home improvement/ old well on property ??
Discussion in 'Off-Topic Discussion' started by anotherreject, Sep 20, 2013.
  1. Sep 24, 2013 at 7:19 AM
    #41
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    So you seal it up so that surface water can't get to the ground water but you want the sides unsealed so the surface water can move down to the ground water ?
  2. Sep 24, 2013 at 7:20 AM
    #42
    Round II
    Round II Member #12005
    :crazy:
  3. Sep 24, 2013 at 7:39 AM
    #43
    gooch14
    gooch14 Well-Known Member
    Kyle
    Michigan
    2011 Blk DC Taco SR5 4x LB
    Bestop, Child Seats, petrified french fry, dog hair, empty Mtn Dew cans cracked windshield, scratches.
    Did you click the link I had put in my first post?
    There is an illustartion that shows you layer the sand and the bentonite, no more than 10ft of sand, and thats if it's a deep dug well.
    If it's only a 30ft dug well you'd most likely do 4-5ft of sand with layers of bentonite.
    So, if your surface water found its way into the well casing, it's only going to travel down through the sand for 4-5ft, then hit bentonite, and find its way either back outside the casing to more filtering media, or just sit there inside the casing on the clay.
  4. Sep 24, 2013 at 8:34 AM
    #44
    OZ-T
    Peter North
    British Columbia
    But there is no casing in a cistern or in a hand dug well , correct ?
    I've seen bentonite used to seal casing to stone at the top just wondered how it would work in an unlined / uncased situation
  5. Sep 24, 2013 at 8:43 AM
    #45
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    The objective is to prevent a direct conduit, or a "bridge", between the surface water and groundwater, and instead force it to follow a better path that allows it to be purified as well as not disrupt natural lateral groundwater movement. There are other ways to abandon a well/cistern to meet this objective too, but the recommendation is usually to pull the casing if practical. If youre interested you can follow the links i provided or that gooch provided above.
  6. Sep 24, 2013 at 8:47 AM
    #46
    OZ-T
    Peter North
    British Columbia
    I read Gooch's link but it only shows how to do it , I was asking what the reasoning behind the sand and bentonite layers was , which you have both answered
  7. Sep 24, 2013 at 10:08 AM
    #47
    gooch14
    Kyle
    Michigan
    gotcha,
    you're short answers can be read in a skeptical smartass dickhead way. My appologies if they weren't intended that way....eff you if they were :p
    Bentonite is expensive, and dug wells would use a lot of it so that was the start of the reasoning for the sand. When you close a typical 4" well you use just the bentonite.
    I'm not a well driller, not even close. But I do Environmental Education for farmers and often have to sell to them the importance of closing a well correctly as opposed to filling in the pit and putting a slab over the top.
  8. Sep 24, 2013 at 10:19 AM
    #48
    OZ-T
    Peter North
    British Columbia
    We had issues on a 6" drilled well on one of my jobs , surface water was getting in below the 20' steel casing , we had to do a " shale trap " grouting to stop the water infiltration .
    This technique is meant to seal the fissures in the rock and not allow for passage of water , that's why I asked
    FU Red Wings
  9. Sep 24, 2013 at 10:21 AM
    #49
    beachingtaco
    beachingtaco "We have assumed control"
    Long Island, new york
    2012 DCLB trd sport
    westin nerf bars, ARE in-channel visors, Wet Okole's, mobtown tailgate skin, Tail Gate theft mod
    A well today is only about a 6" hole but there is a reason they make dry wells, drainage and septic rings from a monolithic concrete pour, they last better over time. Older drainage, septic and cisterns have mortar between the bricks which erode over time and the whole structure could collapse. I'm not the most safety mided but if I had a kid I"d fill it in. If it collapse's won't matter if theres a new conc cover on top.......just my .02
  10. Sep 24, 2013 at 11:21 AM
    #50
    gooch14
    Kyle
    Michigan
    water was going down the outside of the casing to the bottom?
    here they pump clay down as they drill and it pushes up the outside of the casing to help seal it.
  11. Sep 24, 2013 at 11:43 AM
    #51
    OZ-T
    Peter North
    British Columbia
    The casing is only for the top 20' , there were fractures that came from the surface to below the casing , they were the result of blasting after the well was originally drilled though
  12. Sep 24, 2013 at 2:19 PM
    #52
    ecoterragaia
    Central Virginia
    If sealing off the aquifer was successful, that's really impressive.
    I used to work for the Health Department writing permits for well construction and abandonment, among other things. In a case like that we would have suggested that the property owner drill another well. But I didn't work in a region where bedrock was present, it was coastal plain with layers of clay, loam, and sand more than a thousand feet tdeep.
  13. Sep 24, 2013 at 2:40 PM
    #53
    OZ-T
    Peter North
    British Columbia
    Sucessful yes , the company that did the procedure has done hundreds , everything is on rock here
    http://www.drillwell.com/
  14. Sep 25, 2013 at 1:21 PM
    #54
    gooch14
    Kyle
    Michigan
    Rock wells.....we're in all glacial till here...
    My father in laws well is 303ft, all sand and gravel. Most wells in my area are 68ft-100ft of casing, 2-15 of screen.
