Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Aug 12, 2020 at 3:56 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I helped a buddy replace a heating element and figured there would be lots of stuff but it was really simple. And the belt size was surprising.
    308savage[QUOTED] and Drainbung like this.
  2. Aug 12, 2020 at 5:18 PM
    16SRMGM
    16SRMGM Well-Known Member
    2016 Tacoma SR
    Tile question, if anyone can offer some much needed help please!!
    I have backer board(Durock) up. I was told to mesh tape the seam then aquadefense over the seams and screw heads. I’m seeing multiple videos where “thin set” is put over seams and then the aquadefense. Stupid question I know, but what exactly is used for “thin set”?? I asked for it at Lowe’s and I was turned to the aquadefense and told that will work. I looked all over the isles for something saying thin set or anything close. Didn’t see anything.
    Part 2 of this question is now I have aqua defense over half my walls. Can I put this thin set over the top of this stuff or am I totally screwed and need to take it out???
    Thanks in advance for any advice!
  3. Aug 12, 2020 at 5:30 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Thinset is time mortar. Guessing aqua defense is a type of waterproof membrane. I used kerdi and you can apply thinset over top no issues. Infact you use that to seal seems and then obviously apply the tile overtop with the mortar
  4. Aug 12, 2020 at 5:51 PM
    16SRMGM
    2016 Tacoma SR
    So, just To be sure, a “quick set” mortar would be same as thin set and I’m okay to put that over the seams. Then aquadefense over that?? The aquadefense is a membrane type to block moisture.
  5. Aug 12, 2020 at 6:25 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Had to look up aqua defense, never seen it before. Looks like their are some issues with with the curing. So I’m not so sure I would use aqua defense. Maybe some professionals here can chime in. Personally I would recommend if you want a waterproof membrane covering the durock, I would use Schulter Kerdi. It’s a little pricey but is amazing stuff. You apply it with thinset. Then lay the tile over it with more thinset. It’s designed for baths and showers. Home Depot sells it although not sure they have Kerdi in the stores but you can order it from them online.
    wilcam47 likes this.
  6. Aug 12, 2020 at 6:39 PM
    16SRMGM
    2016 Tacoma SR
    Ok, I’ll look into that. I can see why there may be some cure issues. Where I’ve applied it thick, it’s still wet looking. I’ve just quit and I’m going to let it do some drying. Thanks for info!! Greatly appreciated.
  7. Aug 12, 2020 at 7:25 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    mesmerizing
    floodedkiwi, Drainbung, mCat and 3 others like this.
  8. Aug 13, 2020 at 4:45 AM
    megillet
    megillet Resident Badass
    Mark
    Atlanta, GA
    2010 4x4 TRD Sport DCSB MGM 6sp
    I also recommend the Schluter Kerdi. If you have a Floor & Decor near you, they stock a lot more than HD and their Pro desk can order anything in the Schluter catalog with a lot less headache than the "Pros" at HD. There are a ton of Schluter videos online on how to use their stuff. I recently redid our master bath with it and it wasn't too hard to work with.
  9. Aug 13, 2020 at 1:48 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Finally put some gravel down on the RV pad. No more sinking into the mud when leaving/parking. Only bummer was that the gravel showed up the day AFTER I had the Bobcat.
    wilcam47 and Drainbung like this.
  10. Aug 13, 2020 at 2:08 PM
    wilcam47
    Will
    Bourbon state
    Kind of a pain but you can run the truck back and forth over it.
    Maticuno[QUOTED] and Drainbung like this.
  11. Aug 13, 2020 at 2:25 PM
    Maticuno
    2011 Suburban 2500
    Thanks. After spreading it, I packed it down with the truck while my dad feathered in more gravel over the depressions.
    wilcam47[QUOTED] and Drainbung like this.
  12. Aug 13, 2020 at 6:22 PM
    Hawco636
    Hawco636 Great White North
    2010 MGM SR5 - V6 Manual
    I used aqua defense for my shower install and it went on fine, I brushed it on (only because I didn't have a small 3-4in roller) but I made sure to only put on enough to coat, let it dry, then applied a second coat the next day. If you allow enough dry time it works just as well!
    This being said, I did use that kerdi orange waterproofing around the corners/edges of the niches, because I had a 4" wide roll of if from a job I did a while back . If you look close enough you can see it built up around those niches
  13. Aug 14, 2020 at 6:32 AM
    05Taco4x4
    2TR-FE Enthusiast
    I've been in this house less than a year, the back corner had a bit of clutter that I've been clearing out. I gave the tin building to a guy on Craigslist, free to whoever disassembled and hauled away.
    I had to pay to have the self-pour pad broken up and hauled off. Vines killed off the Cherry tree, had a crew remove and grind the stump.
    The previous owner rented the property, last tenant hauled in a bunch of earth and had put pavers on top for her lawn furniture- she took the pavers with her and left a 20' box of sand covered with plastic. I hauled that off yesterday, I'll be spreading seed soon.
  14. Aug 14, 2020 at 7:31 AM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    that's a weird thing to take with her. would think that those we be considered "permanent".
    Drainbung likes this.
  15. Aug 14, 2020 at 7:33 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Must have been some special pavers. Moving is miserable enough without putting yourself through that.
    truchador, Scott B., Maticuno and 2 others like this.
  16. Aug 14, 2020 at 7:36 AM
    theredofshaw
    my wife wanted to take our old security camera system with us but after crawling through the attic and installing it in the dead of summer...I said HELL no. we ended up walking with a pretty penny out of that sale so I wasn't worried about something that was only $200, outdated, and would have been a b***h to install in the new house.
  17. Aug 14, 2020 at 7:38 AM
    theredofshaw
  18. Aug 14, 2020 at 7:48 AM
    jsi
    jsi Well-Known Member
    native earthling
    Looking good. Reminds me of my first house.
    05Taco4x4[QUOTED] likes this.
  19. Aug 14, 2020 at 8:19 AM
    05Taco4x4
    2TR-FE Enthusiast
    They weren't there when I purchased the house, I didn't know that's why the sand was there until I was talking with a neighbor about removing the sand and he told me.
    jsi, Drainbung and wilcam47 like this.
  20. Aug 17, 2020 at 8:04 AM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    Decided because it apparently wasnt hot enough yesterday i needed to do some work. So i emptied the garage, swept it clean and installed the rubber i've been storing for weeks. Turned out great! I still need to add my reducer at the garage edge but thatll be done today.
