Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Aug 21, 2020 at 7:53 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Ya'll wanna come mow mine then?
  2. Aug 21, 2020 at 8:21 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    If the hallway also has the same slope it's most likely just shitty framing. You very seldom have a joist that sags on both ends. Believe it or not there's a lot of framers who aren't very good with square, level, plumb and straight. Crazy but true.
    If it really bothers you that much it can be fixed properly. That would require pulling the tub and toilet, ripping out the old sub floor and furring those joists up. Since the hallway follows the same plane it would leave you with custom transition strip at the doorway.
    The other option is to tile it. You can use the thin set to fix the tub reveal by using a larger notch trowel on the left side. Then you can feather it out and plane it in using a straight edge. Since you want to use vinyl lick and stick I would strongly suggest you don't use self-leveling concrete. It will crack and degrade with traffic because the vinyl does not provide enough support. You might be able to add a hardener and some anti-crack fiberglass to the mix to make it last longer but I wouldn't.
    Or you could just live with it and try to sleep at night. I have severe OCD when it comes to square, level, plumb, and straight. I would fix it correctly but I also do this shit for a living. lol
    RocTaco and Sacrifice[QUOTED] like this.
  3. Aug 21, 2020 at 8:39 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Haha thanks for the tips and info. I apprecate the insight. Not knowing any professionals make it a bit harder to get opinions. Ill make something temporary work with the intent that it will be redone down the road. (Probably real tile like you suggest).
    The hallway is getting carpeted so hopefully it makes the transition less noticeable overall.
  4. Aug 21, 2020 at 9:59 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I’ve been putting off reworking my staircase ever since we moved in a year ago- I built high-end, custom circular and elliptical staircases for years and knew I’d have fun doing it but also immediately recognized this thing wasn't anywhere near the workmanship I'm use to.
    I pulled the wobbly rail and balusters and it's sat like that for 6 months as the rest of the renovation projects have went on around it.
    (we don't use upstairs)
    I finally got tired of looking at it and decided to pull a tread and see what skeletons were under there a few days ago. No glue/adhesive and no center support- these treads were bouncing up and down until the glue between the boards broke (some treads were riddled with dozens of nail holes in an attempt to get them to stop moving- there was nothing under the tread to attach it lol)
    They notched the back of the tread into the stringer and sat the riser on top of the tread.
    :annoyed:
    So I tore into it yesterday...
    A staircase's stringers should flow into the baseboard, top and bottom. You can see the bottom step notched around the stringer and died into the wall- the top tread did the same.
    :frusty:
    So I took care of that
    And that's where I'm at now, everything sanded and ready for new.
    In the morning I'm going to install the rest of the baseboard and prime them along with the old stringer. I've already collected new material and painted the balusters, I've decided to butt the rail into a box newel and ditch the volute. I'll be cutting a new stringer for the open side and hopefully assembling risers and treads tomorrow before dinner.
    Fargo Taco, Slashaar, mbarbay and 7 others like this.
  5. Aug 22, 2020 at 7:03 AM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    ^^^ What he said
    My upstairs the floors are like a fun house, it's 140 years old and there's been various extra supports tied in over the years. The bathroom has the lick-n-stick tile and it works well with the uneven floors. It doesn't bug me too much, mostly because it's stabilized and I just don't have the money to fix it properly even doing the work myself.
    Infact I'm pretty sure the ONLY floor in my house that's completely flat and level is the kitchen.
    Sacrifice likes this.
  6. Aug 22, 2020 at 8:03 AM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    I have one of those. Not sure what to do about it yet so I haven’t done anything. It’s not sagging and the house is 13 years old but I feel like I should do something.
    I knew about that one when I bought it, the one that pissed me off was the collapsed joist end I found a year later. Not sure if the last guy had a gun safe on it or if the idiot that ran the wire through it missed the knockout. Ended up ripping some OSB and through bolting it in place to brace it. Seems to be holding up just fine.
  7. Aug 22, 2020 at 10:22 AM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Pretty sure I've posted this before but always good for a laugh:
    Not my house, not my doing lol.
  8. Aug 22, 2020 at 10:27 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    That double LVL was probably not there for anything anyway
  9. Aug 22, 2020 at 11:08 AM
    JeffreyB
    Jeff
    :eek: The best part about that is someone did that without seeing a problem with it.
    Slashaar and Drainbung like this.
  10. Aug 22, 2020 at 11:14 AM
    theesotericone
    Bishop CA
    The worse part is the inspector also didn't see a problem.
    Slashaar, shakerhood and Drainbung like this.
  11. Aug 22, 2020 at 11:15 AM
    JeffreyB
    Jeff
    I fixed a stupid one a few months ago. I've lived here for 4 years and every once in a while I caught a whiff of sewer gas outside. There has been construction down the street since I moved in so I always attributed it to that. Finally I put two and two together that my radon exhaust was tied in with my vent pipe. It was me pumping the sewer gas out with that radon fan. I isolated the vent pipe and ran the radon fan out separately and haven't smelled it outside since. The crazy thing to me is first of all, someone installed it like that and I'm sure they thought they were being slick as shit. Second of all 2 different owners lived in this house for about 9 years before me and never connected the dots, (granted it took me 4 years) or they did and decided not to do anything about it.
    wilcam47 likes this.
  12. Aug 22, 2020 at 4:37 PM
    Hawco636
    Hawco636 Great White North
    2010 MGM SR5 - V6 Manual
    I knew this was an issue before buying my house, but: the toilet in the upstairs bathroom had a pretty mean lean to it, like you sat on the toilet and it felt like a recliner hahah. They had roll on vinyl as flooring, I could feel the flooring beneath was a bit squishy (The lean made any water on the floor pool around the toilet.
    I wish I had a picture of the floor joists below. They completely cut through the joist running below the toilet, and to support it, they cross blocked it to the adjacent joist that they completely cut through again to have the drain for the tub! Ridiculous what some people think
  13. Aug 22, 2020 at 4:51 PM
    05Taco4x4
    2TR-FE Enthusiast
    I didn’t get to assemble today but made good progress. I added center supports, installed the rest of the baseboard, primed the wall stringer and baseboards, guesstimated the dimensions for the open stringer best I could from the framing and cut it. They had completely removed the foot on one side, all the weight on that side was on the wrap; I scabbed on a new foot. I’ve ripped the risers and cut them to length, should be able to assemble tomorrow. Sure is nice being able to cut a stringer with a chop saw, don't get to do that with the curvy stuff haha
  14. Aug 25, 2020 at 1:03 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Hauled 760 pounds of scrap to the recycler. A whopping $8. Just about paid for the diesel.
  15. Aug 25, 2020 at 2:44 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  16. Aug 25, 2020 at 5:20 PM
    Sudsman44
    Sudsman44 Well-Known Member
    Abington PA
    2012 Tacoma Access 4x4
    Ranch cap w/ rhinorack bars, 5100s, Deaver AAL, 2” front receiver, Matt Gecko bedlights, yadda yadda…
    Damn. Clean aluminum gets $.36/lb around here.
    Drainbung likes this.
  17. Aug 25, 2020 at 5:33 PM
    OZ-T
    Peter North
    British Columbia
    https://youtu.be/1WqazleR3FE
  18. Aug 25, 2020 at 6:16 PM
    Maticuno
    2011 Suburban 2500
    Tin and steel mix. $25 a ton.
  19. Aug 25, 2020 at 8:43 PM
    markmizzou
    markmizzou Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
    You have the same mower I have, I bought mine new and love it. that is if it is this one? OOPs - maybe you got the walk behind? My push mower is a Honda 21 Self
    propelled. That mower as well as my Scag came with a 5 year residential use warranty[​IMG]
    Drainbung[QUOTED] likes this.
  20. Aug 25, 2020 at 9:31 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Great equipment for sure. Mine is the walk behind, still no regrets.
