Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Apr 9, 2021 at 12:51 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    what kind of cfm is the fan moving ?
    Drainbung likes this.
  2. Apr 9, 2021 at 1:23 PM
    cafereef
    cafereef Well-Known Member
    2017 MGM Tacoma TRD Sport
    TRD Sport Exahust, OEM roof Rack, Predator Pro side steps.
    recommendations, I am going to be installing laminate flooring throughout our house. I have 2 bathrooms, and 2 entryways that are limoleum covered. The linoleum is glued to particleboard which is stapled down to the subfloor. recommendations on the best way to pull this up with as easy as possible without damaging the sub floor?
    I am considering buying a 12" bully bar and using my circular saw to score material cutting it down to the subfloor to aid in prying it up. Or is the a better approach? I would go over the top of it with the laminate but then I have to put down plywood throughout the whole house and that's 1600 square feet of plywood I don't really want to put down.
  3. Apr 9, 2021 at 2:21 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Just have to pry it up and pull all the staples. Then put luan down before the laminate
    Charlie Too likes this.
  4. Apr 9, 2021 at 2:29 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    There is no easy way! As long as they didn't go crazy with the staples, your plan is probably about the least difficult. What is your subfloor? Unless you're really lucky, you're going to need to put something down on it; I have had very good luck using Enstron 3/8 underlay. It's relatively inexpensive, and provides a good surface on which to install all types of flooring.
  5. Apr 9, 2021 at 2:35 PM
    ralfnjan
    ralfnjan Well-Known Member
    Not sure of the CFM Peter. If I found the correct Amazon order, 180cfm. Could probably do with a 55cfm 120volt one.
    OZ-T and Drainbung like this.
  6. Apr 9, 2021 at 4:31 PM
    jsi
    jsi Well-Known Member
    native earthling
    Is your laminate 100% water proof. I just tore the laminate out of my brother in laws bathroom because it was all swollen and buckled from spilled water. I had a WTF moment questioning why the builder installed it in the first place.
  7. Apr 9, 2021 at 5:32 PM
    tirediron
    Laminate in a WET zone????? :eek::confused::confused::confused::confused::confused::confused:
  8. Apr 9, 2021 at 6:35 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    A no go? We were actually thinking of doing it in the kitchen, entryways and bathrooms.... All we have at current is linoleum...
  9. Apr 9, 2021 at 6:39 PM
    tirediron
    In my opinion, a definite no-go. I only use impervious flooring in wet zones (Tile, roll floor). I have used Tarkett fibreglass roll flooring in all my wet areas; two bathrooms and kitchen/dining room, as well as my entrance way. I've been VERY happy with it. It's much thicker and more "cushiony" than regular roll floor, and unlike traditional linoleum, if you cut it, rather than the the cut opening and getting larger over time, it self-heals.
    Slashaar[QUOTED] likes this.
  10. Apr 9, 2021 at 10:12 PM
    jsi
    native earthling
    Like I said WTF builder.
    before (It looks ok to the eye, but feels like shit to bare feet)
    after
    You'll be ok everywhere but the bathrooms. There it's just one plugged toilet or kids splashing in the tub to a replacement project.
  11. Apr 10, 2021 at 8:59 AM
    Slashaar
    Josh
    Kansas City, MO
    Don't have to worry about kids, so thats nice. Vinyl like the Tarkett NuGen work in the splash zones?
  12. Apr 10, 2021 at 9:56 AM
    tirediron
    100%
    Slashaar[QUOTED] and Charlie Too like this.
  13. Apr 10, 2021 at 1:49 PM
    cafereef
    subfloor is tounge and groove (house built in 2014). The LvP I am using is 100% waterproof, 5mm thick with underlayment attached too it already.
  14. Apr 10, 2021 at 2:44 PM
    SH7mi
    SH7mi Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
    Subfloor is t&g plywood or OSB?
  15. Apr 10, 2021 at 4:22 PM
    tirediron
    Ohhhhhhhh... you're using LVP, I thought it was the wooden type of laminate; my mistake. In that case, GTG! :thumbsup:
  16. Apr 10, 2021 at 4:34 PM
    OZ-T
    Peter North
    British Columbia
    Prepping 4x12 timbers for my next client build
    Poor little sawhorses
    truchador, Clark27, Drainbung and 3 others like this.
  17. Apr 10, 2021 at 4:35 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Exposed? That's a lot of sanding.
  18. Apr 10, 2021 at 4:38 PM
    OZ-T
    Peter North
    British Columbia
    yes , and yes
    but they aren't being sanded to smooth , just 36 grit / 50 grit belt sand to rip out the dirt
  19. Apr 10, 2021 at 4:40 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Some porch repair and fresh paint from a job last week. Used Lifespan to replace all that was rotten.
    Before:
    After:
    dino41, 98tacoma27, cafereef and 17 others like this.
  20. Apr 10, 2021 at 4:49 PM
    theesotericone
    Bishop CA
    I've got about 3 more weeks on my current project. Post and beam kit house that's an owner build. They got in a little, actually a lot, over their heads so asked me for some help. Cedar window cases in the great room as well as cedar T&G on two walls. Hickory cabinets. It's coming together pretty well.
    When they ordered the cedar 1x6 for the window cases and trim it was rough. I called the mill and pleaded with them to make it surfaced. They did. I didn't have to sand shit. lol
