's pretty straight forward.
    I usually drain the water out of the old one first by connecting a garden hose and routing it outside. It'll make it lighter to lift the unit out.
  10. Jul 31, 2021 at 1:55 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    It's earthquake country. Having 40 or 50 gallons of water on-hand makes a lot of sense.
    soysauce021, Nessal and kalieaire like this.
  11. Jul 31, 2021 at 4:35 PM
    DR_CA68
    Dean
    San Jose
    Just wanted to say thank you to all on the gas heater suggestions. I'll be doing it
    Foster1 and ian408 like this.
  12. Jul 31, 2021 at 9:34 PM
    Redbeardfifty
    Redbeardfifty Well-Known Member
    The other bad part of tankless is hard water.
    I am in concord and need to replace mine. Everyone that puts tankless around here has problems unless they have whole house filters.
    The minerals clog them like mofo’s...
    I need an 80 gal gas to replace my 80 gal gas from 1997.... it probably has a 4 inch thick layer of mineral inside and would explain it running out of hot water quickly. Never been drained lol.
  13. Jul 31, 2021 at 9:53 PM
    JEEPNIK
    Can’t get much more earthquake country than L A County which is where I am. If you are relying on a hot water heater for water you are woefully unprepared.
    Of all of the means to supply potable water that are around a good old fashioned solar still can’t be beat.
  14. Aug 1, 2021 at 12:44 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    9
    Lmk if you still need help. I got a buddy
  15. Aug 1, 2021 at 4:33 AM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    I’m not sure I follow your logic. But I’d much rather have a heater full of potable water than rely on a still for making water.
    Nessal likes this.
  16. Aug 1, 2021 at 5:07 AM
    soggyBottom
    soggyBottom Well-Known Member
    I know you said you're on gas but consider a heat pump water heater. Annual energy cost is half that of gas. You can also usually get a $500 rebate when you file you taxes.
    DR_CA68[QUOTED][OP] likes this.
  17. Aug 1, 2021 at 3:23 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Natural gas is cost efficient and the heat pump heaters are about 2 to 3 times the cost with similar warranty/lifetime. I did see the federal energy rebate is $300 with up to a $750 "local" rebate. The other downside is they typically work best in 40-90º spaces with at least a 1000 cubic feet of airspace (to dump the cool air). There's also some discussion of recovery rates making a heat pump less desirable for a large family.
    Cool idea but seems like it requires careful thought before committing to one.
    Thanks for the pointer!
  18. Aug 1, 2021 at 3:27 PM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    Move out of California and get a tankless. They work great, even with dirty Jersey water. Tagaki FTW
  19. Aug 1, 2021 at 4:02 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    That's not an expense that will pay off. If you're gonna move, leave the heater for someone else :D
  20. Aug 1, 2021 at 4:54 PM
    Sccafire
    Sccafire KMG 365
    Cleburne, Texas
    2023 Jeep Gladiator Rubicon
    Bradford White for the water heater. Best in the market for hard water. Buy once, cry once
    ian408 likes this.
