Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Apr 16, 2020 at 11:23 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    I've mowed our 3 times already and it needs it again :D
  2. Apr 16, 2020 at 11:30 AM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Mine snow has gone and come back three times now. Hopefully it's done with this nonsense and we can get on with spring!
    shane100700 likes this.
  3. Apr 16, 2020 at 11:36 AM
    4BYTOY
    4BYTOY Well-Known Member
    Colorado Front Range
    2018 TRD Off Road
    Guess the bright side is that I don't need to mow the yard....but shoveling snow is getting old.
    Back yard today:
  4. Apr 16, 2020 at 1:46 PM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    We’ve been about the same. No snow for Christmas but fresh snow on Easter. Melted, woke up with about an inch this morning. It’s melted now. Supposed to get some again this weekend. Been like that the last couple months.
    Fargo Taco[QUOTED] likes this.
  5. Apr 16, 2020 at 3:28 PM
    Tacotruck7
    Tacotruck7 Well-Known Member
    SoCal
    04 Prerunner Dbl Cab 2.7L
    https://www.homedepot.com/p/Homewer...oint-x-Slip-Joint-Union-512-14-1-1B/312422090
    Is this the right fitting? So what's nice about this is that you don't have to cut the pipe and reglue every time or what? It also seems easier to do as you don't have to cut then add on an extension to get the hight back. You can just cut, reuse the old threaded fitting and go from there right?
  6. Apr 16, 2020 at 5:06 PM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Been doing this on and off all day. Not fun when you're 40' up in a lift with the wind whipping.
    Haven't had to mow yet though so that's a win :D
    wilcam47, Drainbung and shane100700 like this.
  7. Apr 16, 2020 at 6:40 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Can this be home improvement? I’ve got a zero turn now with no bagger. I have another riding mower and a tracvac I use to get our leaves up. Bought this hustler from a friend today and I’m selling the other three with engines vs doing all the mowing and leaf getting up with one engine.
  8. Apr 17, 2020 at 11:10 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Question pertaining to air compressors for flooring nailers. I bought a Bostitch flooring nailer and according to the manual it says that you need an air compressor with 3.5 scfm to keep up with the nailer at 60 cleats per minute. I’ll be lucky to do half that as it’s my first time.can I get away with $100 Craftsman pancake compressor to do the job?
    If renting one is anything over $30, I’d rather buy it being that installation is probably going to take a few days.
    wilcam47 likes this.
  9. Apr 18, 2020 at 12:17 AM
    scocar
    scocar Patron of the Farts
    Yes, that's exactly it.
    Yes, right fitting.
    Yes, don't have to cut and re-glue. Becomes a simple R&R job of undo unions, then undo your threaded nipples into the valve inlet and outlet, thread them into new valve, and reconnect unions. After you set it up, no measuring, not cutting, no bullshit.
    All new systems should be set up this way. Most aren't.
    Drainbung likes this.
  10. Apr 18, 2020 at 12:50 AM
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    I'm doing this X100 right now. Installing a saltless water softener system with UV light, pre-filters and other fun stuff. I am using 1" copper for the whole system and have 8 slip joints so any major part can be removed/replaced without any cutting. It is also so if any threaded connectors start to leak you can fix them in the same way.
    I have a lot of slip joints in my sprinkler system. especially around valves. I did it before much of my yard was covered in cement/flagstone. I have replaced enough valves over the years to learn.
  11. Apr 18, 2020 at 1:12 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Buy once, cry once! I would buy something bigger.
  12. Apr 18, 2020 at 1:18 AM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    If you are going to buy it, over buy. What’s another 30-50? A night out having 3 drinks? (Not where I live).
    If you are planning on catching a 100 lb fish you don’t go out with 100 lb test leader. You over think it and put on 150-200. Just sayin.
    wilcam47 and robssol like this.
  13. Apr 18, 2020 at 3:40 AM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 Tundra TRD OR inferno
    I used my bostitch pancake tank and flooring nailer to do a 400sq ft oak living room. It did fine as long as you give the tank a second to catch up once it kicks on.
    six5crèéd and 23Skidoo like this.
  14. Apr 18, 2020 at 4:36 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Off subject but my wife and I used to go to a lot of auctions. They had a pancake porter cable compressor, I bid it off at $10 not knowing if it worked or not. That was 8 years ago and it’s still working good :thumbsup:
    QMEDJoe and FlyingWolfe[QUOTED] like this.
  15. Apr 18, 2020 at 4:42 AM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    Hot damn! I love it when that happens:rolleyes:
    six5crèéd[QUOTED] likes this.
  16. Apr 18, 2020 at 6:10 AM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    A little chainsaw work and some fill dirt and I’m done.
    8A58E8A1-D8FE-4EC7-948A-9739897541FB.jpg 4E4BB348-88D6-4AEB-A8D3-A6E7093B8AE6.jpg
  17. Apr 18, 2020 at 7:06 AM
    soggyBottom
    soggyBottom Well-Known Member
  18. Apr 18, 2020 at 7:08 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    I'm going to redo my valves and put them above ground. Rotten moles keep burying them. Will cover with an insulated box to protect them in the winter. Also going to put a new wire inside some pvc pipe. Uugghh lots of digging...
    scocar[QUOTED] likes this.
  19. Apr 18, 2020 at 7:48 AM
    Tacotruck7
    SoCal
    If my valves are close to the ground should I dig it out a little, cut, and extend the pipe?
    it’s hard to explain but where I need to cut the pipe is almost ground level at that point as there is a coupling for the nipples.
  20. Apr 18, 2020 at 9:11 AM
    scocar
    Yeah, I'm on house #4 since I joined TW. First house had zero irrigation, so I planned and installed it all, starting with PSI all the way through 5 zones. High pressure and low. The next three houses all had irrigation, and most of it was retarded. Especially drip. So many DIY clusters. Most drip I would tear out from the valve and redo. Last house had 14 zones with several buried valve boxes all over the property in various states of disrepair. What a cluster. In one thes valves were completely covered in dirt. I had to exhume that one and do it correctly. I won't even go into the constant PITA that entire property was. Irrigation is backbreaking work on a good day.
    ImpulseRed008[QUOTED] likes this.
