Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Dec 24, 2020 at 11:06 AM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I'd ditch the toilet in your bathroom, remove the wall between the bathroom and laundry machines and just closet them in.
    Where's your water heater going?
    edit:
    I'd even consider jack/jill that toilet. That office has a lot of wasted space.
    95 taco[QUOTED] likes this.
  2. Dec 24, 2020 at 1:29 PM
    SH7mi
    SH7mi Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
    Not exactly Home Improvement but more Home Preservation. Christmas Eve surprise of a 100’ Poplar about to fall on my shed. I called a friend to assist in felling the Poplar which the falling tree was leaning on. Once the supporting Poplar fell, the leaner went with it missing the shed by 2-3’.
  3. Dec 24, 2020 at 1:30 PM
    SH7mi
    Kevin
    West Grove, Pa.
    The aftermath ....
  4. Dec 24, 2020 at 1:46 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Got lucky there. I'd take down that other tree next to the shed too that looks like there's a big rot hole at the base.
    CXYyuppie and SH7mi[QUOTED] like this.
  5. Dec 24, 2020 at 1:48 PM
    SH7mi
    Kevin
    West Grove, Pa.
    Yes, it is coming down as well but needs to be topped first to control the direction of fall
    buyobuyo[QUOTED] likes this.
  6. Dec 24, 2020 at 2:30 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Beaver management. It’s a thing now.
    SH7mi[QUOTED] and Drainbung like this.
  7. Dec 24, 2020 at 2:37 PM
    SH7mi
    Kevin
    West Grove, Pa.
    We had Beavers living in the creek about 15 years ago, they moved on. Haven't seen them since.
    FastEddy59[QUOTED] likes this.
  8. Dec 24, 2020 at 2:41 PM
    FastEddy59
    Eddie
    If they got Married you’ll never see ‘em again. Don’t ask me how I know. :frusty:
  9. Dec 25, 2020 at 7:51 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Thanks for the input, I’ll consider ditching the toilet and removing the wall.
    Water heater will either go above the apartment or (more likely) on the shop side of the wall between the apartment and shop, it will have enough air circulation to warrant a heat pump style heater.
    A jack and jill bathroom is one thing that I refuse to have, I’ve never been a fan of them.
    Wasted space as in the space directly in front of the door and beside the desk? The space in front of the door is just large enough for one of my gun safes and any free wall space in the office will get shelving or filing cabinets to help organize stuff. From my rough estimates that leaves a walkway to get in and to the desk and access most wall space comfortably.
  10. Dec 25, 2020 at 8:54 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Stackable washer and dryer and a small linen closet or shelving for towels, sheets, etc
  11. Dec 26, 2020 at 5:15 AM
    ralfnjan
    ralfnjan Well-Known Member
    With the shape those poplars were in, by the look of the trunks, they should have been removed before the shed went up :) but you probably figure that out the other day.
  12. Dec 26, 2020 at 5:25 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Well we finally have good water in the house. Really surprised the previous owners live here for 20+ years and never did anything about the water. (its really high TDS, hard, and few other things).
    Only issue is the pressure pump keeps coming on every 5-10 minutes indicating a small leak somewhere (the pump has a pretty tight cut on/off point though). So went to isolate things and figure out where it was. Upon which Ive learned most of the shut off valves need work. This one (of course the hard to get one) wouldnt even close due to gunk inside it. Of course discovered this on Christmas so nowhere was open to get a new one. Thankfully disassembling it and cleaning it has it not leaking for now. But it will be getting replaced (along with most other ones)
    https://www.tacomaworld.com/media/pxl_20201226_131439333.676007/
  13. Dec 26, 2020 at 5:48 AM
    ralfnjan
    Pump might also be cycling because of the very small pressure tank! The bigger the better, makes for less cycles in the long run.
    CXYyuppie likes this.
  14. Dec 26, 2020 at 5:52 AM
    ralfnjan
    A bigger pressure tank will make for less cycles of the pump (unless that's just a booster of some sort). I have a pressure tank almost the size of one of your plastic tanks. Less cycles is better for the pump motor, pressure switch, power consumption (if you're off grid like me).
    Big ones are self standing so you just plumb from the removed pressure tank to the larger one with braided nylon hose.
  15. Dec 26, 2020 at 5:59 AM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    its a booster pump. The actual well side stuff isnt shown
  16. Dec 26, 2020 at 6:03 AM
    Charlie Too
    Charlie Too Well-Known Member
    Western PA
    2021 Army Green Tacoma TRD Off Road
    That's a high tech system. Mine is downright medieval compared to yours. Fortunately, we do do not have hard water. This system was here when we moved in almost 30 years ago. I figure, if it's not broke don't mess with it. We do have multi filter system for our drinking water. Truth be told, the public water system, which the residents who live on the main road have, is terrible: old pipes that constantly break and water that tastes undrinkable.
  17. Dec 26, 2020 at 6:14 AM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    it both is a "high tech" system and also not at the same time. It looks like a lot of stuff but its mostly just simple things. RO unit feed the tanks. Theres a chemical injector (anti scalant...basically alternate for salt), a UV recirc system that just cycles the water in the tanks, and then the booster pump setup. The hardest part for the guys installing was just getting everything working right (hence why some of the valves are throttled instead of fully open)
    I had a setup like yours at our old house. All we needed was a sediment filter though. The water in this area (even city) sucks. But a lot of it is from farming. The city water in town isnt nearly as bad our well water but the water company we used still installs a ton of systems on city water home. Not nearly as "complex" as ours though
    Charlie Too[QUOTED] likes this.
  18. Dec 26, 2020 at 6:39 AM
    Charlie Too
    Western PA
    Yeah. I have a sediment filter on it, then the 4 stage filters for the drinking water. I don't have any smell, thankfully (when I was a child the neighbors had well water high in sulfur; it smelled like rotten eggs. I was always turned down their offer for a drink).
  19. Dec 26, 2020 at 7:06 AM
    SH7mi
    Kevin
    West Grove, Pa.
    I have hard water as well with a water softener installed. It’s original to the house which is 21 years old. I need to update the system.
    Just a heads up to all with hard water and softening systems, drain 10-15 gallons from the storage tank and water heater every 6 months, this helps with build up and lifetime of water heater.
  20. Dec 26, 2020 at 12:56 PM
    jsi
    jsi Well-Known Member
    native earthling
    Another thing to do is swap out an aluminum anode rod for one made out of magnesium. Aluminum rods can create an aluminum oxide gel that can be difficult to impossible to flush from the tank. My dad's water heater was so full of the stuff that he didn't have enough hot water. When I tried to drain the tank nothing much came out. Ended up my brother and I had to manhandle a 300+ pound beast out of his basement. (not fun)
    They say magnesium doesn't last as long, but does a better job of protection than aluminum. After one year in softened water this is what my aluminum anode rod looked like. I replaced it with magnesium and after a year by I'll pull it for a comparison.
